The Learning Circuit
  • The Learning Circuit
Documents Making Logic Gates From Discrete Components -- The Learning Circuit 51
  • Author Author: rjena
  • Date Created: 23 Jul 2019 3:05 PM Date Created
  • Last Updated Last Updated: 24 Jul 2019 7:24 AM
  • Views 8276 views
  • Likes 9 likes
  • Comments 14 comments
The Learning Circuit | element14 presents |  Project Videos | VCP Biography: Karen
In the previous lesson, Karen explained the logic behind AND, NAND, OR, NOR, NOT, XOR, and XNOR logic gates. In that episode, we also learned that logic gates are typically contained in IC chips, with multiple gates within each chip. For this episode’s project, Karen has decided to throw out the ICs, and instead, use transistors to create each logic gate, further demonstrating how the logic of each gate type works. Follow along to continue the journey of understanding logic gates through the use of transistors. Solder along and you’ll end up with a tidy little project contained within a couple of Altoid tins! In the end, Karen dares you to try your hand at creating the more complicated XOR and XNOR gates out of transistors. Are you up to the challenge?
Bill of Materials
Product NameManufacturerQuantityBuy KitBuy Kit
Prototype Board, 25 x 15 grid, 1.6 mm, 72 mm, 47 mmMulticomp1Buy NowBuy Now
Prototype Board, Phenolic, 30 x 25 grid, 1.6 mm, 94 mm, 71 mmMulticomp1Buy NowBuy Now
Transistor, BC547, NPNMulticomp9Buy NowBuy Now
Hook Up Wire, Blue, 22 AWG, 25 ft, solidNTE ELECTRONICS1Buy NowBuy Now
Resistor Set, 480pcs, 16 x E3 Series Values, 1/4W Through Hole (1kohm, (2) 10kohm)Velleman1Buy NowBuy Now
Tactile Switch, 10mm, Blue, 24 VDC, 50mA, 2.54mmNKK SWITCHES2Buy NowBuy Now
Slide Switch, SPDT, 2.5mm, Through Hole, 6 pinE-SWITCH1Buy NowBuy Now
LED, Red, Through Hole, T-3 (10mm), 20 mA, 1.8 V, 640 nmClear Lens1Buy NowBuy Now
Board-To-Board Connector, 2.54 mm, 4 Contacts, Female-Receptacle, 1 RowsMulticomp10Buy NowBuy Now
Board-To-Board Connector, 2.54 mm, 4 Contacts, Male-Header, 1 RowsMulticomp2Buy NowBuy Now
9V battery snap, flexibleMulticomp1Buy NowBuy Now
Battery, 9 V, PP3, AlkalinePro Elec1Buy NowBuy Now
Additional Parts:
Product Name
Altoid Tins
  • transistor
  • element14 presesents
  • nor
  • e14presents_makerkaren
  • logic gates
  • nand
  • led
  • and
  • inverter
  • not
  • or
    DAB over 7 years ago +4
    Nice episode. When I started learning electronics back in the late 1960's, I purchased some surplus circuit boards that turned out to be Resistor-Transistor Logic (RTL) boards. I learned about logic design…
  • makerkaren
    makerkaren over 7 years ago in reply to ihaag +4
    This is something I found, but did not make myself. Give it a try and let us know how it turns out!
  • makerkaren
    makerkaren over 7 years ago in reply to clem57 +4
    I got the idea for the episode here. https://www.instructables.com/id/Logic-Gates-with-NPN-transistors/ But redrew all the schematics.
  • hdog
    hdog over 4 years ago in reply to dougw
    Thanks.  Leakage was the only reason I could think of.
    dougw over 4 years ago in reply to hdog
    Probably not needed - just ensures leakage current doesn't turn on the LED.
  • hdog
    Just ran across this page.  What function does R4 (4.7K) have in the AND and OR gates?  Seems to just parallel
    the LED.
  • dor2356
    dor2356 over 5 years ago
    That's a really cool episode!
    I'd like to try thinking and building a circuit of 24V OR gate. How would I do it with transistors that way I would keep the output of the circuit still in 24V...?
    Hope you could give me an advice,
    Thanks a lot & I was really enjoyed your video!
    Dor
  • makerkaren
    makerkaren over 5 years ago in reply to jloesel
    That's amazing! Thank you for sharing your project! And also thank you for sharing what you figured out NOT to do. Always helpful to learn from others' mistakes.
  • jloesel
    jloesel over 5 years ago
    Really great material. I really liked the modular design. So much so that I decided to use the idea to make an SR Latch. - Using 2 of the NOR gates.  Just be sure to insert second NOR gate reversed. i.e. The wiring is reverse for one of the NOR gates.  Otherwise, you will short one out very quickly..... and have to build another one.
    Finally, I decided to use the original base design and create a SR Latch component that plugs into the original base component from this tutorial. It was only slightly more complex than the gates in that you had to find space to solder an LED onto the board (which is pretty small already).  But the two builds together make a great demonstration of building an SR Latch from gates as well as directly from transistors.
    Great video and the component way of creating each of these circuits is perfect way to create projects in a school setting.
  • ayama
    ayama over 6 years ago
    great work
    please do keep up the good work and thanks
    dougw over 7 years ago
    Great work.
  • makerkaren
  • clem57
    clem57 over 7 years ago
    So where did you get the schematics for the gates. They really make me think...
    Clem
