Project Videos
  • Project Videos
Project Videos
Documents DIY Star Trek Tricorder from Build Inside the Box -- Episode 506
  • Date Created: 29 Jun 2021 9:16 PM Date Created
  • Last Updated Last Updated: 9 Jul 2021 7:24 AM
  • Views 7100 views
  • Likes 10 likes
  • Comments 9 comments
The tricorder is the most ubiquitous scanning tool from Star Trek. Using the parts from the Build inside the box Competition, James builds a Baldcorder. Inspired by the tricorder’s design, his device can measure light levels and temperature. And it includes blinky LEDs (NeoPixels) so you can see it scanning. For build files and brief instructions, check the community page for details.
To be clear, “Shades of Grey” is not anyone’s favorite TNG episode. This is why we wanted to make sure we included never-seen-before content in this build. So even if you already watched the 500th episode, there are new segments and details on how the Baldcorder build went.
Attached to this document are the same STL files used in the build. Please don’t leave your printer unattended when printing the body pieces. My printer failed about one-third of the time I tried to build it.
A version of the vinyl decals is attached for reference. The layers and colors are set up so that the red lines should be a cut line on a vinyl (or laser?) cutter.
All of the Arduino code should compile with 1.8.x version of the IDE. You’ll need to install Arduino MKR ZERO support in the board manager. The “acknowledgements.md” file has links to the libraries you need as well.
Attached is a snapshot of the code when I finished the project. Below is a link to the Github repo, which might be newer.
Live Stream Links:
While this video is only about 20 minutes, at least 40 hours went into building the Baldcorder. Below is a list of links to all of the live streams where I worked on the project, by subject. (Initial CAD designs, the decal design, painting tests, final painting, 3d printing, and final assembly were all done “off-line.”)
  • Part 1: VL53L0X Proximity Sensor Testing
  • Part 2: Photo Interruptor for Serial Communication
  • Part 3: Amplifying the DAC output with an Op-Amp (for Audio)
  • CAD Design in Fusion 360 Part 1
  • CAD Design in Fusion 360 Part 2
  • Part 5: Light sensing and cap touch
  • Part 6: New Arduino Code Base
  • Part 7: Finalizing code features
  • Part 8: Moving circuits to protoboards
  • Part 9: Power Supply testing (and problems)
  • Part 10: Near-final assembly
Supplemental Content:
  • Episode 500:  Build Inside The Box Challenge!
  • Build Inside The Box - Sump Pump Alarm
  • Build Inside The Box - Member Projects!
  • Build Inside the Box Member Challenge - WINNERS!
Bill of Material:
Product Name Manufacturer Quantity Buy Now
Arduino MKR Zero Arduino 1 Buy Now
Multicomp Pro USB Bank Multicomp Pro 1 Buy Now
WAGO Pluggable Terminal Block WAGO 1 Buy Now
MCP604 Op Amp Microchip 1 Buy Now
Phototransistor Vishay 1 Buy Now
OLED Display MIDAS 1 Buy Now
Analog Temperature Sensor Microchip 1 Buy Now
TOF Range/Proximity Sensor ST Micro 1 Buy Now
NeoPixel Stick Adafruit 1 Buy Now
Additional Parts:
Product Name
Adafruit Quarter Perma-Board
Speaker
baldcorder design files.zip
element14 presents
element14 presents  |  About James |  Workbench Wednesdays
  • vishay
  • light sensor hack
  • measuring temperature
  • microchip
  • baldengineer
  • neopixels
  • e14p_JBE
  • e14presents_baldengineer
  • operational amplifier
  • st micro
  • james
  • multicomp
  • adafruit
  • build inside the box
  • midas
  • wago
  • friday_release
  • tricorder
  • baldengineer
    baldengineer over 5 years ago +4
    Long time element14 fans might recognize "Spock" in this episode. He is played by Max, who produced element14 video content since the Ben Heck days. He came up with the idea to do a Star Trek intro and…
  • javagoza
    javagoza over 5 years ago +2
    Live Streaming during deadline development is the craziest idea in the world. Respect, I would not be able. What madness! Please continue to do so if you are still healthy after this stressful experience…
  • baldengineer
    baldengineer over 5 years ago in reply to javagoza +2
    Streaming a project with a deadline is a mixed bag. The advantage is that it forced me to set smaller achievable goals (what can I get done in 3-4 hours, today?) and provided a lot of extra coverage (more…
    dougw over 3 years ago
    Cool. Any trekkie would be jealous.
  • baldengineer
    baldengineer over 5 years ago in reply to kgoon
    I designed it from scratch.
  • kgoon
    kgoon over 5 years ago
    Great Project! Where did you get the stl or Cad for the hinge with wire pass through?
  • baldengineer
    baldengineer over 5 years ago in reply to kmikemoo
    All credit goes to maxolmsted for the intro. He had a brilliant idea and wrote the lines.
  • kmikemoo
    kmikemoo over 5 years ago
    baldengineer  LOVED the intro!!!  Loved the build also, but the intro was amazing. imageimageimage
  • baldengineer
    Streaming a project with a deadline is a mixed bag. The advantage is that it forced me to set smaller achievable goals (what can I get done in 3-4 hours, today?) and provided a lot of extra coverage (more shots of the process.) The downside is keeping a project interesting for 20, 30, or 40 hours. I definitely would not recommend it for someone new to streaming!
    Fortunately, this one had enough challenges that I could keep it pretty fresh.
    That said, the segment in the video where I turned-on the assembled baldcorder for the first time, that was 100% real. I was incredibly nervous about turning it on. I knew if anything catastrophic would happen, it would happen then and that I'd be in serious time trouble.
    For that reason, I decided to record it off-line because I didn't want the stress of dealing with an audience if I had to go into panic mode. image
    All-in-all it was a fun experience. Competing with Clem and Katie, keeping engaged with an audience while I did it, and getting to make a video with Spock-Max made it a very special project for me.
  • baldengineer
    Long time element14 fans might recognize "Spock" in this episode. He is played by Max, who produced element14 video content since the Ben Heck days. He came up with the idea to do a Star Trek intro and I was super excited to help make it happen.
    As you might imagine, we shot our parts separate from each other. So there was a short period where I wasn't sure how the final skit would turn out. When he sent me the first draft edit, I enjoyed his performance so much, I forgot to watch the rest of the episode. image
    Of all the projects he and I worked on together, this one was lightyears ahead of the others in terms of fun.
    I hope everyone else enjoys it as well!
    DAB over 5 years ago
    Great build.
  • javagoza
    Live Streaming during deadline development is the craziest idea in the world. Respect, I would not be able. What madness! Please continue to do so if you are still healthy after this stressful experience.
