WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Instrument Basics: Digital Multimeters -- Workbench Wednesdays 11
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: Matt
  • Date Created: 15 Jul 2019 4:42 PM Date Created
  • Last Updated Last Updated: 17 Jul 2019 7:24 AM
  • Views 3718 views
element14 Presents  |  Bald Engineer: James Lewis' VCP Profile |  Workbench Wednesdays
A multimeter is the go-to tool for electronics measurements. Knowing how to use it to measure voltage, current, diodes, and transistors can save time (and frustration) while troubleshooting. James explains how the multimeter works so that you can understand what it is doing while using it.
Bill of Materials
Product NameManufacturerQuantityBuy KitBuy Kit
Handheld DMM (72-7780)TENMA1Buy NowBuy Now
Test Lead Set, Banana Plug Stackable, Banana Plug Stackable, Black, Red, 914 mmTENMA2Buy NowBuy Now
Test Lead Set, Banana Plug, Test Clip, Black, Red, 914 mmTENMA2Buy NowBuy Now
Pocket Sized DMM (72-9390)TENMA1Buy NowBuy Now
Raspberry Pi 3 Model B+element141Buy NowBuy Now
LED: Red, Green, T-1Lumex1Buy NowBuy Now
MOSFET, 55V, 49A, TO-220infineon1Buy NowBuy Now
Zener Diode, 5V DO-204AHON-Semi1Buy NowBuy Now
  • e14presents_baldengineer
  • dmm
  • workbench wednesdays
  • measurements
  • multimeter
    beacon_dave over 7 years ago +1
    Hi James, What equipment / techniques might you use to assess the health of audio frequency inductive loop system (AFILS) copper tapes ? https://www.ampetronic.co/products/flat-copper-tape/ When installed…
    dougw over 7 years ago in reply to beacon_dave +1
    A metal detector or a stud finder should detect metal strips.
    Hi James,
    When installed they are usually fairly low resistance at 0.1 to 10 ohms, otherwise the amplifiers they connect to stop operating.
    As they tend to be installed under floor coverings they can be difficult to inspect visually, however are at risk of corrosion from contact with concrete, cuts from carpet fitters knives, moisture from carpet cleaning/leaks/spills, shorts from drawing pins/staples, and leakage to earth where they cross metal conduits etc.
    I suspect that a milliohm meter with Kelvin four-wire probes might be a good starting point to measure the end-to-end resistance and then an insulation tester to measure from tape to earth.
    In addition to this what cable tracing equipment might be suitable to acuratelly locate the exact path of such tapes under the floor covering ?
