DIY Test Equipment
  • DIY Test Equipment
DIY Test Equipment
Forum Variable resistor with display
Join DIY Test Equipment to participate - click to join for free!
  • Replies 9 replies
  • Subscribers 15 subscribers
  • Views 3157 views
craigst
craigst over 9 years ago
I want a way to have a variable resistor it's a digital display and maybe a way to see resistance as well the reason is cars use resistance for sensors all over Mainly I want to use led's but dam warning lights , error free lights well nothing works I been adding different resistors to try trick the ECU and variable resistor with display will tell me what resistor I need
Is there sumink I can buy ? Or I can build
    jw0752 over 9 years ago +1
    Hi Craig, Sorry, I am having a hard time understanding what you are looking for. Are you looking for a variable resistor that you can use for an input to the computer in place of a sensor? Even if I have…
    Hi Craig,
    Sorry, I am having a hard time understanding what you are looking for. Are you looking for a variable resistor that you can use for an input to the computer in place of a sensor? Even if I have your question correct there would still be more information needed and there may be situations where the sensor itself isn't resistive.
  • craigst
    craigst over 9 years ago in reply to jw0752
    Sorry I Wana make a standalone tool that uses a variable resistor to 2 points allowing me to connect in between a wires to add resistance to it to identify what resistor I need to add , and little 2 line display or something to show the resistance I'm creating
    Use is for led car head light as my van requires a resistance to make it then bulb is ok , but I can't get light bulb warning light off till I get correct resistance
    It's simple and could just use a variable resistor in between it but rather make a tool I can use in my job
  • craigst
    craigst over 9 years ago in reply to craigst
    I guess it's just a tool the emulates resistance and tells me how my resistance it's giving can find any tools like that just for a 5v to 12v maybe 24v
    A digital one of these , although this would work same
    Look at this on eBay  http://www.ebay.co.uk/itm/262823608556
  • the-dubster
    the-dubster over 9 years ago in reply to craigst
    Sounds like you're trying to fool your CANBUS into thinking it has a filament lamp installed and  of an LED.
    You can actually purchase CANBUS compatible lights that don't flag an issue on the warning system.
    I'll assume you've checked the legality of installing non-standard vehicle lights for your locality.
  • the-dubster
    That's a decade resistance box, you switch in resistors to give a combined overall resistance that you require - the value obtained is decoded from the switch positions.
    A quick 'google' (other search engines are available) of "Digital Resistance Box" turned up some inexplicable pictures of safes and also this (and other examples).
    It's an option, but you'd need to use it a fair bit to possibly justify the extra cost / effort over a standard  decade resistance box!
  • craigstill
    craigstill over 9 years ago in reply to the-dubster
    you are right but my van aint liking it error free led still flags the error yes my service van fits all laws but i have flashing side lights 2 modes, error free but causes cambus error  , my cree full beam cause no error  ( standard not error free) very strange
    Digital Resistance Box looks like what i want i will keep a look out for one, most bmw and Mercedes 2.1 oms is the sweet spot but mine just want to be awkward
  • the-dubster
    the-dubster over 9 years ago in reply to craigstill
    Did you spot the link in the post above? It's (probably) what you're after!
    https://hackaday.com/2014/09/28/digital-decade-resistance-box-on-the-cheap/
  • Sean_Miller
    Sean_Miller over 9 years ago
    You could use a potentiometer as your source voltage.  Turn it to get the desired level of brightness.
    You could either simply mount or hide the potentiometer.  Or, you could measure the voltage output and then calculate the resistor to emulate it with a voltage divider circuit.
    See ya',
    Sean
  • the-dubster
    the-dubster over 9 years ago in reply to Sean_Miller
    I think that the brightness isn't the issue, rather that his CANBUS is showing an error as the lamp is incompatible. That said, it is an option to figure out the required resistance as you can adjust until the error clears.
