DIY Test Equipment
  • DIY Test Equipment
DIY Test Equipment
Blog Portable addressable led strip tester
Join DIY Test Equipment to participate - click to join for free!
  • Author Author: den_olli
  • Date Created: 8 Sep 2017 12:19 PM Date Created
  • Views 2933 views
  • Comments 15 comments
  • diytestequipch
den_olli
den_olli
8 Sep 2017
in the office building I work we have DIY addressable led strips surrounding every floor of the building to make it glow at night. It's a part of my job to maintain this setup and unfortunately the setup breaks down a lot.
We we got a defect then I have to open up the sealing and get the 3m long led bar out and take it to the warehouse to test the led strip. I have already bought a wireless soldering iron so I can do small repairs without taking the led strip out of the sealing, but I still need to get it out if I want to connect it to the test unit.
It would really be great if I would have sort of a portable addressable led strip tester, that can run the following tests
- put all led's to red
- put all led's to green
- put all led's to blue
- put all led's to white
- slow nightrider mode 1 led at a time
- put all led's to black (off)
this would save me a lot of time and I guess it would be a great tool for everyone that uses addressable led strips in there projects
I'm trying to figure out a way to make such tester, but the main problem I have is how to deliver enough power for the 3 meter long led strip?
    dougw over 9 years ago +3
    You can buy low cost commercial controllers for ws2812 or whatever led type you have or make your own... https://learn.adafruit.com/adafruit-neopixel-uberguide/arduino-library
    shabaz over 9 years ago in reply to den_olli +3
    Hi Olivier, How frequently is there a failure? And how long could it take to fix the failure, if you had a test tool? Even if it takes just 30 minutes to fix, this is very expensive, considering the aliexpress…
  • gadget.iom
    gadget.iom over 9 years ago +2
    Do you know what make/model the LED strips are? How may LED's need testing by the unit?
  • gadget.iom
  • gadget.iom
  • den_olli
    den_olli over 9 years ago in reply to gadget.iom
    they used some cheap ledstrips that they ordered from aliexpress
    Hi Olivier,
    Even if it takes just 30 minutes to fix, this is very expensive, considering the aliexpress LED strip very likely cost less than how much you cost the business for 30 minutes.
    Is it not more worthwhile to replace the design with a more reliable one that does not use aliexpress LED strips?
