DIY Test Equipment
  • DIY Test Equipment
DIY Test Equipment
Blog Elevator test unit
Join DIY Test Equipment to participate - click to join for free!
  • Author Author: popupideas
  • Date Created: 27 Aug 2017 6:20 PM Date Created
  • Views 2735 views
  • Comments 12 comments
  • diytestequipch
Elevator test unit
popupideas
popupideas
27 Aug 2017
one diy test unit I want to build is a g-force accelerometer tested for elevators. Prefer a Bluetooth enabled box you put inside an elevator that when it is sent up it will record the travel speed, acceleration, start and stoppong force. It bit I had issues figuring out was vertical speed.
Anyway. I am a loooong way off but maybe one day
    beacon_dave over 9 years ago in reply to jw0752 +4
    How about a barometric pressure sensor being used as an altimeter. Difference in altitude over time would give you the average velocity for that period. It may only be accurate enough for taller buildings…
    beacon_dave over 9 years ago in reply to dougw +3
    ...and then these guys at thyssenkrupp Elevator come along and ruin your day... https://multi.thyssenkrupp-elevator.com/en/ An Elevator That Actually Goes Sideways https://www.youtube.com/watch?v=kdTs…
    jw0752 over 9 years ago in reply to balearicdynamics +2
    Hi Enrico, As long as the elevator itself isn't air tight the barometric pressure measurement should work well indoors. It is in fact just a measurement of the force (weight) of a column of air. Even if…
  • popupideas
    popupideas over 9 years ago
    Thank you everyone for the input! wow.
    I don't know if the following information would be helpful but:
    You can do a pretty decent calculation of travel distance on most elevators (there are exceptions that one would have to measure)
    And the Acceleration and deceleration distances are usually consistent. 18-26 inches. Because these numbers are rough I know it would not give extremely accurate information.
    I never considered the barometric pressure option. I will have to look into that a bit more. I had considered this idea for a unit would also be useful for diy rocket and NEO balloon projects.
    Thank you again for everyone that gave their time and thoughts to this.
  • popupideas
