Project Videos
  • Project Videos
Project Videos
Documents DIY Shapeoko CNC Pendant -- Episode 420
  • Date Created: 11 Nov 2019 10:04 PM Date Created
  • Last Updated Last Updated: 15 Nov 2019 8:24 AM
  • Views 15855 views
  • Likes 10 likes
  • Comments 88 comments
One of the great joys of being able to design with electronics is the ability to make your own custom tools. DJ recently picked up a CNC router and in order to make his life a wee bit easier, he’s designed and built a pendant that will allow him to more comfortably, and accurately set up his parts in the machine. Follow along as he tinkers his way to new gadget that, hopefully, will be of use or inspiration for fellow makers and CNC enthusiasts.
Bill of Material:
Panel Mount Push Button Grayhill 7 Buy Now
5mm LED Multicomp 7 Buy Now
680R Resistor Multicomp Pro 7 Buy Now
3D Filament Verbatim 1 Buy Now
Rotary Encoder Bourns 1 Buy Now
Additional Parts:
Product Name
Teensy LC
Resources_DIY Shapeoko CNC Pendant.zip
element14 Presents  |  DJ Harrigan's VCP Profile  |  Project Videos
  • shapeoko
  • carbide 3d
  • digital fabrication
  • fusion 360
  • cnc
  • cad
  • usb hid
  • xxl
  • rotary encoder
  • microcontroller
  • multicomp
  • dj
  • cam
  • bourn
  • router
  • dj harrington
  • friday_release
  • woodworking
  • e14presents_djharrigan
  • rogo
    rogo over 7 years ago +2
    The project is very nice but a cabling scheme would not be refused!
  • thomasvdd
    thomasvdd over 7 years ago +1
    Awesome project! I'm definitely building this, it solves exactly the annoyance I encounter when milling. Could you share the file for the front plate which includes the text?
    DAB over 7 years ago +1
    Nice build. DAB
  • Johnalex
    Johnalex 8 months ago in reply to beacon_dave
    I’ll have to try it and see.
    Is there a wiring diagram somewhere on here?   Pretty sure I know where everything goes, but just in case.
  • Johnalex
    Thank you.  But  had forgot to switch the board from serial to keyboard.
    beacon_dave 8 months ago in reply to Johnalex
    Looks like you should be ok there as the code is looking for a high-to-low transition which should only occur as you move the selector switch between positions. It is also only sending new key presses if the updated Axis or Speed state has changed from the previous state.
  • Johnalex
    Can selector switches be used?  Or would that continue to “key press”?
    You probably need to reference the Keyboard library.
    https://docs.arduino.cc/built-in-examples/usb/KeyboardAndMouseControl/
    https://docs.arduino.cc/language-reference/en/functions/usb/Keyboard/
    https://docs.arduino.cc/language-reference/en/functions/usb/Keyboard/keyboardPress/
    https://docs.arduino.cc/language-reference/en/functions/usb/Keyboard/keyboardRelease/
    Note that the Keyboard library is for use with 32u4 and SAMD based boards.
  • Johnalex
    When I compile I get ‘Keyboard’ not found.
  • Johnalex
    I have a few questions: first, will this work on a different Teensy or Arduino board?  The Teensy class is no longer available.   Second, I would like to leave out the LEDs,  can I just remove that section?  Third, can I add axis by adding to the CASE statement?
    I don’t suppose this would work on an old Teensy 2.0++?  I have a few of those laying around.   I might have a 3.5 also
  • rozz
    rozz over 5 years ago
    Very nice. It would be helpful to have the schematic. it would be helpful to have the layout for the front panel. I'll keep looking for them but both could be added to the Resources_DYI Shapeoko CNC Pendant zip file.
  • pedtec
    pedtec over 5 years ago
    Hello , Thanks for a great project  I have 3d replicated all pieces and have programmed and succesfuly prototyped.  Wire restraint stl is not in the package.  Would you be able to direct me to where i can find such stl on thingiverse or was that something you created?  Any help would be greatly appreciated.
    Peter
  • troles
    troles over 5 years ago in reply to maximocnc
    did you ever get this done with the pro micro?  I would like to do it the same with the micro
