Project Videos
  • Project Videos
Project Videos
Documents DIY Arduino Helicopter Collective Joystick Control -- Episode 440
  • Date Created: 1 Apr 2020 8:47 PM Date Created
  • Last Updated Last Updated: 3 Apr 2020 7:24 AM
  • Views 35885 views
  • Likes 15 likes
  • Comments 139 comments
I love to fly in simulators, especially helicopters. But, there is just not an affordable collective control that I have found, so I decided to make one for myself! I am going to build a joystick using an Arduino Micro, with a bunch of buttons for assignable controls and a high quality encoder for the collective axis.
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Also you can watch the live Twitch recording about this build: element14 Presents Live Twitch Stream: DIY Arduino Helicopter Collective Joystick Control
Bill of Material:
BOURNS Absolute Rotary Encoder, 120 rpm, 128 PPR, EAW Series BOURNS 1 Buy Now
ARDUINO Development Board, Arduino Micro, ATmega32U4 MCU, 20 3.3V I/O, 12 Analogue Inputs, ISCP Header ARDUINO 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Square ITW SWITCHES 1 Buy Now
ITW SWITCHES Pushbutton Switch, Industrial, 59 Series, 13.6 mm, SPST-NO-DB, Momentary, Round ITW SWITCHES 1 Buy Now
C & K COMPONENTS SWITCH, SPDT, 5A, 120VAC C & K COMPONENTS 3 Buy Now
BOURNS Incremental Rotary Encoder, Pro Audio, Continuous. 24 Detents, 24 Pulses, Quadrature Output BOURNS 1 Buy Now
Additional Parts:
Product Name
5 Way Momentary Square SMD Tactitle Switch
M3x5x2 Square Nuts
8mm Bore Diameter ball mounted pillow blocks
T6 Seamless Aluminum Round Straight Tubing 16 Gauge 1-3/8" OD
HelicopterCollective_Resources.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • itw
  • arduino micro
  • rotary encoder
  • friday release
  • diy arduino helicopter collective joystick control
  • bourns
  • e14p_KC
  • helicopter
  • friday_release
  • benaim
    benaim over 6 years ago +5
    One good project, it's one project that you can modify So I changed my mind, I use now one hall sensor AS5048a with 14-bit resolution ( Best resolution and linerality ) I changed too, the place of friction…
  • benaim
    benaim over 6 years ago in reply to benaim +4
    Pictures coming, better later than never So I used on SS495a, and to have one big range of value for "only" 45° of move, I done one adapter with 2 magnets. With this I have near 0 to 5 Volts on SS495a…
  • benaim
    benaim over 6 years ago in reply to KalebTheMaker +3
    Just received my two Bore Diameter ball So, now I can continue this project Kaleb, Thanks for sending a diagram to all followers I don't need because, I changed somethings, for example angle sensor and…
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to fcaballerog
    They should all be on the Bill of Materials above. There are four ITW switches, three toggles, and the hat switch. Toggles are the "C & K" switches.
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to creektime
    Hey Joe, You are right, the one in the "Base" directory is the right one. Iterative design with poor cleanup or just lost in a mountain of files. Sorry for the mixup!
    I will see about getting the file here updated. Let me know how the build goes, would love to see pics!
    -Kaleb
  • ironeagle585
    ironeagle585 over 6 years ago
    HI Kaleb, thank you for a great maker project, already got the maechnical part done, but was wondeing where you can get hold of the Controllers Lite software you used in the video, searched Goggle etc, but no joy, hope you can help. All the best.
  • celcius1
    celcius1 over 6 years ago
    Hi Kaleb,
    I loved this project of yours but after watching a video of Tom Stantons when he did a video of a helicopter not a drone, it got me thinking bout building a helicopter again.
    What I've been going over is I want to build a coaxial rotor design, with a full swashplate and collective control, but with one motor, to closer model a real world helicopter.  What I'm trying to figure out is how I can run both rotors but have the ability to adjust the speed of each rotor to give me yaw control.  Any thoughts, I was either looking at a clutch design, or a geared design similar to that of a CVT to control the rotational speed of the two rotors.  But my ultimate design goal is to use one motor.
    Then see if I can link it up to your helicopter control.
    Regards
    Paul
  • fcaballerog
    fcaballerog over 6 years ago
    Good to all, I am looking at the diagram and I get the impression that there are more push buttons and switches than in the list of components .. Does anyone who is assembling the device have the list of components to be able to order and buy them?
  • creektime
    creektime over 6 years ago
    You have two different friction plates.  One in the the 'Base' directory that has a newer date on it, and the other one directory above it with 3 other files.  Since the one in the Base directory matches the design, I am assuming that we should be using that one.  But what is/was the other one for?
  • fcaballerog
    fcaballerog over 6 years ago in reply to benaim
    ¿Podría Philippe además de publicar sus fotos, publicar sus archivos modificados? Diagrama de cableado STL, etc. Entonces tendríamos dos versiones para elegir y ensamblar.
    Gracias.. image
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to benaim
    Awesome, I am glad you made some changes to it, make it what you want!
    Good luck, and please share pics. Excited to see another build of this!
    -Kaleb
  • benaim
    Just received my two Bore Diameter ball image
    So, now I can continue this project image
    Kaleb, Thanks for sending a diagram to all followers image
    I don't need because, I changed somethings, for example angle sensor image and I'm be able to adapt your wonderful project image
    So like I'm promised, I will send some pictures here image
  • fcaballerog
    fcaballerog over 6 years ago in reply to KalebTheMaker
    Thank you! by the scheme I am looking forward to mounting it ..
    A question, is there any possibility to make a list of the components but to order them by aliexpress? I think it is the cheapest place for components ..
    Thank you so much..
