Build a Present
  • Build a Present
Build a Present
Blog EL Wire Christmas Tree
  • Author Author: scottiebabe
  • Date Created: 18 Dec 2021 3:46 AM Date Created
  • Views 42373 views
  • Likes 15 likes
  • Comments 13 comments
scottiebabe
scottiebabe
18 Dec 2021
Soft 404
  • scottiebabe
    scottiebabe over 4 years ago in reply to beacon_dave +1
    Deleted
    beacon_dave over 4 years ago in reply to scottiebabe +1
    If it is silicone sleeving then perhaps not the easiest to glue unless you prime the surface first with something like Loctite 770. However if you use enough hot glue then you might get a C-clip type mechanical…
  • surbhika
    surbhika over 4 years ago
    Ahh i have seen these wires for first time. Will order some right away..
    If it is silicone sleeving then perhaps not the easiest to glue unless you prime the surface first with something like Loctite 770. However if you use enough hot glue then you might get a C-clip type mechanical connection with it once it solidifies. Perhaps difficult to keep neat and tidy though. "exhibit e14: 'sculpture in light (with stringy bits)' "
    I was thinking more of open wireframe type skeleton designs with the LED filament shapes mounted between two points of the frame, but that's not going to work on its own.
    Spraying it with some sort of lacquer that encapsulates it and hardens once it dries might work. Or inserting it into clear tubing which can then be manipulated with a bit of heat.
    Engraving Perspex/Plexiglass and inserting it into the groove could work quite good in some cases but the light may bleed in such a way that you don't want it to, and you are likely to get reflections which you may not want. (Although I would like to find out more about various edge-lighting techniques.)
  • scottiebabe
    This comment was deleted.
    A lot of potential for those decorative projects.
    Perhaps though there needs to be a semiflexible version so that you can bend it into a shape and it will then hold that shape, otherwise we are back to the EL wire problem you had. Also perhaps an easier way to cut it to different lengths.
  • scottiebabe
