Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi Fallout Terminal PC -- Episode 373
  • Author Author: kellyhensen
  • Date Created: 20 Nov 2018 7:53 PM Date Created
  • Last Updated Last Updated: 21 Dec 2018 8:24 AM
  • Views 10689 views
  • Likes 9 likes
  • Comments 58 comments
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
Typing a password by hand is so blase, so why not spice up your daily PC unlocking routine by creating an overly contrived password keeper? In the modern Fallout games, you find many a RobCo terminal lying about ready to reveal secrets from before the great war, but in order to gain access, you often need to “hack” the system. Let’s re-create our own mini terminal to emulate a keyboard and unlock a computer in “real life.”
Bill of Material:
Product NameManufacturerQuantity
Buy Kit
Raspberry Pi 3B+
RASPBERRY PI1Buy Now
PiTFT
ADAFRUIT1Buy Now
Speaker PhatPIMORONI1Buy Now
5VDC Power SupplyXP POWER1Buy Now
Pushbutton SwitchNTE ELECTRONICS1Buy Now
1141 -  Assembled Data Logging Shield For ArduinoADAFRUIT1Buy Now
OnOff ShimPIMORONI1Buy Now
Verbatim 3mm FilamentVERBATIM1Buy Now
Trinket 5V 16MhzADAFRUIT1Buy Now
Power AdapterXP POWER1Buy Now
DC Power ConnectorMCM1Buy Now
Additional Parts:
Product NameQuantity
M2x6 Screw Flathead
6
M2.5x6 Screw Philips
4
M2.5x10 Screw Philips
4
White, Charcoal, and Hammered Black Spray Paint
1
Micro USB B to USB A cable
1
6mm Tactile Switch
6
3D Files.zip
  • terminal
  • robco
  • fallout 3
  • fallout 4
  • bethesda
  • pimoroni
  • fallout
  • game
  • serial terminal
  • hacking minigame
  • curses
  • raspberry pi
  • fallout 76
  • fallout new vegas
  • miniature
  • friday_releasedj
  • hacking
  • friday_release
  • 3d printed
  • e14presents_djharrigan
  • mrvolt
    mrvolt over 7 years ago in reply to dougw +2
    Thanks Doug. I think I want to make a slight redesign to make this a general purpose Pi Case for future development.
  • mrvolt
    mrvolt over 6 years ago in reply to skwirl42 +2
    Wow James, I'm stoked you're still going strong on this! Also, you can definitely post the game you're working on. It's only spam if that's the only thing you do post, but you're actually sharing and contributing…
  • mrvolt
    mrvolt over 5 years ago in reply to xxbigladxx +2
    Hi there, There are multiple ways to run a program at boot. Here's a good tutorial: https://www.dexterindustries.com/howto/run-a-program-on-your-raspberry-pi-at-startup/
  • skwirl42
    skwirl42 over 7 years ago
    I’ve been working on my own. Not having a 3D printer I had the parts printed by a local shop in the colours I wanted them. The print is exactly the same as yours, but I’m still collecting hardware and deciding what I want in there. I want it to have more utility than just the hacking game (such as running pico-8 games), so I’m making some hardware changes.
    Here the are the main differences with my plan:
    • Pi Zero, for cost reasons
    • no trinket, since it won’t be interfaced with a PC
    • power will be provided from a panel mount micro USB cable from the hole designed for the trinket (still have to figure out how I’m going to get that physically connected), and will probably have to widen the hole where the trinket was intended to be to make room for that panel mount, and drill screw holes to mount it
    • I reamed out the power jack hole in the back to fit a smaller power button
    • instead of the key caps from the print I’m going to make an 8x2 USB keyboard to fit in the spot, based off of this C64 keyboard hack and using an atmega8 I’ve had lying around for over a decade, and these switches
    • The keyboard will cost a fair bit extra, but it’s a good project on its own
    Other than those changes I’m going to stick to the original design.
  • skwirl42
  • mrvolt
    mrvolt over 7 years ago in reply to skwirl42
    Very cool, James!
    I'm excited to see your take on it. Do you have any photos of your build so far?
  • skwirl42
    skwirl42 over 7 years ago in reply to skwirl42
    I have no idea what I’m going to do with the hole that was originally intended to be for the power button
  • skwirl42
    skwirl42 over 7 years ago in reply to mrvolt
    This is the only decent shot I’ve got at the moment. The case still needs some sanding. It doesn’t show up very well in the photo, but the vent is a metallic grey. I also debated whether or not I should leave the washers on with the screws. And the Pi Zero is half visible there.
    Another difference, I’ll be using a cobbler to break out the pins from the back of the display. I’ll still need to deal with the I2C pins that the speaker phat uses, but I believe the additional pins are brought out as pads on the back of the display.
  • skwirl42
    I’ll take some more pics of the case tomorrow, although there’s not much new there. I think I wrecked either the Pi or the on/off shim while soldering them together, since when I connect power absolutely nothing happens. My guess is the shim board didn’t take kindly to the rough treatment it got as I was trying to get it flush with the Pi’s pin header. My soldering skills are not great. I’m a software developer by trade. I’ve got a fork of the hacking game and I made a pull request to your repo for some of my changes.
    When I realized that curses on Windows isn’t up to the task of properly displaying essential parts of the game I also started working on a platform abstraction to offer either curses or tcod as the display library. It also abstracts input, because I was considering having a gpio based input on the Pi, or just standard input if that’s not available.
    So I guess there is more to show, it’s just not hardware.
  • skwirl42
    And I can’t find the implementation of the hacking game that works inside my RobCo OS system, so I must just have it locally. I’ll figure that out at some point.
  • skwirl42
    Thinking further on this, if I use small snap-dome switches and a silicone membrane I can fit a QWERTY keyboard into the space for the keyboard. Granted, the keys would be small, but it'd have decent tactile feedback and let me use the terminal fully.
  • skwirl42
    Also, I'd definitely need to get this assembled by whoever makes the PCB, as it'd all need to be small, SMT parts.
  • skwirl42
    I added the abstracted version of the hacking game here https://github.com/skwirl42/robco-os , so those interested can take a look at the abstraction system and how I applied it in the case of the hacking game.
  • skwirl42
    I started designing a keyboard in KiCad. I'm going to have to get creative with the key layout. This is my first attempt at this sort of thing, so I don't know if anything's wrong with the design. Right now this is just the layout for the keys and a pin header, with the idea that I'd attach a microcontroller to it and make it available as a USB keyboard.
    Here are the gerber files
    shabaz over 7 years ago in reply to skwirl42
    Hi James,
    I've placed a graphic of it below, to make it easier to see. It *almost* fine to me, but make sure (if you have not already done so) to run the error rule checks and design rule checks in KiCAD. (I don't use KiCAD so I don't know how you access that, but it will have that capability). It's not recommended to send a design off for manufacture without doing that.
    However, there's something strange going on with the switches. Are these created by yourself? They are missing the solder mask layer (in the graphic below, it should look pink like with the diodes). That's important to fix, otherwise the PCB will be unusable.
    If this is your first PCB, are you sure you'll be able to solder the switches? They look extremely small, maybe less than 3mm long.
    Also, the text (SW1, SW2, etc) is going to get wiped out by the PCB factory, in the areas where the pads are. The PCB will still function, but the printing will look ugly with chopped off text. To resolve that, either the text needs to be moved, or deleted. But this is a cosmetic thing.
    The traces could be tidied up (I guess they are auto-routed) but appear functional, I did check the trace thickness and spacing you've got there.
    If you want to do it cosmetically nice, then it all needs ripping up and manually drawn (for example, using the lower layer to do mainly horizontal traces, and the upper layer for mainly vertical traces). Here's an example (random picture via google) that is likely 2-layer too:
    But in summary I think your layout will be fine, if you do the ERC/DRC, and also resolve the switch pads.
