The Learning Circuit
  • The Learning Circuit
Documents Series & Parallel Circuits -- The Learning Circuit 02
  • Date Created: 28 Nov 2017 9:34 PM Date Created
  • Last Updated Last Updated: 29 Nov 2017 8:24 AM
  • Views 5791 views
  • Likes 9 likes
  • Comments 12 comments
element14's The Ben Heck Show
Join Karen as she shares her enthusiasm for teaching STEM subjects, gives you what you need to know to get started on electronics projects, and more.
sudo Sergeant
See All Episodes
In a previous episode, Karen made a simple circuit using some common everyday items.  Now she’ll demonstrate the difference between parallel and series circuits by adding additional voltage and another bulb to her simple circuit.  She’ll also cover the difference between stranded and solid wire and use a multimeter to demonstrate the difference in how voltage is distributed in a parallel and series circuit.
Make Your Own!
Parts & Products:
Product Name
Part Link
Hookup Wire - Red, 22 AWG, 25ft, solidBuy NowBuy Now
Hookup Wire - Black, 22 AWG, 25ft, solidBuy NowBuy Now
2 AA Battery HolderBuy NowBuy Now
AA Batteries (4pk)Buy NowBuy Now
Lamp Holder (10pk)Buy NowBuy Now
2.47V Miniature Screw Incandescent Lamp Bulbs (10pk) Buy NowBuy Now
Tenma Digital MultimeterBuy NowBuy Now
Additional Materials
Product Name
Metal Paper Clips
Brass Paper Fasteners
Cardboard
Download the Introduction to Circuits featuring Karen in eBooks!
Simple circuits such as the ones Karen demonstrates are an easy way to learn about the difference between simple and parallel circuits. In a Series Circuit, all components are connected end-to-end to form a single path for electrons to flow.  In a Parallel circuit, all components are connected across each other to form two sets of electrically common points.
Another consideration you’ll need to understand when getting started with electronics projects is your choice between using stranded or solid wires.  Both types of wiring are effective means of transmitting electricity, however, a stranded wire is more efficient in sending the electrons through your circuit.  It’s also better suited for more intricate usages such electronic devices and circuit board where it offers the flexibility to be bent or twisted to connect electronic components.  Solid wire is frequently used for outdoor or rugged applications where wire may be exposed to corrosive elements, adverse weather conditions, or frequent movement. It’s also a good choice for smaller projects where the flexibility of stranded wire makes it difficult to use.
Karen uses solid wire to demonstrate the difference between series and parallel circuits because it’s stiff and stays attached better.  In electronics, a node refers to any point on a circuit where two or more circuit elements meet. In a schematic, the node will be the wires between the components.  In a circuit the current flows from high voltage to a lower voltage. The current flows through every path it can take to the point of lowest voltage (commonly referred to as ground).  Two components are said to be in series if they share a common node and the same current flows through them.  If the components share two common nodes then they are said to be in parallel.
What other basic electronic concepts would you like to learn about?
Let us know in the comments below!
  • learn electronics
  • parallel circuit
  • the learning center
  • e14presents_makerkaren
  • passive_featured
  • nodes
  • theheckwithkaren
  • starter projects
  • serial circuit
  • battery
  • voltage
  • schematic
  • stem projects
  • thelearningcircuit
    DAB over 8 years ago +2
    Nice episode Karen. One slight slip at the end. The parallel lights get the same voltage, not necessarily the same power from the batteries. You might want to add a quick view of Kirchoff's Law as you…
  • Sean_Miller
    Sean_Miller over 8 years ago +1
    Yep...like they say, Complex is easy, Simple is hard! Funny story...my boy and I started adlibbing our (embarrassingly small) channel recently to be more casual in our videos. After putting 5 hours into…
  • Sean_Miller
    I'll definitely take a look and feed back. Your last video had a lot of positive comments - that's a good sign for the style of delivery, although definitely not the only metric to watch. For our channel…
    DAB over 6 years ago in reply to sebastiantt
    Back in the old days, we used the parallel port for printers because they were locate close enough to the computer to have a short cable length.
    When you have devices further apart, you use a serial circuit.
    A good example is wifi. You never find a wifi implementation using parallel channels. Everything is a single serial channel. It keeps the circuit simple, but you sacrifice bandwidth and data rates.
  • sebastiantt
    sebastiantt over 6 years ago
    My question is where i use serial or paralle circutes, give an exaple for that : sorry for my bad english image
    DAB over 6 years ago in reply to osceola
    It all depends upon the application.
    Ideally, you can transfer more data in shorter time, which in a good remote application means you can power up, send the data and power down faster, but parallel transfer can only occur over short distances.
    In a serial system, you send the data slower one bit at a time, so your overall CPU would have to be on longer to send and receive messages over longer distances.
    If you are worried about the power usage, you would need to run some analysis to see if the frequency of data transfer changes the power usage profile.
  • osceola
    osceola over 6 years ago
    While there is a lot of commentary on voltage and power, do the batteries lose power faster in the parallel circuit?  Or asked another way, do they expend (more) power per unit time -- do they wear out faster?
  • magiotcz
    magiotcz over 7 years ago
    Thanks for all beginners image
  • raffy8xx8
    raffy8xx8 over 8 years ago
    Please include to the lesson the logic circuit with demo.
    From simple to multiple combination logic.
    Thanks
  • Sean_Miller
    Your last video had a lot of positive comments - that's a good sign for the style of delivery, although definitely not the only metric to watch.  For our channel, I'm just happy to get comments, even the one's that say "cringe" in all caps.  image  Dave Jones (EEVLog) gave my boy a comment last week which felt like an autograph, so that made up for all those "cringe" comments.
    Viewer Comments remind me of a story from Jeff Gordon, the NASCAR racer.  Just before a race, during driver introductions, he and Dale Earnhardt, Sr. were circling the track in the back of a truck waiving to fans.  No one knew Jeff, yet.  The crowd was loudly booing Dale which was typical back then due to his "Intimidator" personality.  Dale leaned to Jeff and said, "It's when they are quiet that you have to worry."
    See ya',
    Sean
  • makerkaren
    makerkaren over 8 years ago in reply to Sean_Miller
    The next TLC to come out is much less scripted. It's more project than concept based though, so that helps as I'm less trying to keep all the intricate details straight. I would be curious to see what you think of the difference in style, given your experience in making your own videos.
  • Sean_Miller
    Funny story...my boy and I started adlibbing our (embarrassingly small) channel recently to be more casual in our videos.  After putting 5 hours into filming, editing, and publishing to YouTube, I finally tuned in to me referring to LEDS as "lightbulbs" throughout the whole thing.  So, somehow, I need to find the middle ground to keep me from being scripted, but still being accurate.
    Look forward to Friday.
    See ya',
    Sean
  • makerkaren
    That's a very good point, Sean. Thank you. I've worked with kids a lot and I struggle to explain basic concepts in a simple manner with terms that don't seem too foreign or overwhelming. I often use "power" as a lazy out, which obviously is a terrible idea since it has a specific meaning once you get past the very basics. I get stuck in a chicken and egg loop in that I want to use the correct terminology, but to do that, I have to take the time to explain what all of it means and then I fall down a well of tangents. Thanks for the feedback! I'm still working on a good path of explaining basics in small, bite-sized pieces that are factually accurate, but simple to understand without having to explain EVERYTHING at once.
