Project Videos
  • Project Videos
Project Videos
Documents Metal Plate Your 3D Prints with a DIY Galvanizing Machine -- Episode 477
  • Date Created: 15 Dec 2020 6:40 PM Date Created
  • Last Updated Last Updated: 18 Dec 2020 8:24 AM
  • Views 7882 views
  • Comments 22 comments
The fastest way to iterate on mechanical prototype parts is probably 3d printing, but some parts need to be finally done in machined metal. Wouldn't it be awesome if you could quickly 3D print a part and metalize it within minutes to show your customer asap how the finished part will look like? Clem builds a self contained portable easy to use galvanizing machine on a shoestring budget and tests out its capabilities. Coating Steel with Copper, 3D printed PETG with real Gold reclaimed from old electronics and even a metalized Rubber duck.
Bill of Material:
TEXAS INSTRUMENTS Digital Isolator, 2 Channel, 70 ns, 3 V, 5.5 V, SOIC, 8 Pins TI 1 Buy Now
ALPS ALPINE Rotary Encoder, Insulated Shaft, Mechanical, Incremental, 24 PPR, 24 Detents, Vertical Alps Alpine 1 Buy Now
POLYMAKER 3D Printer Filament, PolyLite Series, 1.75mm Dia, Transparent, PETG, 1 kg Polymaker 1 Buy Now
XP POWER AC/DC Power Supply, ITE, 2 Output, 42 W, 5 V, 5 A, 24 V XP-Power 1 Buy Now
BOURNS SMD Current Sense Resistor, 0.1 ohm, CR Series, 2512 [6432 Metric], 3 W, ± 1%, Metal Film BOURNS 1 Buy Now
SCHRACK - TE CONNECTIVITY General Purpose Relay, RZ Series, Power, Non Latching, SPDT, 5 VDC, 16 A SCHRACK 1 Buy Now
TEXAS INSTRUMENTS Current Sense Amplifier, 1 Amplifier, SOT-23, 8 Pins, -25 °C, 85 °C TI 1 Buy Now
Arduino UNO Arduino 1 Buy Now
Additional Parts:
Product Name
PCB by Aisler
Krokoclamps
thick cables
Glass Jars
Copper sulfate, Sodiumbicarbonate, Gold electrolyte
Copper pipe, Gold plated spare components
DIYGalvanizer_Resources.zip
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • how to coat metal easy
  • arduino uno
  • maker machinery
  • clem
  • arduino galvanizing
  • alps alpine
  • e14presents_mayermakes
  • metal look
  • reclaim gold
  • easy galvanizing
  • how to galvanize plastics
  • metal 3d prints
  • polymaker
  • real gold on 3d prints
  • metalize your 3d
  • schrack
  • arduino uno project
  • bourns
  • metalize
  • coat 3d prints
  • simple metal coating
  • friday_release
  • mayermakes
  • xp power
  • e14p_CMM
  • galvanizing
  • celcius1
    celcius1 over 5 years ago +4
    Nice neat project clem, could this project be used to do Aluminium Anodising or is it just galvanising?
  • mayermakes
    mayermakes over 5 years ago in reply to jrdst1100tx +3
    DAB over 5 years ago +2
    Good episode Clem. FYI, you can use a stirring mechanism to improve the plating time. You get localized deficits of the plating compound, which inhibits new molecules and atoms from reaching the intended…
  • easyejl
    easyejl over 5 years ago
    Fantastic! I was starting to (unsuccessfully so far) play with electroplating conductive PLA, but this is much better.
  • mayermakes
    mayermakes over 5 years ago in reply to easyejl
    thanks, keep in mind you need to tweak settings and solutions to work with your particular part so a good outcome needs some trial and error.
  • easyejl
    easyejl over 5 years ago in reply to mayermakes
    I was more or less following this
    https://www.instructables.com/High-Quality-and-safe-Nickel-Plating/
  • easyejl
