Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15856 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • rogo
  • rogo
  • cmspooner
    cmspooner over 6 years ago in reply to rogo
    I agree. I am building one and was hoping to see if the button debounce was using internal pull-ups or not.
    I have the buttons and have assembled the top case. Electronics and programming today/early next week and then the bottom printed last.
  • mayermakes
    mayermakes over 6 years ago in reply to cmspooner
    as far as I can tell the MCU board used in this project has built in pullups, you ca nactivate themn in software.
    if you use an arduino micro for this (as I would) it has internal pullups for sure(also to be activated in code)
  • maximocnc
    maximocnc over 5 years ago in reply to mayermakes
    Hi Clemens. I'm new here, an I would like make my pendant but only have an arduino pro micro, I would want to ask you if you can pas me the schematic of the connections for it? or may be somebody have it?
    tnanks in advance to all.
    I'm at joseluis.cmax@gmail.com
  • mayermakes
    mayermakes over 5 years ago in reply to maximocnc
    Hi this project was done by mrvolt.
    if your Pro micro has a 32u4 MCU on it the keyboard library will work.
    if its a variant with 328p on you will need to use a different Board.
    the actual schematics dont matter that much, just connect your switsch between the pin you want to use for it and gnd. optionally place a pullup resistor on each pin or use the pinmode Pullup function in Code.
    (either way you need to make sure each pin is always at High OR low, never floating or in a weird state.)
    All the code does is wait for an input and output a corresponding keystroke  over the usb port.
