Project Videos
  • Project Videos
Project Videos
Documents Matrix Voice Controlled Robot -- Episode 401
  • Date Created: 2 Mar 2019 7:12 PM Date Created
  • Last Updated Last Updated: 5 Jul 2019 7:24 AM
  • Views 3480 views
  • Comments 7 comments
element14 presents  |  Dave Ploeger's VCP Profile |  Project Videos
Johnny 4 wasn't very much alive until Dave put the robot's head on R8-D8s body. Johnny needed input - code that would help him to move around in his new body. Join Dave as he finally makes his robot fully functional, he adds a Matrix Voice shield to a Raspberry PI. With the help of snips.ai, which is an offline voice recognition software, he will control the robot with his voice.
Follow this guide for installing the snips.ai and the matrix voice shield:
MATRIX Voice and MATRIX Creator Running Snips.ai
Bill of Materials:
Product NameManufacturerQuantityBuy Kit
Matrix VoiceMatrix Labs1Buy Now
Arduino Nano, ATmega328-MCUArduino1Buy Now
Raspberry PI 3B+ON SEMICONDUCTOR1Buy Now
4 CH LOGIC LEVEL CONVERTERAdafruit1Buy Now
PCA9685 PWM/Servo Driver, 16-Channel, 12-Bit, I2CAdafruit1Buy Now
LED Module Type:Board + LEDAdafruit1Buy Now
GP2Y0A41SK0F - Distance Measuring SensorSHARP2Buy Now
Additional Parts:
Product NameQuantity
SG90 Servos7
LED Neopixel ring with 8 LEDs2
Prototype boards1
Headers and wires1
6V geared motors, unknown gear ratio1
Code and 3D models are attached to this document!
3D_files_and_Code.zip
  • johnny 5
  • nicolas cage
  • matrix voice
  • mqtt
  • astro-mech
  • snips.ai
  • arduino nano
  • face-off
  • pololu
  • r2-d2
  • e14presents
  • neopixels
  • oled display
  • wemos d1
  • wemos d1 mini
  • robot
  • mg90
  • johnny 5 is alive
  • john travolta
  • diy power supply
  • e14presents_davedarko
  • droid
  • gp2y0a41sk0f
  • raspberry pi
  • servos
  • ws2812b
  • astro droid
  • voice controlled robot
  • raspberry pi 3b+
  • rpi
  • voice recognition
  • matrix creator
  • astromec
  • sharp sensor
  • voice control
  • pwm controller
  • mosquito
  • pca9685
  • snips
  • motor driver
  • tank mode
  • adafruit
  • grove
  • drv8835
  • star wars
  • voice controlled
  • friday_release
  • 3d printed robot
  • 3d print
  • 3d printed
  • sg90
    dubbie over 7 years ago +1
    I really liked the robot, especially the head part and the facial expression possibilities. This is something I am interested in. But seven micro servos to get this effect does seem quite excessive. The…
  • davedarko
    davedarko over 7 years ago in reply to dubbie +1
    Thanks for the feedback, Dubbie! the snips.ai setup was one of the easiest - I dipped my toes in some of them and it definitely was good to start with (tutorials where on point) and the results were great…
    DAB over 7 years ago
    Nice project.
    I am always entertained when people think they can just throw a project together and expect it to work.
    There is a reason why us engineers spent a lot of time in class learning about the components and more importantly, the process of defining, designing, building and testing a project.
    Each step prepares you for the next and forces you to consider things you had not thought of.
    FYI, it is always a good idea to sit someone else down and walk through each of these steps with them as you explain what you think you want to do.
    You will almost always reach a point where you suddenly realize that you forgot something very important.
    Taking time to work through the process always saves you time in the long run. Yes I know a lot of people who say they just sit down and do it, but they are just lucky if they succeed at all.
    The process gets you repeatable results.
    If you want successful projects, then learn and use the process.
  • davedarko
    davedarko over 7 years ago in reply to DAB
    Thanks for the feedback!
    When I started to revisit this project for the video, I wanted to do a lot of things at the same time.
    This video shows - more than my other videos - how I defined the project while designing it.
    On other projects I went through the process afterwards and skipped the things I did in parallel that didn't work out.
    But still this project and video frustrated me a bit, because it didn't have that "all worked out perfectly fine, like planned" feeling.
    I talked a lot at MakerFaire about what's next for the robot, before making the video. My main problem probably
    was trying to find a lot of solutions in parallel, because of the nature and shortness of time in making that video.
    That way I "wasted" time on problems that weren't important in a later state.
    In the end I was successful regarding the project, but I was a bit drained after all that and it shows in the video, I think.
    Still, I learned a lot from it and try to improve for future videos..
    DAB over 7 years ago in reply to davedarko
    Learning is always good.
