Project Videos
  • Project Videos
Project Videos
Documents Arduino Unit Conversion Calculator -- Episode 455
  • Date Created: 14 Jul 2020 4:45 PM Date Created
  • Last Updated Last Updated: 17 Jul 2020 7:24 AM
  • Views 7323 views
  • Comments 15 comments
As a maker I convert units all the time, fractional to metric, tenths to metric, MPH to KPH etc. In this video I build a dedicated desktop calculator that can do all of my conversion at the twist of a knob and the punch of a few keys. I will be using the Arduino UNO, a rotary encoder, an LCD character display and a bunch of Cherry MX switches to build this. It is designed in a way that it can be easily replicated and built at home.  New conversions are easily added with a software update!
Supplemental Content:
  • Download Code from Github
  • View Model and download 3d Cad files
Bill of Materials
Rotary Encoder, Mechanical, Incremental, 24 PPR, 24 Detents, Vertical, With Momentary Push Switch BOURNS 1 Buy Now
Small Signal Diode, Single, 100 V, 200 mA, 1 V, 4 ns, 1 A ON SEMICONDUCTOR 20 Buy Now
Arduino Uno SMD, ATmega328 MCU, 54 3.3V I/O, 16 Analogue Inputs, 4 UARTs ARDUINO 1 Buy Now
USB Cable, Type A Plug to Type B Plug, 1.8 m, 6 ft, USB 2.0, Black QUALTEK ELECTRONICS 1 Buy Now
Additional Parts:
Product Name
Cherry MX Brown, No Diode, No LED x20
Tactile Switch x2
20x4 2004 LCD Display Module with I2C x1
Kaleb Clark - Kaleb_008-STL-Files.zip
element14 presents  |  About Kaleb |  Project Videos
  • kaleb
  • e14presents_kalebclark
  • arduino uno
  • diy
  • unit conversion
  • metric
  • rotary encoder
  • desktop
  • tool
  • on semiconductor
  • bourns
  • e14p_KC
  • fractional
  • friday_release
  • KalebTheMaker
    KalebTheMaker over 6 years ago in reply to celcius1 +2
    Hi Paul, Thanks! The power source should not be a problem, it was just that specific one. If I plug it into my computer (which I do for powering it on my desk), it works fine. A portable version would…
  • celcius1
    celcius1 over 6 years ago +1
    Hi Kaleb, Loved the project, but to avoid finding a compatible USB power source, why did you not try using a AA battery pack like this https://www.jaycar.com.au/4-x-aa-side-by-side-end-to-end-battery-holder…
    DAB over 6 years ago +1
    Nice build. DAB
  • celcius1
    Hi Kaleb,
    Loved the project, but to avoid finding a compatible USB power source, why did you not try using a AA battery pack like this https://www.jaycar.com.au/4-x-aa-side-by-side-end-to-end-battery-holder/p/PH9204  to keep it portable.
    I assume the current draw would be low enough to utilise a simple Alkaline Battery Pack.
    Regards
    Paul
  • KalebTheMaker
    Hi Paul, Thanks!
    A portable version would be a great update to this! The case would have to be modified to accomodate the battery pack, but it could Alkaline batteries, or even a small LiPo with a boost converter.
  • KalebTheMaker
    Hi Paul, Thanks!
  • celcius1
    celcius1 over 6 years ago in reply to KalebTheMaker
    Hi Kaleb,
    i’d say it would be best to stick with AA batteries as it would be more consistent with the calculator theme of the project IMHO. And a 6v AA pack keeps things simple and less headaches.
    Are the f3d files available If I wanted to make changes to the fusion project? As I work in Fusion 360.
    Regards
    Paul
  • KalebTheMaker
    They sure are. Under "Supplemental Content" above, is a link to the Fusion 360 web portal thing. You can download F360 archive or many other types of 3d files.
    -Kaleb
