Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35748 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • flybysky
    flybysky over 6 years ago
    Hello, this is a awesome project, thank you for your effort and upload the files...
    i'm a very new beginner in adurino and don't have any idea how to make the wiring...can you please help me with this problem..? Maybe with a connection diagram or a video or a picture?
    It would so great to make this Project real and enjoy flying helicopter more realistic...
    much thanks in advance...
  • benaim
    benaim over 6 years ago in reply to flybysky
    Hello,
    This original post, is a very good base of reflection, but if you are beginer in arduino, and you don't have any ideas of electronics components, you need help from other person, like a friend.
    Kaleb, posted here this project, thanks to him   , I started this build, STL files are good, but not really accurate if you haven't all at home...
    The base (Support) missing, and I think he do that, because all is depend what is your settings, chair, etc...
    Now, I have one 3D printer, so I can modify the originals STL files
    Now, I'm waiting    for the bloody Bore Diameter ball to finish this project...
    When, I will finish my collective , based on this project, I will be able to send some photos
    To be able to finish this project, you need, 3D printer and base in electronic.
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to benaim
    I have uploaded the CAD file for the base plate to GitHub (Link above in supplemental content). You are correct, that was specific to my chair that I mounted this on, but it does have the correct spacing for the mounting holes.
    I found the schematic. I was not able to export, so its just a screenshot... But it's on GitHub now as well.
    -Kaleb
  • KalebTheMaker
    -Kaleb
  • benaim
    Just received my two Bore Diameter ball image
    So, now I can continue this project image
    Kaleb, Thanks for sending a diagram to all followers image
    I don't need because, I changed somethings, for example angle sensor image and I'm be able to adapt your wonderful project image
    So like I'm promised, I will send some pictures here image
  • KalebTheMaker
    Awesome, I am glad you made some changes to it, make it what you want!
    Good luck, and please share pics. Excited to see another build of this!
    -Kaleb
  • fcaballerog
    fcaballerog over 6 years ago in reply to benaim
    ¿Podría Philippe además de publicar sus fotos, publicar sus archivos modificados? Diagrama de cableado STL, etc. Entonces tendríamos dos versiones para elegir y ensamblar.
    Gracias.. image
