Project14
Project14
Member Updates Tiny light cluster
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: Workshopshed
  • Date Created: 12 Oct 2018 2:50 PM Date Created
  • Views 2116 views
  • Likes 10 likes
  • Comments 6 comments
  • clusteredmcuch
  • tagname
Tiny light cluster
Workshopshed
Workshopshed
12 Oct 2018
Here's my idea I'm afraid I did not quite have time to get it completed as I've had lots of other things on.
My first thought was what is the cheapest MCU I can find? I spotted the ATTiny10 chips for just 25p each so bought a handful of these along with some surface mount LEDs and resistors.
These would be powered from some button batteries I just happened to have lots of.
The nodes would be spaced out on a clear plastic sheet so you could see that there was no physical connection between them.
They would provide a synchronised pattern or message.
So how does the synchronisation work you ask? Well that would be done by using a camera flash and the LEDs acting as a sensor (a trick I learnt from the Microbit).
https://electronics.stackexchange.com/questions/902/detecting-light-with-an-led
Unfortunately I only got as far as wiring up the ATTiny to some wires and the LED to some wires. I do have a programmer for the ATTiny but I've not tried programming it yet.
  • 14rhb
    14rhb over 7 years ago +6
    Andy, Maybe you haven't got as far as you'd have liked but thank you for sharing as you've given me some ideas for in the future. Your use of a small MCU was exactly along the lines of what I was thinking…
  • Fred27
    Fred27 over 7 years ago +5
    25p? You were ripped off! 3c is the going rate for microcontrollers these days. https://www.eevblog.com/forum/blog/eevblog-1132-the-3-cent-microcontroller!/
    genebren over 7 years ago +4
    These ATTiny parts are on of my favorites. I have used these on a lot of simple device including my light ring for my microscope and my under cabinet LED lighting solution in my kitchen. I have also used…
  • Workshopshed
    Workshopshed over 6 years ago
    Just got some UV resin for another project. Perhaps I'll get this one back up and running?
  • Workshopshed
