DIY Test Equipment
  • DIY Test Equipment
DIY Test Equipment
Blog DIY Test Equipment: Mini Air Jet
Join DIY Test Equipment to participate - click to join for free!
  • Author Author: rsc
  • Date Created: 21 Jul 2017 8:09 PM Date Created
  • Views 2669 views
  • Likes 11 likes
  • Comments 8 comments
  • test equipment
  • diytestequipch
  • project14
  • diytestinstruch
rsc
rsc
21 Jul 2017
I work with small thermocouples and Hot-Wire/Hot-Film devices in my lab.  To test and calibrate these devices requires some crazy equipment sometimes.
Try to imagine blowing air on a thermocouple that's in a chain of thermocouples 1mm apart without disturbing the ones on either side.
Hot-films are very sensitive to the air flow direction, and it's difficult to move a big fan around keeping the air flow at accurate angles.
So, after trying straws taped to little fans and other sometimes successful ideas, I designed a small hand-held air jet for this purpose.
The case was designed using AutoCAD, and printed on a SeeMeCNC H2 Delta 3D printer.
I designed it to use a small 30mm fan , and power it with a 9V battery.
Here's the finished unit:
Here's a video of the jet in operation with a hot-film.
    shabaz over 9 years ago +4
    Very cool (in both ways : )! The enclosure looks really nice too.
  • the-dubster
    the-dubster over 9 years ago +4
    Well, I like it. I guess that makes me a bit of a fan . . . . . . . . . . . . Sorry, the 'cool' gags had already been taken)!
  • Workshopshed
    Workshopshed over 9 years ago +4
    I'm blown away!
    jw0752 over 9 years ago
    Hi Scott,
    Have you done any experiments directed at collimating the air flow that comes from the outlet or do you just rely on the close proximity of the outlet to the thermocouple? I would think that a collimated air flow could make your device more accurate.
    By the way I would have to say that this is a cool device.
  • rsc
    rsc over 9 years ago in reply to jw0752
    I have an extra 0.3mm 3d printer nozzle I was thinking about adding to the end to make it more precise.
    I also have some small tabletop camera tripods that could be used as a holder.
  • rsc
