Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi E-Ink Task Organizer -- Episode 422
  • Date Created: 21 Nov 2019 8:20 PM Date Created
  • Last Updated Last Updated: 29 Nov 2019 8:24 AM
  • Views 17208 views
  • Likes 11 likes
  • Comments 43 comments
Design and build of a Rasbperry PI based Calendar, ToDo and Weather display on an e-ink screen. The case is made of all 3d printed parts and is able to be set on a desktop, or hung upside down from a shelf. All code written in python and pulls data from Open Weather Map for weather, Google Calendar for the calendar items and Todoist for ToDo items.
Click Here for access to all the supporting files you will need to replicate this build!
Bill of Material:
DELKIN DEVICES Flash Memory Card, MLC, MicroSDHC Card, UHS-1, Class 10, 16 GB, Utility MicroSD Series DELKIN DEVICES 1 Buy Now
RASPBERRY-PI RASPBERRY PI POWER SUPPLY, 90-264VAC, US RASPBERRY-PI 1 Buy Now
RASPBERRY-PI Single Board Computer, Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE Enabled RASPBERRY-PI 1 Buy Now
Additional Parts:
Product Name
Waveshare 7.5 inch e-Paper HAT
Eink Organizer_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • episode 422: raspberry pi e-ink task organizer
  • kaleb
  • e14presents_kalebclark
  • python
  • e-ink
  • e-paper
  • raspberry pi
  • friday release
  • e14p_KC
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to msebok +3
    Hi Matt, I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the…
    beacon_dave over 6 years ago in reply to fortyishguy +2
    "What is the eink display you used?" It tells you above under 'Additional Parts' https://www.waveshare.com/7.5inch-e-paper-hat-b.htm https://www.waveshare.com/wiki/7.5inch_e-Paper_HAT_(B)
  • jap1906
    jap1906 over 6 years ago in reply to shabaz +2
    Hi Shabaz, Thanks for your help! I just bought the Raspberry Pi model 3B and will try to configure during the weekend.
  • msebok
    msebok over 6 years ago
    Great project.
    One thought regarding the refresh. My ebook reader refreshes at each chapter, at each page it seems to just write to the screen again. it may get muddy after a couple text changes but may also limit the number of refreshes that happen. The only time I really get annoyed at the refresh is when I come to the reader after not having read for a while and the book cover stays in the background, which seems to require a manual refresh. But for normal reading it does not bother me to refresh every page. (also the refresh is quick just flashes the screen and your done I dont know if this is due to it being a purpose built machine or??..)
    I really hope you are able to limit the refresh or figure a way around it for your purposes.
    I was thinking another use for this project, for my purposes (I have an on call schedule for work) but to get a decent sized screen that would display an entire month (like a calendar does) is quite expensive. but would be ideal because it would really only need to refresh once a month.
  • msebok
    Great project.
  • KalebTheMaker
    Hi Matt,
    I have figured out that it really only needs to refresh a few times an hour and that helps a lot. After having in place for several days, I dont even notice it anymore. I have heard about the fast refresh, and my initial findings are for the smaller screens. There were no methods for that in the supplied driver from the vendor.
    About on call, that would be a good use for this! I did on-call for years and know the pains!
    Thanks,
    -Kaleb
