Project Videos
  • Project Videos
Project Videos
Documents Arduino vs 555 Timer - Tiny Slot Car Racers -- Episode 492
  • Date Created: 22 Mar 2021 10:46 PM Date Created
  • Last Updated Last Updated: 2 Apr 2021 7:24 AM
  • Views 5642 views
  • Likes 8 likes
  • Comments 12 comments
"Should have used a 555!" A special breed of makers often boasts in comments about simple Arduino projects. But are they right or wrong..or is there more to it besides a simple choice? Clem finds out with a fun-only project so nobody can argue about its purpose! A tiny electronic slot racing tabletop game! Once built with a 555 timer circuit and rebuilt with an Arduino and some simple code. Both perform the same function..but which one is better?
Supplemental Content:
  • Episode 492: Bonus Content: Slot Car Racers Full Reveal
Bill of Material:
NE555P TI 1 Buy Now
Resistor MCF 0.25W 1M MULTICOMP PRO 1 Buy Now
resistorMCF 0.25W 10K MULTICOMP PRO 1 Buy Now
Cap 1uF Epcos 1 Buy Now
Cap 0,1uf Epcos 1 Buy Now
LM7808 ST 1 Buy Now
Schrack / TE 2 Buy Now
Arduino nano Every Arduino 1 Buy Now
RED LED 5V kingbright 1 Buy Now
Resistor 390 ohm MULTICOMP PRO 1 Buy Now
Additional Parts:
Product Name
Arcade style buttons
SlotRacers_Resources.zip
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • raspberry pi webcam
  • te
  • epcos
  • clem
  • hq camera projects
  • e14presents_mayermakes
  • robot
  • rpi moving camera
  • uv4l
  • 555 timer
  • raspberry pi
  • kingbright
  • multicomp
  • hq camera
  • schrack
  • friday_release
  • mayermakes
  • 555
  • e14p_CMM
  • mayermakes
    mayermakes over 5 years ago in reply to celcius1 +3
    Thanks for the tips, I built it purely from my memory of how a slotcar looks on the underside, andhad to make some changes to make it fit my desired parts. Haven't seen a real slotcar in person foar at…
  • mayermakes
    mayermakes over 5 years ago in reply to kmikemoo +3
    thanks, sometiomes its nice to get away from programming and build purely with descrete parts..but after troubleshooting that curcuit you remember why programming is so much easier to debug.
    beacon_dave over 5 years ago +3
    I recall that the Matchbox cars had solid spring-loaded pick-up shoes as opposed to the braid pick-ups. You can see them at around 6:36 into this video: Powertrack Car Service / Speedtrack https://youtu…
  • mayermakes
    mayermakes over 5 years ago in reply to DAB
    thats right, experience is a major factor!
    DAB over 5 years ago
    Fun project Clem.
    I have spent many hours playing with slot cars, especially the smaller scale ones.
    You are correct. You have to spend a lot of time cleaning the brushes and motor contacts because they build up carbon.
    These cars also put out a lot of EMF which will interfere with some electronic devices.
    The issue of the 555 verses Arduino comes down to experience in the specific devices.
    If you are good at electronics, you can do changes to the 555 very quickly.
    If you are good at software, you can probably do the changes in software faster.
    Either device will give you lots of flexibility and fun.
  • mayermakes
    mayermakes over 5 years ago in reply to beacon_dave
    I only associate matchbox with Die cast toys, had no idea they made other products.
    Also my last encounter with a slot car was 20 years ago, So I pretty muched guessed and tried to recal lfeatures I saw. Did not  bother to google much
         https://youtu.be/eAlq7TnxXug?t=396
  • mayermakes
  • mayermakes
    mayermakes over 5 years ago in reply to Workshopshed
    possibly? maybe? could be? I suspect its that the car does little hops as it is crazy overpowered, maybe if it does not loose contact the carbon buildup wouldbe not happenening
  • mayermakes
    the limits of sourcing and sinking current are vastly different on the chip, that is why I did it that way the other version ended in a blwon up 555
  • mayermakes
    Haven't seen a real slotcar in person foar at least 20 years.
  • kmikemoo
    kmikemoo over 5 years ago
    mayermakes  I love it!  While I love the Arduino, I'm often more impressed with the elegance of a discrete component circuit.  That which looks like it should be simple rarely is as easy as it seems at first.
    I also like that you went for the aesthetics of the mountain raceway first. image  Great job building it all from scratch!
  • Workshopshed
    Workshopshed over 5 years ago
    I wonder if an AC supply and a diode in the car would reduce sparking and carbon buildup?
