Cool LED Display
  • Cool LED Display
Cool LED Display
Blog Cool LED Displays: Boost That LED!
Join Cool LED Display to participate - click to join for free!
  • Author Author: jc2048
  • Date Created: 22 Nov 2017 11:24 PM Date Created
  • Views 4402 views
  • Likes 18 likes
  • Comments 16 comments
  • arduino_projects
  • leddisplaych
  • arduino_classic
  • arduino uno project
  • arduino projects
jc2048
jc2048
22 Nov 2017
Cool LED displays. I don't have a lot of time at the moment, but wanted to do something [I did vote for it, after all] so I've
thrown together this - a simple bit of experimenting with an Arduino.
Rather than just light an LED, I thought I'd make it a little bit of a challenge and see if I could light a series string
of seven LEDs. The red LEDs I'm using have a forward voltage of around 2V, so that means I need something like 13V or 14V
to get them illuminated. I could have just used a bench supply to provide the LED voltage but that's not much fun and
wouldn't have made a very interesting blog so I'm going to generate the voltage from the Arduino's 5V with a very simple
and crude boost converter.
Here it is working (warning: world's worst video)
and here it is drawn as a circuit diagram
you can see how I just lashed the components together, without a breadbord or pcb, in this next photograph
How does it work? The MOSFET is switched by the Arduino. Let's consider a time where the output has been low for a while
and is just about to switch high - the gate voltage (relative to the source) is very low and the MOSFET is off. When the
Arduino pin goes high, the gate rises to something close to 5V and the MOSFET turns on. That happens fairly quickly. When
the MOSFET is on it behaves much as a small value resistor would (in this case, a few ohms), so at that point we have 5V
across the coil. The current through the coil can't change instantaneously, instead it starts to ramp up with the rate of
change dependent on the inductance - I chose the 10mH value so that it would ramp to about 20mA in a few tens of
microseconds, a time period which we could control quite accurately with the processor on the board. If you look at the
waveforms below, you can see the ramp up of the current [yellow trace is the output pin, blue trace is the coil current].
As it ramps, energy is being stored in the form of a magnetic field around the coil. After 60uS, the Arduino turns off
the MOSFET, and then the interesting bit happens; the magnetic field storing the energy can't remain there indefinitely,
so the coil needs to be rid of it. If it needs to, and in this case it does, it will do that by increasing the voltage at
the MOSFET end so as to maintain the current that was flowing at the time the switch turned off [as the energy stored is
used up, the current will fall until we are back to zero again]. Initially, the coil can charge the intrinsic capacitance
at the drain of the MOSFET and the capacitance of the LEDs, but those capacitances aren't all that large and it will
quickly attain a voltage where the LEDs turn on and then most of the energy will go to running the LEDs for a short
period. Repeating the process gives the illusion that the LEDs are on continuously. The next set of waveforms show the
voltage at the coil/MOSFET/LED node and the current that flows through the LEDs. As the current declines, the voltage
falls because the forward voltage of the LEDs depends on the current. When the energy stored by the coil is almost used
up, it no longer runs the LEDs but instead what's left of the energy moves back and forth from the coil to the
capacitance at that node [which of course includes the capacitance of the scope probe tip]. The ringing looks a bit
alarming but there's little energy there and it's not doing any real harm.
Sorry the current waveforms are a bit of a mess. The probe is a bit noisy and isn't that good with small currents.
A couple of points if you want to replicate this. Firstly, check the waveform timing produced by the Arduino before connecting the
circuit - there's no protection if the timing is wrong. Secondly, if the LED string is disconnected for any reason, the voltage
will increase until the current does flow, even if that means the coil has to avalanch the MOSFET to do it - so make sure
the LEDs are the right way round and connect properly - if you're a bit nervous, a 24V zener across the LED string would
provide an alternative path in the event of a fault.
Finally, here's the sketch I used.
int outPin = 9;   // output pin to use
// the setup routine runs once when you press reset:
void setup() {
  // set output pin:
  pinMode(outPin, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
word onPeriod = 0;
  // LED on
  for(onPeriod=0;onPeriod<5000;onPeriod++) {    // repeat for about half a second
    noInterrupts();
    digitalWrite(outPin, HIGH);   // pin is high
    delayMicroseconds(60);        // ...for 60 microseconds
    digitalWrite(outPin, LOW);    // then low
    interrupts();
  // LED off
  delay(500);   // off for half a second
If you want to try fading the LEDs, keep the high time constant and lengthen the low time.
  • jc2048
    jc2048 over 8 years ago +8
    players.brightcove.net/.../index.html Another one. This time it's twenty LEDs and a better shape - a star. I've increased the on time so that the current is higher to compensate for the increased number…
  • jc2048
    jc2048 over 8 years ago +7
    players.brightcove.net/.../index.html I couldn't resist doing a bit more with this, so I added two more strings of LEDs (with the LEDs all interleaved) and used MOSFETs to switch one string at a time into…
    jw0752 over 8 years ago +7
    Hi Jon, I love the way you let us look at the technical beauty that lies behind the scenes. Just about anyone can make an LED flash but making one flash in a new way is pretty neat. John
  • jc2048
    Another one. This time it's twenty LEDs and a better shape - a star. I've increased the on time so that the current is higher to compensate for the increased number. You can see from the waveforms that the initial current through the LEDs is now 50mA and the voltage at the top of the string lifts to 40V to get the current to flow. (Although the LEDs will have a DC maximum rating of something like 30mA, they don't mind being pulsed like this - the average current is quite low, just a few milliamps.)
    The ringing is quite entertaining - the first half cycle tries to go below ground but is stopped by the MOSFET body diode conducting and the subsequent cycles continue with the negative peak just above ground.
    And I can report that the MOSFET didn't mind at all being avalanched and is still happily working (whoops!). Probably not too surprising - with the coil limiting the current and the duration quite short it's only doing what any small zener would be able to do.
    • Vote Up +8 Vote Down
  • jc2048
