sudo Sergeant
  • sudo Sergeant
sudo Sergeant
Documents sudo Sergeant 06: File Permissions
Join sudo Sergeant to participate - click to join for free!
  • Date Created: 9 Oct 2017 9:41 PM Date Created
  • Last Updated Last Updated: 18 Jan 2019 4:11 PM
  • Views 2425 views
  • Comments 7 comments
element14's The Ben Heck Show
sudo Sergeant
Featured Bonus Content
See All Episodes
Felix discusses how file permissions work with Linux. He covers what they mean, what they’re for, and how to set them. You’ll learn to use command line to create a file and decipher user, group, and others rights. You can then add or remove permissions by CHMOD or by permission bits in octal notation.
File permissions are the most basic form of security control on a Linux based operating system. They are implemented in a manner which can be configured to grant or deny access to files. The permissions can be modified by either the one who owns the file, or the super user.  The instruction to modify the permissions can take numeric arguments or symbolic arguments.
Felix uses a command line example to show you how to see the permissions of a file: Typing “ls” shows you the root directory structure.
sergeant@raspberrypi: ~ $ ls
Desktop   Documents   Downloads Music   Pictures  Public  Templates test  Videos
He wants to go the test directory so he types the command cd test. Typing ls again shows that this directory has two directories that were previously mounted.
sergeant@raspberrypi: ~ $ cd test
mount0  mount 1
Next he creates a files using command line using the touch command followed by the file he is creating and uses the ls command to verify the file was created:
sergeant@raspberrypi: ~/test  $  touch testfile.text
sergeant@raspberrypi: ~/test  $ ls
mount0 mount1 testfile.txt
To find the file permissions of this newly created file he types in ls -l:
sergeant@raspberrypi: ~/test  $ ls -l
total 8
drwxr-xr-x 2 sergeant sergeant 4096 Aug 25 13:40 mount0
drwxr-xr-x 2 sergeant sergeant 4096 Aug 25 13:40 mount1
- rw-r-- r-- 1  sergeant sergeant       0 Aug 30 09:46 testfile.txt
For testfile.txt the information to left of the number 1 are the file permissions. The first bit in the file permissions is the file type, the next 3 are the permissions of the owner,  the following three bits are the permissions of the group, and the last three are the permissions of anybody who is either not in the group or not the owner.  The last bit is a single character that specifies alternate access methods.image
For instance, if you see "drwxr" it means that the file type is director, the r means that the owner can read the directory, the w means the owner can write to the directory,  and x means the owner can execute the directory (since it's a directory it doesn't really get executed). The next 3 bits are the group rights. For testfile.txt, "r--" means that the group can read this but cannot write or execute.
There are two ways to modify the file permissions.  They can either be done through numeric method or via a character method. With the character method, you would change the file permissions by sending the instruction chmod (change modify).  Felix suggests expanding the help anytime you have an instruction. After, using the  command "--help" Felix decides to give execution permissions to the user for the file by typing in the following command:
In this example, read and write are turned off execute is turned on:
sergeant@raspberrypi: ~/test  $ chmod u=+x testfile.txt
total 8
---xr-- r-- 1  sergeant sergeant       0 Aug 30 09:46 testfile.txt
In this example, read and write are added along with execute:
sergeant@raspberrypi: ~/test  $ chmod u=+rwx testfile.txt
total 8
-rwxr-- r-- 1  sergeant sergeant       0 Aug 30 09:46 testfile.txt
To give those same permissions to the group simply use the following command:image
sergeant@raspberrypi: ~/test  $ chmod g=+rwx testfile.txt
total 8
-rwxrwxr-- 1  sergeant sergeant       0 Aug 30 09:46 testfile.txt
To give those permissions to others you would use the following command:
sergeant@raspberrypi: ~/test  $ chmod o=+rwx testfile.txt
total 8
-rwxrwxrwx 1  sergeant sergeant       0 Aug 30 09:46 testfile.txt
To take away group permissions you would use the minus sign instead of the plus sign:
sergeant@raspberrypi: ~/test  $ chmod g=-rwx testfile.txt
total 8
-rwx---rwx 1  sergeant sergeant       0 Aug 30 09:46 testfile.txt
This is covers adding and removing permissions using the character method.  To change permissions via the numeric method you can head over to  Unix Permissions and Lookup . Select your permissions bits. We're focusing on user, group, and others.If you want to have read write execute for user group and others you would select those permissions on the page.image
sergeant@raspberrypi: ~/test $ chmod 777 testfile.txt
sergeant@raspberrypi: ~/test $ ls -l testfile.txt
-rwxrwxrwx 1 sergeant sergeant 0 Aug 30 9:46 testfile.txt
Trying again with a different numeric value changes the file permissions:
sergeant@raspberrypi: ~/test $ chmod 700 testfile.txt
-rwx------ 1 sergeant sergeant 0 Aug 30 9:46 testfile.txt
  • numeric method
  • sudo sergeant
  • octal notation
  • file permissions
  • rpibeginner
  • character method
  • chmod
  • rpiexpert
  • command line
  • permission bits
  • sudosergeant
  • linux
  • tariq.ahmad
    tariq.ahmad over 9 years ago in reply to jackwhite+ +1
    I am by no means a Linux expert but I do have previous professional experience maintaining Linux servers, modifying file permissions on PHP files (usually through FTP but I have used command line), and…
    shabaz over 9 years ago in reply to tariq.ahmad +1
    tariq.ahmad wrote: Changing file permissions can be tricky for people maintaining Linux servers for business or in another field. This is definitely true.. I've a formal qualification in one of the UNIX…
  • tariq.ahmad
    tariq.ahmad over 9 years ago in reply to koudelad +1
    Thanks koudelad ! This has been fixed!
  • koudelad
    koudelad over 9 years ago
    There is a link to sudo Sergeant episode 05 video, instead of episode 06.
  • tariq.ahmad
    Thanks koudelad !
  • tariq.ahmad
    Thanks koudelad !
