Project Videos
  • Project Videos
Project Videos
Documents Arduino vs 555 Timer - Tiny Slot Car Racers -- Episode 492
  • Date Created: 22 Mar 2021 10:46 PM Date Created
  • Last Updated Last Updated: 2 Apr 2021 7:24 AM
  • Views 5642 views
  • Likes 8 likes
  • Comments 12 comments
"Should have used a 555!" A special breed of makers often boasts in comments about simple Arduino projects. But are they right or wrong..or is there more to it besides a simple choice? Clem finds out with a fun-only project so nobody can argue about its purpose! A tiny electronic slot racing tabletop game! Once built with a 555 timer circuit and rebuilt with an Arduino and some simple code. Both perform the same function..but which one is better?
Supplemental Content:
  • Episode 492: Bonus Content: Slot Car Racers Full Reveal
Bill of Material:
NE555P TI 1 Buy Now
Resistor MCF 0.25W 1M MULTICOMP PRO 1 Buy Now
resistorMCF 0.25W 10K MULTICOMP PRO 1 Buy Now
Cap 1uF Epcos 1 Buy Now
Cap 0,1uf Epcos 1 Buy Now
LM7808 ST 1 Buy Now
Schrack / TE 2 Buy Now
Arduino nano Every Arduino 1 Buy Now
RED LED 5V kingbright 1 Buy Now
Resistor 390 ohm MULTICOMP PRO 1 Buy Now
Additional Parts:
Product Name
Arcade style buttons
SlotRacers_Resources.zip
element14 presents
element14 Presents  |  About Clem  |  Project Videos
  • raspberry pi webcam
  • te
  • epcos
  • clem
  • hq camera projects
  • e14presents_mayermakes
  • robot
  • rpi moving camera
  • uv4l
  • 555 timer
  • raspberry pi
  • kingbright
  • multicomp
  • hq camera
  • schrack
  • friday_release
  • mayermakes
  • 555
  • e14p_CMM
  • mayermakes
    mayermakes over 5 years ago in reply to celcius1 +3
    Thanks for the tips, I built it purely from my memory of how a slotcar looks on the underside, andhad to make some changes to make it fit my desired parts. Haven't seen a real slotcar in person foar at…
  • mayermakes
    mayermakes over 5 years ago in reply to kmikemoo +3
    thanks, sometiomes its nice to get away from programming and build purely with descrete parts..but after troubleshooting that curcuit you remember why programming is so much easier to debug.
    beacon_dave over 5 years ago +3
    I recall that the Matchbox cars had solid spring-loaded pick-up shoes as opposed to the braid pick-ups. You can see them at around 6:36 into this video: Powertrack Car Service / Speedtrack https://youtu…
  • celcius1
    celcius1 over 5 years ago
    Hi Clem,
    Obviously you don't have much experience with slot cars, where as I have and have helped with building tracks.  Your better off using 12mm or 16mm MDF, and then using a trimmer router https://www.bunnings.com.au/ryobi-400w-trim-router_p6210607  and the correct router bit.   Then you either cut the slot using either a straight edge or profile.  If your using more of a braid than tape as the power tracks, then that part needs to be routed as well.  And with most slot cars to get them to run straight the slot needs to be snug not tight and using a round pin, and at least 5 to 7 mm deep.  The car should run straight then.
    But the basic design of the car is spot on, but you need to use an actual guide pin of correct dimensions to get it to run straight.
    This website Building Slot Car Tracks  goes into more detail on how to make the track so you get a straight run as well
    Regards
    Paul
  • mayermakes
    Haven't seen a real slotcar in person foar at least 20 years.
  • mayermakes
