Project Videos
  • Project Videos
Project Videos
Documents DIY Miniature Multimeter -- Episode 483
  • Date Created: 26 Jan 2021 4:41 PM Date Created
  • Last Updated Last Updated: 29 Jan 2021 8:24 AM
  • Views 5229 views
  • Likes 14 likes
  • Comments 14 comments
Breadboarding is often the start of great projects but measuring on Breadboards is often not so great. The standard multimeter leads don't fit into breadboard holes and alligator clips are needed to connect to the circuit. There must be a better way! Clem designs a tiny Multimeter dedicated to be used with a breadboard! Easy to connect, battery powered and it even has a WI-FI so you can view the readings on your phone!
Get the PCB here: https://aisler.net/p/BKDRSPYV
Bill of Material:
BAK Rechargeable Battery, 3.7 V, Lithium Polymer, 370 mAh, Connector BAK 1 Buy Now
MIDAS Graphic OLED, 96 x 16 Pixels, White on Black, 3V, I2C, 33mm x 10mm, -40 °C Midas 1 Buy Now
MCM Wire Kit, Jumper, Copper, 0.6 mm Diameter, 350 Piece MCM 1 Buy Now
FTDI Interface Analog Development Board LC234X, USB to UART Bridge FTDI 1 Buy Now
MICROCHIP Battery Charger for 1 Cell of Li-Ion, Li-Pol battery, 6V input, 4.2V / 500mA charge, SOT-23-5 Microchip 1 Buy Now
MICROCHIP Fixed LDO Voltage Regulator, 2.1V to 6V, 210mV Drop, 3.3V/500mA Out, SOT-223-3 Microchip 1 Buy Now
ESP32-S2-WROOM espressif 1 Buy Now
USB Connector, USB Type C, USB 3.1, Receptacle, 24 Ways, Surface Mount, Right Angle Molex 1 Buy Now
INA219 SOIC TI 1 Buy Now
0,1 Ohm current shunt resistor panasonic 1 Buy Now
Additional Parts:
Product Name
ESP32-S2-WROOM
MiniMultimeter_Resources.zip
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • esp32
  • oled
  • molex
  • measure voltage arduino
  • make a multimeter
  • clem
  • mcm
  • ina219 arduino
  • homemade multimeter
  • battery charger
  • microchip
  • native usb esp32s2
  • esp32 project
  • esp32 multimeter
  • diy multimeter
  • e14presents_mayermakes
  • esp32-s2-wroom
  • breadboard
  • BAK
  • oled arduino
  • esp32-s2
  • rechargeable battery
  • multimeter
  • esp32s2
  • midas
  • friday_release
  • mayermakes
  • ftdi
  • e14p_CMM
  • simple esp32s2 i2c on esp32
  • mayermakes
    mayermakes over 5 years ago +4
    Here are some interesting question is want to adress: by user Cliff Matthews I don't know why the typical breadboard end-type PCB format wasn't chosen as the base PCB (you could put your 3D plastic contraption…
    DAB over 5 years ago +3
    Nice build Clem. The screen is way too small for someone like me, but sending the data to your phone or computer makes up for that problem. DAB
  • aspork42
    aspork42 over 5 years ago +3
    I love it! I see two different uses - "local" just as you have noted; and "Remote" where these are small enough to deploy out and about; perhaps around a larger machine like the power supply on a 3D printer…
  • kmikemoo
    kmikemoo over 5 years ago
    mayermakes  VERY cool.  Outside my current skill set, but awesome none the less.  Definitely bookmarked for visiting again later.
    On the MODE Resistance in the code, why ADC?  I don't understand why (ReadADC/10).  Wouldn't VR1 = [(Vin/1023) * ReadADC]?  I can understand the rest - although I did need to get out the paper and pen to dust the cobwebs from my brain.
  • kmikemoo
  • mayermakes
    mayermakes over 5 years ago in reply to kmikemoo
    well....
    as stated in the video that section gives me headachse, I tried multiple versions and that yielded the closest to the nomainal value of the resistor Imeasured, but my math could be totally wrong, I derived that section from some adc tutorial, and tried to adapt it.
    so if you have abetter understanding please feel free to improve the code.
    one thing I recently heard a lot is that the esps adc is not reliable so there might be another issue.
    on a future version I would likely outsource that to a dedicated adc chipp that feeds data back over i2C
