Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi AI Tracking Eye of Sauron - AI AL Barad Dur - Episode 665
  • Author Author: e14phil
  • Date Created: 16 May 2025 8:51 AM Date Created
  • Last Updated Last Updated: 19 Mar 2026 5:15 PM
  • Views 4326 views
  • Likes 9 likes
  • Comments 13 comments
Welcome back to element14 presents! In this exciting episode, Lorraine takes on the challenge of making the Eye of Sauron move using LEGO, Raspberry Pi, and machine learning. If you're a fan of intricate builds and innovative tech projects, this is one episode you won't want to miss.
The Inspiration Behind the Project
Lorraine has been away for a while, focusing on completing her PhD thesis. To celebrate her achievement, her supervisors, colleagues, friends, and husband gifted her a massive LEGO kit with 10,000 pieces. Over the Christmas holidays, Lorraine built the Eye of Sauron, a project that combines her love for LEGO and her passion for technology.
Congratulations to Dr. Lorraine Underwood from our team and the whole community.
The Plan: Making the Eye Move
The Eye of Sauron is known for its fiery appearance in the movies, and Lorraine's LEGO version includes a red light block to give it a glowing effect.
But Lorraine wanted to take it a step further by making the eye move. The goal is to add more LEGO bricks to enable the eye to tilt left and right, and up and down, creating the illusion that it's following people across the room.
Adding Machine Learning to the Mix
To achieve this, Lorraine plans to integrate a camera into the structure that can detect faces using machine learning. The camera will lock onto a face and move the eye to follow that person around the room. This adds a layer of interactivity and realism to the project, making it even more impressive.
Challenges and Solutions
One of the challenges Lorraine faces is hiding the camera within the LEGO structure without drilling or gluing the pieces, which are considered sins in the LEGO community. She explores different options for mounting the servos and ensuring the eye can move freely without hitting any obstacles.
Building the Structure
Lorraine starts by soldering the servo board and configuring the Raspberry Pi to control the servos. She tests different libraries for pose detection and object detection to find the best one for her project. After some trial and error, she settles on a solution that works well for detecting body coordinates.
Integrating the Camera and Servos
With the top of the tower modified to allow better movement, Lorraine carefully feeds the camera through the structure, ensuring it remains hidden. She uses double-sided tape and a custom 3D-printed holder to secure the servos and Raspberry Pi in place. The servos are programmed to move the eye based on the coordinates detected by the camera.
Final Adjustments and Testing
Lorraine makes final adjustments to the structure, ensuring everything is securely in place. She calibrates the servos through code, setting the default positions and testing the movement in different directions. The eye successfully follows a person around the room, creating a subtle yet impressive effect.
This project showcases Lorraine's skills in 3D printing, Python programming, and camera integration, all while maintaining the integrity of the LEGO build. The Eye of Sauron now not only glows but also follows people around the room, thanks to the clever use of machine learning and servos.
Supporting Files and Links
  • Supporting Code
Join the Conversation
What do you think of this project? How would you have approached it differently?
Bill of Materials
Part Manufacturer Quantity Buy KitBuy Kit
MULTICOMP PRO Raspberry Pi 5 Starter Kit, 8GB, micro SD 16GB, Case with Fan, HDMI Cable, PSU 5.1V/5.0A UK Plug
Multicomp Pro 1 Buy Now
DFROBOT Servo Motor, Micro, 6 V, 0.17 N-m
DFROBOT 2 Buy Now
RASPBERRY-PI Raspberry Pi AI Camera, 12MP, IMX500 Intelligent Vision Sensor, Raspberry Pi Neural Network Model RASPBERRY-PI 1 Buy Now
ADAFRUIT Raspberry Pi PWM Servo Hat Development Board ADAFRUIT 1 Buy Now
Additional Parts:
Product Name Quantity
LEGO Barad Dur
1
Paper clips
1
  • servo motor
  • LEGO
  • python
  • e14p_LU
  • raspberry pi project
  • Face Detection
  • Raspberry Pi AI Tracking Eye of Sauron
  • machine learning
  • rpi
  • ai camera
  • Eye of Sauron
  • friday_release
  • AI AL Barad Dur
  • jeffronicus
    jeffronicus over 1 year ago
    I like the final result, but aren't the AI camera and the Pi an overpowered combination if you're only using the camera for tracking and not recognition?
    beacon_dave over 1 year ago
    I think a couple of these links may relate to episode 641 Moon Phase Display Waning gibbous moonLast quarter moonWaning crescent moonNew moon image
    DAB over 1 year ago
    Great build.
    You could change out the servo with a motor and use flexible wire to the eye.
    That way you get a smoother pull motion for both left and right movement.
  • ralphjy
    ralphjy over 1 year ago
    Congratulations on your PhD.  I wasn’t familiar with the term “Physical Computing “.   Great demonstration of it.
    Just wondering where you got the 10,000 pieces count from ?
    Was it a 'two for the price of one' sort of deal ? Slight smile
    Pieces ≠ Item #  Slight smile
    dougw over 1 year ago in reply to dougw
    Can't edit. Another idea is just twist 2 paperclips together, or perhaps use a length of small pipe cleaner - already twisted.
    beacon_dave over 1 year ago in reply to beacon_dave
    Typo (can't edit) - the front view is rotated by 90° and not the rear as indicated.
    The R/C aircraft world might be worth a look for appropriate wire/tube, as it is often used for push rods to connect servos to movable wing surfaces.
    They also tend to have wire bending tools to put offsets into the rods and various rod ends and couplings for smooth operation.
    There are possibly enough separate translucent bricks to add small LEDs per brick to get them to illuminate separately
    rear view (rotated 90°):
    front view:
    The Lord of the Rings: Barad-dûrTm (3/3) 79.58MB (PDF)
    Might take a bit of experimentation to light a brick optimally e.g. surface mount to the rear or drill and insert into the centre of the brick. Edges could be blacked out before assembly so as to reduce brick-to-brick light spill or left as is to allow bleed for a smoother blend.
    A small LCD display could really animate the shape of the vertical pupil in the centre (and colour) and allow for more realistic fire effects but need to have a smooth transition from LCD back to LEGO. Perhaps have it mounted behind a thin layer of clear material to soften the effect and keep the front flush with the four genuine LEGO parts (highlighted in green) bonded to the front of it to bring it back to the world of Lego.
    Looks like you can get spares so no need to modify the original parts if you want to revert.
    Could you perhaps redo the eye and use a round display in the centre of a translucent resin 3D print with additional embedded RGB LEDs around the outside to create an animated flaming eye with reactive pupil ?
