WorkBench Wednesdays
  • WorkBench Wednesdays
Documents PCB Design Tips and Tricks - Workbench Wednesdays 58
Join WorkBench Wednesdays to participate - click to join for free!
  • Date Created: 12 Jul 2022 4:48 PM Date Created
  • Last Updated Last Updated: 27 Jul 2022 7:24 AM
  • Views 123154 views
  • Comments 6 comments
No matter how many printed circuit boards you design, the first version of a board will always need to be tested and debugged. These four tips are from Bald Engineer’s experience of designing almost 100 PCBs. With these, you will track your board revisions easier, keep notes of individual boards, and make testing with a scope (or DMM) much faster.
See lots more information, videos and member advice on PCB Design and Prototyping
Supplemental Content:
  • Episode 542: A Noise-Free DIY Switching Power Supply - How Hard Can It Be?
Bill of Material:
Surface Mount Test Points Harwin 1 Buy Now
Arduino Uno Arduino 1 Buy Now
element14 presents
element14 Presents  |  About James |  Workbench Wednesdays
  • PCB Layers
  • test points
  • PCB Silkscreen
  • KiCad PCB
  • pcb tips and tricks
  • pcb
  • workbench wednesday
  • james
  • pcb prototyping
  • pcb design
  • Printed Circuit Board
  • colporteur
    colporteur over 4 years ago
    I'm not sure if this tip has the same merit as yours but it has saved my bacon a few times. I identify polarity on the silk-screen, especially for power. I've been in poor light conditions trying to confirm polarity for a connection. The simple ++/-- give me reference.
    dougw over 4 years ago in reply to baldengineer
    0.079 " , or about 2mm diameter. Pin jacks or tip jacks are also 2mm, so it is a handy size.image
  • baldengineer
    baldengineer over 4 years ago in reply to dougw
    Off-hand, do you know how big you make those holes?
  • koudelad
    koudelad over 4 years ago
    Very good tips - I am looking forward to using them when drawing my next board.
    Good tips - thanks
    I sometimes add through hole test points that are just large enough to fit DVM test leads, especially for ground. This frees up a hand since the test lead plugs into the test point and stays there without being held.
  • baldengineer
    FYI there is a group on the element14 Community for PCB questions! Check it out here:
    community.element14.com/.../
