Project Videos
  • Project Videos
Project Videos
Documents DIY Dance Dance Revolution Mat -- Episode 471
  • Date Created: 29 Oct 2020 2:56 PM Date Created
  • Last Updated Last Updated: 6 Nov 2020 8:24 AM
  • Views 6204 views
  • Likes 9 likes
  • Comments 18 comments
I LOVED those dance machines in arcades where you would jump on different arrows to music. But I always too shy to get on one in front of everyone! Now you can make your own touch sensitive dance mat to play on for hours in the comfort of your own home. This dance mat uses a Circuit Playground Express to create touch sensitive arrows that you have to dance on before your time runs out. The more arrows you hit, the faster the game goes. It’s quite a workout!
Bill of Material:
Battery Holder, 3 x AAA, On/Off Switch, 2-Pin JST, 6" Long Cable Adafruit 1 Buy Now
Single Core Wire MultiComp Pro 1 Buy Now
M3 Bolt TR Fastenings 1 Buy Now
M3 nut TR Fastenings 1 Buy Now
M4 ring terminal Pro Power 1 Buy Now
Additional Parts:
Product Name
Copper Tape
Coloured vinyl
A self powered speaker for louder beeps with 2 croc clips for connecting
Episode 471 Resources.zip
element14 presents
element14 presents  |  About Lorraine |  Project Videos
  • e14p_LU
  • lorraine
  • dance
  • e14presents_lorraineunderwood
  • dancing
  • stepmania
  • dance mat
  • lorraine underwood
  • circuit playground express
  • multicomp
  • adafruit
  • touch sensitive
  • e14presents_lunderwood
  • friday_release
  • Workshopshed
    Workshopshed over 5 years ago +4
    I built one of these back at the end of last year and had similar issues to you. I believe the issue is that you need to be grounded for the capacitive sensors to work well. It worked a lot better if you…
    DAB over 5 years ago +2
    Hi Lorraine, I think you need to add a good ground plane to ensure you get a good capacitance reading. Try using a metal screen under the cardboard attached to the ground wire of your CPU device. That…
  • kmikemoo
    kmikemoo over 5 years ago +2
    lorrainbow I LOVE IT! I really liked that you shared the struggles because that's how all of my projects go. I'm always intrigued by how the problem was solved. I would call your project a rousing success…
  • celcius1
    celcius1 over 5 years ago
    Nice try, but failed dismally I was quite the player of these games in my 20’s even built my own arcade replica of the dance mat, with plywood and polycarbonate sheeting.  Ended up selling it a few years later but I still have the plans.
    my original design utilised the controller from a PSX for the input, so yes I had DDR 5th mix on the PSX, and later modified it using a keyboard matrix so I could hook it up to my computer as well when playing the game Dance With Intensity https://www.ddrpcgamer.com/Dance-With-Intensity-en.htm
    So no need to reinvent the wheel, the software is available albeit for PC but all the PC is expecting is the correctly associated keys.
    Capacitive touch is good if implemented in a more sound manner,  beats having to use heavy duty micro switches in my original design.
    I Would say think it through more and you will succeed but you may have been better off using ply and plastic sheeting.
  • celcius1
