DIY Test Equipment
  • DIY Test Equipment
DIY Test Equipment
Blog Portable addressable led strip tester
Join DIY Test Equipment to participate - click to join for free!
  • Author Author: den_olli
  • Date Created: 8 Sep 2017 12:19 PM Date Created
  • Views 2886 views
  • Comments 15 comments
  • diytestequipch
den_olli
den_olli
8 Sep 2017
in the office building I work we have DIY addressable led strips surrounding every floor of the building to make it glow at night. It's a part of my job to maintain this setup and unfortunately the setup breaks down a lot.
We we got a defect then I have to open up the sealing and get the 3m long led bar out and take it to the warehouse to test the led strip. I have already bought a wireless soldering iron so I can do small repairs without taking the led strip out of the sealing, but I still need to get it out if I want to connect it to the test unit.
It would really be great if I would have sort of a portable addressable led strip tester, that can run the following tests
- put all led's to red
- put all led's to green
- put all led's to blue
- put all led's to white
- slow nightrider mode 1 led at a time
- put all led's to black (off)
this would save me a lot of time and I guess it would be a great tool for everyone that uses addressable led strips in there projects
I'm trying to figure out a way to make such tester, but the main problem I have is how to deliver enough power for the 3 meter long led strip?
    dougw over 9 years ago +3
    You can buy low cost commercial controllers for ws2812 or whatever led type you have or make your own... https://learn.adafruit.com/adafruit-neopixel-uberguide/arduino-library
    shabaz over 9 years ago in reply to den_olli +3
    Hi Olivier, How frequently is there a failure? And how long could it take to fix the failure, if you had a test tool? Even if it takes just 30 minutes to fix, this is very expensive, considering the aliexpress…
  • gadget.iom
    gadget.iom over 9 years ago +2
    Do you know what make/model the LED strips are? How may LED's need testing by the unit?
  • den_olli
    den_olli over 9 years ago in reply to dougw
    I know, we got one at this moment, but the problem is that it doesn't deliver the required power for the led strips
