DIY Test Equipment
  • DIY Test Equipment
DIY Test Equipment
Blog DIY Test Equipment: Mini Air Jet
Join DIY Test Equipment to participate - click to join for free!
  • Author Author: rsc
  • Date Created: 21 Jul 2017 8:09 PM Date Created
  • Views 2674 views
  • Likes 11 likes
  • Comments 8 comments
  • test equipment
  • diytestequipch
  • project14
  • diytestinstruch
rsc
rsc
21 Jul 2017
I work with small thermocouples and Hot-Wire/Hot-Film devices in my lab.  To test and calibrate these devices requires some crazy equipment sometimes.
Try to imagine blowing air on a thermocouple that's in a chain of thermocouples 1mm apart without disturbing the ones on either side.
Hot-films are very sensitive to the air flow direction, and it's difficult to move a big fan around keeping the air flow at accurate angles.
So, after trying straws taped to little fans and other sometimes successful ideas, I designed a small hand-held air jet for this purpose.
The case was designed using AutoCAD, and printed on a SeeMeCNC H2 Delta 3D printer.
I designed it to use a small 30mm fan , and power it with a 9V battery.
Here's the finished unit:
Here's a video of the jet in operation with a hot-film.
    shabaz over 9 years ago +4
    Very cool (in both ways : )! The enclosure looks really nice too.
  • the-dubster
    the-dubster over 9 years ago +4
    Well, I like it. I guess that makes me a bit of a fan . . . . . . . . . . . . Sorry, the 'cool' gags had already been taken)!
  • Workshopshed
    Workshopshed over 9 years ago +4
    I'm blown away!
  • jc2048
    jc2048 over 9 years ago
    That's really neat. Simple, yet does just exactly what you want it to and solves a problem for you.
    Nice case - 3D printers are really in their element doing prototypes that are only one step removed from a production injection moulding.
    I find myself toying with the idea of adding extendable and fold-out legs to it, so that it could be set into position without having to be held. Would be a bit complicated to do with 3-D printing I imagine.
  • jc2048
