Project Videos
  • Project Videos
Project Videos
Documents DIY Dance Dance Revolution Mat -- Episode 471
  • Date Created: 29 Oct 2020 2:56 PM Date Created
  • Last Updated Last Updated: 6 Nov 2020 8:24 AM
  • Views 6240 views
  • Likes 9 likes
  • Comments 18 comments
I LOVED those dance machines in arcades where you would jump on different arrows to music. But I always too shy to get on one in front of everyone! Now you can make your own touch sensitive dance mat to play on for hours in the comfort of your own home. This dance mat uses a Circuit Playground Express to create touch sensitive arrows that you have to dance on before your time runs out. The more arrows you hit, the faster the game goes. It’s quite a workout!
Bill of Material:
Battery Holder, 3 x AAA, On/Off Switch, 2-Pin JST, 6" Long Cable Adafruit 1 Buy Now
Single Core Wire MultiComp Pro 1 Buy Now
M3 Bolt TR Fastenings 1 Buy Now
M3 nut TR Fastenings 1 Buy Now
M4 ring terminal Pro Power 1 Buy Now
Additional Parts:
Product Name
Copper Tape
Coloured vinyl
A self powered speaker for louder beeps with 2 croc clips for connecting
Episode 471 Resources.zip
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • e14p_LU
  • lorraine
  • dance
  • e14presents_lorraineunderwood
  • dancing
  • stepmania
  • dance mat
  • lorraine underwood
  • circuit playground express
  • multicomp
  • adafruit
  • touch sensitive
  • e14presents_lunderwood
  • friday_release
  • Workshopshed
    Workshopshed over 5 years ago +4
    I built one of these back at the end of last year and had similar issues to you. I believe the issue is that you need to be grounded for the capacitive sensors to work well. It worked a lot better if you…
    DAB over 5 years ago +2
    Hi Lorraine, I think you need to add a good ground plane to ensure you get a good capacitance reading. Try using a metal screen under the cardboard attached to the ground wire of your CPU device. That…
  • kmikemoo
    kmikemoo over 5 years ago +2
    lorrainbow I LOVE IT! I really liked that you shared the struggles because that's how all of my projects go. I'm always intrigued by how the problem was solved. I would call your project a rousing success…
    Hi Lorraine,
    That should get you a more consistent capacitive touch circuit.
  • Workshopshed
    Workshopshed over 5 years ago in reply to DAB
    Hey Dab, that was the same conclusion I had with my version. The issue is not that the floor is conductive, it is because the dancer is insulated from the floor.
    Try an antistatic wristband or a long wire connected to the plumbing.
  • Workshopshed
    DAB over 5 years ago in reply to Workshopshed
    Yes, the capacitive sensing needs to have a charge difference.
    If you include the ground plane, you set up two plates for the sensing to work.
