element14 presents
element14 presents
Documents You can Join the Build Inside the Box Challenge! Here's what's in The Box
  • Author Author: kellyhensen
  • Date Created: 11 Mar 2021 6:05 PM Date Created
  • Last Updated Last Updated: 25 Jun 2021 2:32 PM
  • Views 9495 views
  • Likes 19 likes
  • Comments 69 comments
element14 presents
Build Inside The Box
500th Episode | About the Challenge | Contestants | The Prizes | element14 Vault Giveaway | The Box | Terms & Conditions |  See Brainstorming Call |  Member Challenge Winners | Episode 504
Register for the Twitch live stream to see which one of your favorite vcp projects won! Click on the banner below:
Thanks to the element14 Community for all of the great ideas, while it was difficult, we had to distil all of the recommendations down to what would fit into one box (and fit our challenge).
Now while our contestants get to grips with the parts that were decided for what was to be in the box, you can take part in the competition with the box and to do so, you have the opportunity to win the box yourself!
sponsored by WAGO
Here's what's in THE BOX:
The BOX Buy the Box*Buy the Box*
Arduino MKR Zero
Buy NowBuy Now
MULTICOMP PRO Portable USB High Capacity Power Bank
Buy NowBuy Now
WAGO Pluggable Terminal Block
Buy NowBuy Now
Microchip Op Amp
MICROCHIP MCP604-I/PMCP604-I/P Operational Amplifier
Buy NowBuy Now
Vishay Phototransmitor
VISHAY Phototransistor
Buy NowBuy Now
MIDAS OLED Graphic Display
Buy NowBuy Now
MICROCHIP Temperature Sensor IC
Buy NowBuy Now
ST Microelectronics Gesture Sensor
ST Range/Gesture Sensor 53L0-SATEL-I1
Buy NowBuy Now
Members Contest is closed - Build Inside The Box
The contest criteria: In conjunction with the Build Inside The Box 500 - where our video host contestants will be competing against each other to win prizes for their favourite STEM organisations, we are also hosting a member challenge open to all element14 Community Members.  All you have to do is:
  1. use all of the components in The Box to build a working project
  2. post a blog of how you created that project
  3. include a short video of the project working in your blog
Blogs should be posted in element14 presents space (not in your 'user account' blog space).  Be sure to tag it with 'BuildInsideTheBox' (you can tag content at the end of your blog.)
Meet the Winners for the Members Challenge and watch episode 504.
The top three entries for members who 'Build Inside the Box' (as selected by the video host contestants participating in the Build Inside The Box 500, and also by the element14 Community staff) will each win a $150 shopping cart that you can spend on any of our global online stores.
Project blogs need to be posted before (and no later) than Friday, 7th May 2021 5pm CDT
Go here for full terms and conditions
Register or Login to add a comment below.
  • vishay
  • oled
  • microchip
  • member challenge
  • multicomp pro
  • member competition
  • build_inside_the_box
  • multicomp
  • build inside the box
  • midas
  • wago
  • bitb
  • easyejl
    easyejl over 5 years ago in reply to cstanton +10
    OK then. In 2006 my wife was pregnant with our 3rd child, and had a miscarriage at 19 weeks. We were devasted and it was really hard to keep things together. But we had to, as there were the first two…
  • cstanton
    cstanton over 5 years ago +9
    I can't enter this competition, but I still feel like joining in... > Tell us about a time that you received something you didn't know what to do with, and how you were able to turn that into something…
  • vmate
    vmate over 5 years ago +9
    Well, I don't really have one big story, but I do love turning all kinds of things into something useful. The most notable story that I have is when I received one of those USB TV tuner dongles from a…
  • aspork42
    aspork42 over 5 years ago
    Hi there - is anyone out there having issues getting their screen to work?
    im trying with I2C and it doesn't show up on the bus (3.3 v from the MKR). I noticed the back of my board says 5V Supply so I also tried with a level SHIFTER and putting all signals at 5v. Using the Adafruit library SSD1306.h with SSD1306 drivers.
    Data sheet mentions the other pins, but seems like I shouldn't need them with I2C.
    sneak preview of the breadboard stage...
    • Vote Up +5 Vote Down
  • kmikemoo
    kmikemoo over 5 years ago in reply to aspork42
    aspork42  It's SPI.  I used the Adafruit library, but opted for the hardware SPI instead of the default software SPI.  This left the I2C open for the TOF sensor.  If there's a way to convert it to I2C, I haven't stumbled across it.
  • aspork42
    aspork42 over 5 years ago in reply to kmikemoo
    They are right next to each other in the examples:
    And this is pretty confusingly marked, not with MISO/MOSI/SCLK/CS as normal for SPI. Instead we have SDA and SCL which seem to indicate I2C.
    At any rate, I was able to get it running via SPI as you noted (and 3.3V). Thanks for the response image
  • aspork42
  • easyejl
    easyejl over 5 years ago in reply to aspork42
    I need to start on that part as well. I keep "forgetting" it as it sort of seems like the simplest piece to integrate.
    Have you started your blog? can you add a link for it? interested to see what you're doing with the stepper image
    beacon_dave over 5 years ago in reply to aspork42
    "...And this is pretty confusingly marked, not with MISO/MOSI/SCLK/CS as normal for SPI. Instead we have SDA and SCL which seem to indicate I2C..."
    It looks like the controller used supports both.
    https://www.midasdisplays.com/getmedia/f3485ee8-9e11-41fc-809f-2afd900c2651/SSD1306BZ.pdf?ext=.pdf
  • aspork42
    aspork42 over 5 years ago in reply to easyejl
    No blog ready yet... Was kinda planning on doing just one at the final, but I think I'll go ahead and post something with my progress. This will cover me in case of failure image
  • easyejl
    easyejl over 5 years ago in reply to beacon_dave
    In theory sure, but the description in their docs is confusing, at least to me.
    It is nice that the mkr has that connector for a 2nd i2c channel but I ordered a multiplexer anyhow.
    Right now I'm up to displaying the distance measurement from a single VL sensor on the oled
  • aspork42
    I've got basic communication with all the devices at this stage - temperature sensor, photo-interrupter, screen, distance sensor. Using the op-amp for some signal conditioning. Have a few more things to do still though... I have some cool things planned right now, but don't want to give it away.
    I was playing with the stepper motor and was able to get it to turn to indicate the temperature, and turn based on the distance read for the distance sensor. I've got everything except the screen all inside of one sketch. Just got the screen going the other day so need to roll that in. After that I have mechanical build to do image
    Debating making a circuit board to clean things up... but don't really like using the stepper; should really have a servo for what I'm doing.
  • easyejl
    Are you getting consistent reads from the photo interrupter? If you are, let me know what you're using for pull down as mine is all over the place.
  • aspork42
    I am getting pretty good reads. It is surprisingly binary on/off. I’ll post the schematic for that part later today. I started by using the example circuit in the data sheet. Using one of the op-amps to make the signal 0-3.3 volts output.
  • aspork42
    aspork42 over 5 years ago in reply to aspork42
    Here's what I did.
    The output shown for 'channel II' gives either 0.03V or 2.8V. I then take it and push into a simple comparitor circuit with the op-amp to get 0 or 3.3V output.
  • easyejl
    the major standout difference I see from what I was doing is that you're using 5v for the emitter and 3.3 for the receiver which I hadn't been doing. about to try it.
    Oh and just as a funny thing I noticed, you can't have Cura running and the Arduino IDE at the same time and have the arduino IDE work correctly. Took me a while to work that out image
  • aspork42
    If you look at the schematic, you really only have an LED and a resistor in that part of the circuit; nothing else; not any more complicated than that. I really only chose 5v since that is what my breadboard had available right there. LEDs run fine on both 5 and 3.3 V.
    I wrote up a quick post on progress here:
    Build Inside the Box - James O'G - Build log -Update Sunday 5/2/2021
