Project Videos
  • Project Videos
Project Videos
Documents Raspberry Pi Auto Etch A Sketch™︎ -- Episode 372
  • Author Author: kellyhensen
  • Date Created: 20 Nov 2018 7:52 PM Date Created
  • Last Updated Last Updated: 14 Dec 2018 8:24 AM
  • Views 4921 views
  • Comments 17 comments
Raspberry Pi Auto Etch A SketchTm
element14 presents  |  daftmike's VCP Profile  |  Project Videos
In this video Mike builds an automatic Etch A SketchTm machine using stepper motors and 3D printed gears.
Bill of Material:
Product NameManufacturerQuantity
Buy Kit
Raspberry Pi 3 Model B+, BCM2837B0 SoC, IoT, PoE, NOOBS Included
RASPBERRY-PI1Buy Now
Raspberry Pi DC Stepper Motor Hat Develo
ADAFRUIT1Buy Now
3D Printer Filament, 1.75 mm, PLA, Red, 1 kgMULTICOMP1Buy Now
Stepper Motor, High Torque, DC, 0.5 N-m, 1.8 A, Two Phase, 1.75 ohm, 3.3 mHNANOTEC1Buy Now
CONTINUOUS ROTATION SERVOADAFRUIT1Buy Now
Arduino Flip Code:
  GY-521 IMU test code for flipping the etch a sketch - daftmike 2018
#include <Wire.h>
#include <Servo.h>
// Servo is attached to pin 5
Servo servo;
const int servoPin = 5;
// Variables used for the IMU readings
long accelX, accelY, accelZ;
float gForceX, gForceY, gForceZ;
long gyroXCali = 0, gyroYCali = 0, gyroZCali = 0;
long gyroXPresent = 0, gyroYPresent = 0, gyroZPresent = 0;
long gyroXPast = 0, gyroYPast = 0, gyroZPast = 0;
float rotX, rotY, rotZ;
float angleX = 0, angleY = 0, angleZ = 0;
long timePast = 0;
long timePresent = 0;
// Variables used to keep track of the 'flip'
bool flipStarted = 0;
bool flipFinished = 0;
int flips = 0;
int servoDir = 90;
// String to hold the serial data from the Pi
String piMsg;
// Speed, angle and number of 'flips'
const int forwardSpeed = 60;
const int backwardSpeed = 180;
const int numFlips = 5;
const int lowAngle = -140;
const int midAngle = -120;
void setup() {
  Serial.begin(9600);  // start the serial port
  Wire.begin();  // start i2c
  setUpMPU();  // start IMU coms
  calibrateGyroValues();
  timePresent = millis();  // time reference for IMU readings
void loop() {
  readAndProcessAccelData();
  readAndProcessGyroData();
  readPi();
void servoFlip() {
  if (servoDir == 90) {
  servo.attach(servoPin);
  servoDir = forwardSpeed;
  servo.write(servoDir);
  Serial.println("flip started, servo moving forward...");
  flipStarted = 1;
  if (flipStarted == 1) {
   if (servoDir == forwardSpeed && angleX < lowAngle && flips < numFlips) {
  servoDir = backwardSpeed;
  Serial.println("servo backward...");
  flips++;
  Serial.print("flip number: ");
  Serial.println(flips);
   if (servoDir == backwardSpeed && angleX > midAngle && flips < numFlips) {
  Serial.println("servo forward...");
  flips++;
   if (servoDir == backwardSpeed && -2 < angleX) {
  Serial.println("turning servo OFF...");
  servo.detach();
  servoDir = 90;
  flips = 0;
  flipStarted = 0;
   delay(2000);
   setUpMPU();
void readPi() {  // read data from the serial port into a string to check for messages
  if (Serial.available()) {
  piMsg = Serial.readString();
   if (piMsg == "flip") {
   servoFlip();
   else if (piMsg == "cali") {
  Serial.println("calibrating gyro values...");
   setUpMPU();
void setUpMPU() {
  // power management
  Wire.beginTransmission(0b1101000);  // Start the communication by using address of MPU
  Wire.write(0x6B);  // Access the power management register
  Wire.write(0b00000000);  // Set sleep = 0
  Wire.endTransmission();  // End the communication
  // configure gyro
  Wire.write(0x1B);  // Access the gyro configuration register
  // configure accelerometer
  Wire.write(0x1C);  // Access the accelerometer configuration register
void calibrateGyroValues() {
  for (int i = 0; i < 5000; i++) {
   getGyroValues();
  gyroXCali = gyroXCali + gyroXPresent;
  gyroYCali = gyroYCali + gyroYPresent;
  gyroZCali = gyroZCali + gyroZPresent;
  gyroXCali = gyroXCali / 5000;
  gyroYCali = gyroYCali / 5000;
  gyroZCali = gyroZCali / 5000;
void readAndProcessAccelData() {
  Wire.write(0x3B);
  Wire.requestFrom(0b1101000, 6);
  while (Wire.available() < 6);
  accelX = Wire.read() << 8 | Wire.read();
  accelY = Wire.read() << 8 | Wire.read();
  accelZ = Wire.read() << 8 | Wire.read();
  processAccelData();
void processAccelData() {
  gForceX = accelX / 16384.0;
  gForceY = accelY / 16384.0;
  gForceZ = accelZ / 16384.0;
void readAndProcessGyroData() {
  gyroXPast = gyroXPresent;  // Assign Present gyro reaging to past gyro reading
  gyroYPast = gyroYPresent;  // Assign Present gyro reaging to past gyro reading
  gyroZPast = gyroZPresent;  // Assign Present gyro reaging to past gyro reading
  timePast = timePresent;  // Assign Present time to past time
  timePresent = millis();  // get the current time in milli seconds, it is the present time
  getGyroValues();  // get gyro readings
  getAngularVelocity();  // get angular velocity
  calculateAngle();  // calculate the angle
void getGyroValues() {
  Wire.write(0x43);  // Access the starting register of gyro readings
  Wire.requestFrom(0b1101000, 6);  // Request for 6 bytes from gyro registers (43 - 48)
  while (Wire.available() < 6);  // Wait untill all 6 bytes are available
  gyroXPresent = Wire.read() << 8 | Wire.read();  // Store first two bytes into gyroXPresent
  gyroYPresent = Wire.read() << 8 | Wire.read();  // Store next two bytes into gyroYPresent
  gyroZPresent = Wire.read() << 8 | Wire.read();  // Store last two bytes into gyroZPresent
void getAngularVelocity() {
  rotX = gyroXPresent / 131.0;
  rotY = gyroYPresent / 131.0;
  rotZ = gyroZPresent / 131.0;
void calculateAngle() {
  // same equation can be written as
  // angleZ = angleZ + ((timePresentZ - timePastZ)*(gyroZPresent + gyroZPast - 2*gyroZCalli)) / (2*1000*131);
  // 1/(1000*2*131) = 0.00000382
  // 1000 --> convert milli seconds into seconds
  // 2 --> comes when calculation area of trapezium
  // substacted the callibated result two times because there are two gyro readings
  angleX = angleX + ((timePresent - timePast) * (gyroXPresent + gyroXPast - 2 * gyroXCali)) * 0.00000382;
  angleY = angleY + ((timePresent - timePast) * (gyroYPresent + gyroYPast - 2 * gyroYCali)) * 0.00000382;
  angleZ = angleZ + ((timePresent - timePast) * (gyroZPresent + gyroZPast - 2 * gyroZCali)) * 0.00000382;
void printData() {
  Serial.print("X : ");
  Serial.print(angleX);
  Serial.print("° | Y : ");
  Serial.print(angleY);
  Serial.print("° | Z : ");
  Serial.print(angleZ); Serial.println("°");
Supporting Files:
Click Here for access to all the supporting files you will need to replicate this build!
Auto-Etch-A-Sketch-master.zip
  • episode 372: raspberry pi auto etch a sketch™
  • raspberri pi
  • friday_release
  • e14presents_daftmike
  • Sean_Miller
    Sean_Miller over 7 years ago +4
    Great use of joints in Autodesk Fusion. That is a critical skill to master. It allows one's prints to do what you want with the first printed part attempt - preventing hours of rework. Surprisingly low…
    DAB over 7 years ago +3
    Nice build. I recently saw another post where someone used a CNC cad program to drive the stepper motors to do a similar task with the etchasketch. Adding the self erase feature was a good modification…
  • mayermakes
    mayermakes over 7 years ago +2
    Compliment on the stunnign print quality of your 3d printed parts, and awesome build!!
  • cgz
    cgz over 7 years ago
    Nice Job Mike!
    So can you please tell us what 3D printer you used in your setup? You should also maybe list what tools you used to make the project. E.g, software, hardware etc.. You know like Fusion3D, and a XX 3D printer. Should be listed somewhere. Just some feedback!
    P.S. I miss Ben, but I continue to watch this channel to stay loyal image
  • cgz
    Nice Job Mike!
