The Learning Circuit
  • The Learning Circuit
Documents micro:bit Add-on ZIP Halo LED Ring -- The Learning Circuit 58
  • Date Created: 4 Nov 2019 9:54 PM Date Created
  • Last Updated Last Updated: 4 Nov 2019 8:24 AM
  • Views 2429 views
The Learning Circuit | element14 presents |  micro:bit
In this episode, Karen explores another BBC micro:bit add-on, the ZIP LED Halo. This ZIP Halo has 24 RGB LEDs in a circle that gets attached around the micro:bit so the onboard LED array is still visible and can also be used. Get started programming the Halo as Karen shows how to control individual LEDs, how to change colors, use presets, as well as create your own custom colors, design, and patterns.
Bill of Material:
Product NameManufacturerQuantityBuy KitBuy Kit
BBC micro:bit go + 3V battery holder, USBBBC MICRO:BIT1Buy NowBuy Now
ZIP Halo LED Add-On Pack For micro:bit Inventors KitKitronik1Buy NowBuy Now
ZIP Halo LED Code.zip
  • learning circuit
  • micro:bit led array
  • e14presents_makerkaren
  • microbit
  • stem projects
    DAB over 6 years ago +2
    Another well explained episode. Well done. DAB
  • makerkaren
    makerkaren over 6 years ago in reply to beacon_dave +1
    That is not an option in the block editor. It might be possible if you code in Javascript instead of the block editor, but I'm not sure if it's capable of using HSV values. That would be neat and a lot…
  • clem57
    clem57 over 6 years ago
    Thanks makerkaren. Very enjoyable episode.
    Clem
  • clem57
    Clem
