Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35765 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • alecmg
    alecmg over 1 year ago in reply to alecmg
    Hi, I was missing a built-in accelerator like the real thing on helicopters.
    Since I use it in MSFS2020, I felt the need to change this already pretty cool design.
  • alecmg
    alecmg over 1 year ago in reply to murrayadamjames
  • murrayadamjames
    murrayadamjames over 1 year ago in reply to alecmg
    Cool. I finished the project. I’m happy to share my updated code and talk with you about the project.
  • alecmg
    Hello, I'm just getting started. But I took the liberty of making some changes to the project. I added a throttle grip, with a potentiometer in the center of the tube. The wires are now on the outside in a curved rod (channel).
    I'm printing everything right now. When it's ready, I'll post the results here.
  • murrayadamjames
    Hey all.  I am building this project.. yes, 5 years late.  I have it all wired up, code is in the Arduino micro, and it is displaying as a joystick in Windows.  I could use some pointers to help complete the testing. The ACE is not working perfectly and the buttons are not working correctly. If anyone has time to help I would appreciate it.
  • murrayadamjames
    can someone help me find the twitch live stream?
    link is not working
  • benaim
    benaim over 2 years ago in reply to Uni33
    I abandoned Arduino IDE a long time ago. I now use VSCODE and PlatfomeIO ( https://platformio.org/)
    See even Cursor ( https://www.cursor.com ) the free version, which helps you (sometimes yes, sometimes not) thanks to AI.
    It perfectly manages many modules like Arduino or even ESP32
    Main advantage, we can see the calls to external libraries (source code) and better understand how to use them.
    Above all, we can keep versions of old libraries for old projects, without necessarily having them updated. Which is impossible with the Arduino IDE. This allows us to resume old projects without fearing that a library update will bug, because a function is no longer supported.
    At first, it seems more complicated to use, but in the end, we save a lot of time.
    Enjoy VSCODE ( or Cursor ) and PlateformIO Heart eyes
  • Uni33
    Uni33 over 2 years ago
    ok, I managed to load the correct libraries and the compilation was successful, we will see after assembling and uploading to Arduino
  • Uni33
    C:\Users\Activcom\Desktop\Helikopter\HeliCollective-master\HeliCollective-master\CollectiveControl\CollectiveControl.ino: In function 'void loop()':
    C:\Users\Activcom\Desktop\Helikopter\HeliCollective-master\HeliCollective-master\CollectiveControl\CollectiveControl.ino:151:23: error: 'class ClickEncoder' has no member named 'getValue'
    value += handleEnc->getValue();
    C:\Users\Activcom\Desktop\Helikopter\HeliCollective-master\HeliCollective-master\CollectiveControl\CollectiveControl.ino:188:17: error: 'Button' is not a member of 'ClickEncoder'
    ClickEncoder::Button b = handleEnc->getButton();
    C:\Users\Activcom\Desktop\Helikopter\HeliCollective-master\HeliCollective-master\CollectiveControl\CollectiveControl.ino:189:7: error: 'b' was not declared in this scope
    if (b != ClickEncoder::Open) {
    C:\Users\Activcom\Desktop\Helikopter\HeliCollective-master\HeliCollective-master\CollectiveControl\CollectiveControl.ino:189:26: error: 'Open' is not a member of 'ClickEncoder'
    exit status 1
    Compilation error: 'class ClickEncoder' has no member named 'getValue'
  • Uni33
    Hi, I don't know how to write Arduino code and I have a problem with errors when compiling the code. Are you able to send me the correct code? I really want to make such controls for my son and I already have all the elements.
