Project Videos
  • Project Videos
Project Videos
Documents Make The Ultimate Phone Charging Camping Flashlight -- Episode 486
  • Date Created: 16 Feb 2021 6:05 PM Date Created
  • Last Updated Last Updated: 19 Feb 2021 8:24 AM
  • Views 4733 views
  • Likes 9 likes
  • Comments 17 comments
Carrying around a rechargeable torch and power bank when out and about at night or whilst camping? Why not combine them into one easy to carry unit? Here’s how I do it.
Supplemental Content:
  • Episode 486: Bonus Content: Make The Ultimate Phone Charging Camping Flashlight
Bill of Material:
PICPALNB126 Rechargeable Battery, 14.4 V, Lithium Ion, 3.35 Ah, 18650, Connector Panasonic 1 Buy Now
CC094 USB Connector, USB Type A, Socket, 2 Ways, Chassis Mount, Horizontal Velleman SA 1 Buy Now
0523405 Carpoint Socket Outlet, 12V Carpoint 1 Buy Now
48-782 Marine Grade Weatherproof 12V Cigarette Lighter Socket Philmore 2 Buy Now
Connector Housing, KK 254 2695, Receptacle, 2 Ways, 2.54 mm Molex 1 Buy Now
08-50-0032 Contact, KKRegistered 254, KK 254 4809 Series, Socket, Crimp, 22 AWG, Tin Plated Contacts Molex 1 Buy Now
Quick Disconnect Terminal, FASTON 250 Series, Female Quick Disconnect, 6.35mm x 0.81mm AMP – TE CONNECTIVITY 1 Buy Now
1614 10 DC Power Connector, Jack, 2 A, 2.35 mm, Panel Mount, Solder Lumberg 1 Buy Now
LED Housing, 9.5 mm x 12.5 mm, Black, Plastic, 5mm / T1 3/4 LEDs KINGBRIGHT 7 Buy Now
Pushbutton Switch, 20.2 mm, DPST, Off-On, Round Raised, Black Multicomp Pro 2 Buy Now
Pushbutton Switch, 20.2 mm, DPST, Off-(On), Round Raised, Black Multicomp Pro 1 Buy Now
Additional Parts:
Product Name
27W 12V DC Round LED Work Lamp
Plastic box with handle
UltimateFlashlightResources.zip
element14 presents
element14 presents  |  About Katie |  Project Videos
  • traveling
  • katie dumont
  • carpoint
  • molex
  • usb power bank
  • e14p_KD
  • lumberg
  • e14presents_kdumont
  • panasonic
  • te connectivity
  • velleman
  • kingbright
  • lithium ion charger
  • katie
  • multicomp
  • torch
  • camping
  • rechargeable battery
  • night walks
  • friday_release
  • hifromkatie
    hifromkatie over 5 years ago in reply to baldengineer +4
    I came across the buttons whilst searching, but they are really neat. Going to keep them on my go to parts list! The OpenSCAD is a bit of a fragile relationship, when I get my head around an idea then…
  • baldengineer
    baldengineer over 5 years ago +2
    Unexpected OpenSCAD (@ 9:20)! You are definitely more skilled with it than I am. I can, just barely, edit pre-existing designs. Also, I didn't know Multicomp Pro had those panel mount push buttons. I need…
  • koudelad
    koudelad over 5 years ago +2
    Nice build! The output luminosity is huge I was also impressed by the OpenSCAD. Do you have an estimation of the battery life while powering just the lamp? I would suggest to do some basic (PWM?) regulation…
  • hifromkatie
    hifromkatie over 5 years ago in reply to royjames
    Like Dave has said, the files are for KiCad and OpenSCAD, both are free to use, and can be downloaded online. It appears the zip is downloaded fine, it's just the computer can't find a way to open them. (KiCad for .sch and kicad_pcb & OpenSCAD for .scad files).
    Please give it a go and let me know if you have any further issues or questions
  • royjames
    royjames over 5 years ago in reply to beacon_dave
    Thanks Dave I will try that. much appreciated
    beacon_dave over 5 years ago in reply to royjames
    "...I have dowloaded the zip file, butI can't open them..."
    You will need the KiCad / OpenSCAD etc. design tools installed to open these design files.
  • royjames
    royjames over 5 years ago in reply to hifromkatie
    Sorry Katie, for being a pest. I have dowloaded the zip file, butI can't open them.
    getting the following:
    Any help would be appreciated, probably very simple, but maybe I having a senior moment.
  • airbornesurfer
    airbornesurfer over 5 years ago
    I like the functionality of a box lantern design versus so many off-the-shelf ideas that try to jam as much as possible into the handle. Well done!
  • hifromkatie
    What stage are you getting to with downloading/opening? I'll see if I can point you in the right direction, or get someone else to assist.
  • royjames
    Katie I am problems downloading the zip file. More likely a senior moment on my side. please advise. Roy
  • hifromkatie
    hifromkatie over 5 years ago in reply to koudelad
    Good call, hadn't thought about that image
  • koudelad
    koudelad over 5 years ago in reply to hifromkatie
    My guess is that 27 W is absolute maximum power consumption when powered by a car battery that is charged by an alternator. This can easily be 14.8 V (which is 1.23 times more than 12 V) and then 19.46 W * 1.23 = 24 W , which is closer.
    Here is a typical measurement on a car battery when not being charged and while running the engine.
  • hifromkatie
    hifromkatie over 5 years ago in reply to DAB
    The strap would be a good idea, it's fairly hefty in weight. A few minutes around the garden is fine, but I'm not sure I'd want to go on a long walk with it.
