WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Win a Tenma Power Supply
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: kellyhensen
  • Date Created: 19 Sep 2019 2:23 PM Date Created
  • Last Updated Last Updated: 19 Nov 2019 6:47 PM
  • Views 8174 views
  • Likes 15 likes
  • Comments 128 comments
Congratulations to our winners!
Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through.
The winner of the Tenma Supply is Andrew J!
His submission literally made James laugh out loud: turning the supply into a mouse to scare a cat.
Congrats on your new supply!
But that's not all! We're going to find some element14 Community swag for the following honorable mentions:
neuromodulator
liamsenior
dougw
javagoza
This giveaway is closed.
Now that you know the basics of how to use a power supply, wouldn't it be great to have one to use on your very own bench?  Well, you are so lucky because James has one to give away!
Unsupported video URL format.
James is always looking for novel ideas for how to use the equipment on his work bench. . . so in this contest, he's asking for ideas on the most unique use for a power supply that maybe isn't just using it as a power supply.  (I don't think he means gutting it and using it for a potted plant.)
Add your suggestion in the comments below (no later than Friday, November 1) and you're entered with a chance to win.
James will select the winner and announce her/him on this page no later than November 14, 2019.
Learn More about the Tenma Power SupplyLearn More about the Tenma Power Supply
Full Terms and Conditions
  • giveaways
  • ww_giveaway
    dougw over 6 years ago +10
    I would like to set this power supply up to be able to rapidly test USB cable performance. I have a large collection of USB cables that is still growing. It seems every device comes with yet another USB…
  • baldengineer
    baldengineer over 6 years ago +9
    Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through. The winner of the Tenma Supply is Andrew J ! His submission…
    Jan Cumps over 6 years ago +8
    That is a very good PSU! also: I encourage baldengineer to give away *all* the equipment that we can see in the video
  • koudelad
    koudelad over 6 years ago
    Here are a few real-life examples I would use it for.
    1) Multi-chemistry battery charger. There are many types of batteries on the market and each type requires special charging conditions. I have single cells and assembled packs of Ni-MH, Li-ion and Li-Polymer accumulators in various projects and at work. Also Pb accumulators in a car and a scooter. There are special chargers for each type, but CV and CC modes are OK to charge all the types. Of course the form factor is bigger than a dedicated charger, but if you know the specifics of your accumulators, you can increase or reduce the charging speed.
    Recently, we saved a colleague who came to work on a motorcycle, but later couldn't start because of a drained battery. Using a power supply, not only we charged the battery so he could start the engine, but also kept all the electronic circuitry running. Some new cars refuse to start after a DIY accumulator change.
    2) Measuring capacitors leakage current
    As described in baldengineer's tutorial https://www.element14.com/community/community/element14-presents/workbenchwednesdays/blog/2019/06/19/measuring-an-aluminum-electrolytic-capacitors-esr . At work, we use large electrolytic capacitors during manufacturing of some of our devices, in order to test the low power modes of the device. Every capacitor used this way needs to be measured for the leakage current so the devices' low power mode is distinguished from a capacitor self-discharging.
    3) Cooler/heater for component specification testing
    There are many applications that will benefit from a regulated power delivered to a Peltier module.
    I used this a few times already. I needed to overclock a CPU for a while and used Peltier module inserted between the CPU and a heat sink with a fan.
    A general purpose heater or cooler might be built the same way - just attaching a large CPU heat sink with a fan on one side and a heated/cooled object on the other. This setup can be used to test leakage current of various components, mainly (but not limited to) semiconductors. For example microcontrollers can have 1000x higher leakage current at 100 Centigrade, compared to a consumption specified in the datasheet for 25 Centigrade.
    4) Flicker-free LED lightning
    A few years ago, LCDs started with tubes' back light and later moved to LEDs. Still, there are cheaper back lights in LCDs in stand alone-monitors and laptops that use PWM dimming. The same is situation is now with LED lightning. If the lights are dimmable, they use PWM. Higher frequencies are used so the flickering effect is reduced, but there is nothing more comfortable linear power dimming. This requires building your own power supply (or at least I haven't seen a commercially available solution).
  • koudelad
