Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi Fallout Terminal PC -- Episode 373
  • Author Author: kellyhensen
  • Date Created: 20 Nov 2018 7:53 PM Date Created
  • Last Updated Last Updated: 21 Dec 2018 8:24 AM
  • Views 10684 views
  • Likes 9 likes
  • Comments 58 comments
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
Typing a password by hand is so blase, so why not spice up your daily PC unlocking routine by creating an overly contrived password keeper? In the modern Fallout games, you find many a RobCo terminal lying about ready to reveal secrets from before the great war, but in order to gain access, you often need to “hack” the system. Let’s re-create our own mini terminal to emulate a keyboard and unlock a computer in “real life.”
Bill of Material:
Product NameManufacturerQuantity
Buy Kit
Raspberry Pi 3B+
RASPBERRY PI1Buy Now
PiTFT
ADAFRUIT1Buy Now
Speaker PhatPIMORONI1Buy Now
5VDC Power SupplyXP POWER1Buy Now
Pushbutton SwitchNTE ELECTRONICS1Buy Now
1141 -  Assembled Data Logging Shield For ArduinoADAFRUIT1Buy Now
OnOff ShimPIMORONI1Buy Now
Verbatim 3mm FilamentVERBATIM1Buy Now
Trinket 5V 16MhzADAFRUIT1Buy Now
Power AdapterXP POWER1Buy Now
DC Power ConnectorMCM1Buy Now
Additional Parts:
Product NameQuantity
M2x6 Screw Flathead
6
M2.5x6 Screw Philips
4
M2.5x10 Screw Philips
4
White, Charcoal, and Hammered Black Spray Paint
1
Micro USB B to USB A cable
1
6mm Tactile Switch
6
3D Files.zip
  • terminal
  • robco
  • fallout 3
  • fallout 4
  • bethesda
  • pimoroni
  • fallout
  • game
  • serial terminal
  • hacking minigame
  • curses
  • raspberry pi
  • fallout 76
  • fallout new vegas
  • miniature
  • friday_releasedj
  • hacking
  • friday_release
  • 3d printed
  • e14presents_djharrigan
  • mrvolt
    mrvolt over 7 years ago in reply to dougw +2
    Thanks Doug. I think I want to make a slight redesign to make this a general purpose Pi Case for future development.
  • mrvolt
    mrvolt over 6 years ago in reply to skwirl42 +2
    Wow James, I'm stoked you're still going strong on this! Also, you can definitely post the game you're working on. It's only spam if that's the only thing you do post, but you're actually sharing and contributing…
  • mrvolt
    mrvolt over 5 years ago in reply to xxbigladxx +2
    Hi there, There are multiple ways to run a program at boot. Here's a good tutorial: https://www.dexterindustries.com/howto/run-a-program-on-your-raspberry-pi-at-startup/
  • skwirl42
    skwirl42 over 7 years ago in reply to skwirl42
    I have no idea what I’m going to do with the hole that was originally intended to be for the power button
  • mrvolt
    mrvolt over 7 years ago in reply to skwirl42
    Very cool, James!
    I'm excited to see your take on it. Do you have any photos of your build so far?
  • skwirl42
    I’ve been working on my own. Not having a 3D printer I had the parts printed by a local shop in the colours I wanted them. The print is exactly the same as yours, but I’m still collecting hardware and deciding what I want in there. I want it to have more utility than just the hacking game (such as running pico-8 games), so I’m making some hardware changes.
    Here the are the main differences with my plan:
    • Pi Zero, for cost reasons
    • no trinket, since it won’t be interfaced with a PC
    • power will be provided from a panel mount micro USB cable from the hole designed for the trinket (still have to figure out how I’m going to get that physically connected), and will probably have to widen the hole where the trinket was intended to be to make room for that panel mount, and drill screw holes to mount it
    • I reamed out the power jack hole in the back to fit a smaller power button
    • instead of the key caps from the print I’m going to make an 8x2 USB keyboard to fit in the spot, based off of this C64 keyboard hack and using an atmega8 I’ve had lying around for over a decade, and these switches
    • The keyboard will cost a fair bit extra, but it’s a good project on its own
    Other than those changes I’m going to stick to the original design.
  • mrvolt
    mrvolt over 7 years ago in reply to drradkin
    Hey Derrick,
    Have you worked more on your own build of the terminal in the mean time? I'm very curious to see another take on it, and I'm still available to answer any questions you may have.
  • mrvolt
    mrvolt over 7 years ago in reply to sheldonw76
    Hey Sheldon,
    I wanted to follow up on this build. Have you made your own version? I'd love to see any photos of work you may have done with this.
  • sheldonw76
    sheldonw76 over 7 years ago in reply to mrvolt
    Thank you, DJ!  I thought I was missing something in your original code and you were doing some voodoo to make it talk to the Trinket.  Thanks again.
  • mrvolt
    mrvolt over 7 years ago in reply to qwerty1212
    Hey there,
    There's no tutorial since this was just a proof of concept that has some flaws, but I have properly updated the repo to contain the raspi dependent version as well as the trinket code. I initially only committed just the command line version.
    Best of luck,
    DJ
  • mrvolt
    Hey Derrick,
    I've just updated the repo with the hardware dependent code. Hope that helps!
  • mrvolt
    Hi Sheldon,
    I only committed the command line version of the game. I've just updated the repo, so you should find what you need now!
  • sheldonw76
    I have been looking over the code, where does it call out the gpio pins to activate Trinket?  Thanks!
