Project Videos
  • Project Videos
Project Videos
Documents Arduino Unit Conversion Calculator -- Episode 455
  • Date Created: 14 Jul 2020 4:45 PM Date Created
  • Last Updated Last Updated: 17 Jul 2020 7:24 AM
  • Views 7349 views
  • Comments 15 comments
As a maker I convert units all the time, fractional to metric, tenths to metric, MPH to KPH etc. In this video I build a dedicated desktop calculator that can do all of my conversion at the twist of a knob and the punch of a few keys. I will be using the Arduino UNO, a rotary encoder, an LCD character display and a bunch of Cherry MX switches to build this. It is designed in a way that it can be easily replicated and built at home.  New conversions are easily added with a software update!
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Bill of Materials
Rotary Encoder, Mechanical, Incremental, 24 PPR, 24 Detents, Vertical, With Momentary Push Switch BOURNS 1 Buy Now
Small Signal Diode, Single, 100 V, 200 mA, 1 V, 4 ns, 1 A ON SEMICONDUCTOR 20 Buy Now
Arduino Uno SMD, ATmega328 MCU, 54 3.3V I/O, 16 Analogue Inputs, 4 UARTs ARDUINO 1 Buy Now
USB Cable, Type A Plug to Type B Plug, 1.8 m, 6 ft, USB 2.0, Black QUALTEK ELECTRONICS 1 Buy Now
Additional Parts:
Product Name
Cherry MX Brown, No Diode, No LED x20
Tactile Switch x2
20x4 2004 LCD Display Module with I2C x1
Kaleb Clark - Kaleb_008-STL-Files.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • arduino uno
  • diy
  • unit conversion
  • metric
  • rotary encoder
  • desktop
  • tool
  • on semiconductor
  • bourns
  • e14p_KC
  • fractional
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to celcius1 +2
    Hi Paul, Thanks! The power source should not be a problem, it was just that specific one. If I plug it into my computer (which I do for powering it on my desk), it works fine. A portable version would…
  • celcius1
    celcius1 over 6 years ago +1
    Hi Kaleb, Loved the project, but to avoid finding a compatible USB power source, why did you not try using a AA battery pack like this https://www.jaycar.com.au/4-x-aa-side-by-side-end-to-end-battery-holder…
    DAB over 6 years ago +1
    Nice build. DAB
  • absurdasparagus
    absurdasparagus over 5 years ago
    hey im new to all this. i cant get the encoder to work. any one know a video i can watch to learn how the encoder library works?
  • gomer1
    gomer1 over 6 years ago
    is there a schematic for this.
    ron
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to mr_widget
    Good suggestion with mils, I will keep that one in mind!
    -Kaleb
  • mr_widget
    mr_widget over 6 years ago
    While on the subject of thermistors, I wanted to know with precision what the non-linearity of response certain well-known pcb through-hole thermistors are.
    I did this with an Arduino Uno prior to developing my mixed-signal standard module:
  • mr_widget
    For additional coversion I would like to have are obvious for a PCB hacker like me: Mils to mm and obverse.  I read a metric buttload of datasheets and drawings that have the "wrong" pcb layout geometry in the packaging specs, while I use Eagle for most of my work, and house rules that all dimensions on the pcb be in mils for spacing things like differential pair signal lines etc.
    J.R. Stoner
  • mr_widget
    I did create a more modular approach to handling a rotary encoder (with a debounce logic for the press-on switch built in to many encoders).
    The URL for a project description is here:
    https://bifrost-group.com/ee-times-designline-blog-article
    Maybe if you want to simplify the Arduino code a bit so you don't have software real-time artifacts to contend with, this may be worth taking a look at.
    One of my personal projects that includes this device (plus a thermistor temp sensor to leverage the mixed-signal features of the Silego/Dialog part) is a standard component for many of my larger projects that has a SPI breakout, for either a PCB mounted encoder, or a panel-mounted encoder separate from the breakout.
    J.R. Stoner
  • eliminster
    eliminster over 6 years ago in reply to KalebTheMaker
    Absolutely my friend!
    I am however not going to print the button caps, as I have never been able to get them to look/feel like I want anyway. I have a friend of mine that said for me to try 3D resin printing them, but I don’t have one and never even touched one before. What are your thoughts?
    - Keven
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to eliminster
    Thanks Keven!
    If you do build one, please share some pictures here, and feel free to ask questions. I would love to see it
    -Kaleb.
  • eliminster
    Kaleb,
    I have to say, this is one of the coolest projects! I can’t wait to build this and stick it on my desk.
    -Keven
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to DAB
    As always, Thanks DAB!
    -Kaleb
