IoT: In the Cloud
  • IoT: In the Cloud
IoT: In the Cloud
Blog Arduino IoT Cloud controlled MKR Robot ARM: Das Blinken LED
Join IoT: In the Cloud to participate - click to join for free!
  • Author Author: jomoenginer
  • Date Created: 22 Mar 2019 8:07 AM Date Created
  • Views 4136 views
  • Likes 10 likes
  • Comments 13 comments
  • mkr_1010
  • arduino iot cloud
  • arduino_iot_cloud
  • arduino mkr 1000
  • iotcloudch
  • robot arm
  • arduinoday2019ch
  • arduino mkr wifi 1010
jomoenginer
jomoenginer
22 Mar 2019
IoT: In the Cloud - Arduino IoT Cloud controlled MKR Robot ARM
The Internet of Things is still a hot marketing topic covering everything from Voice Assistants, and Smart Lights, to connected Refrigerators that can order groceries straight from a panel on the door of the frig. There are many predictions that by 2025 there will be something like 21 billion IoT devices chirping on the net.  Considering this, and the increase of the MKR line of dev boards from Arduino, it seems quite appropriate for the folks at Arduino to delve into the Cloud with their Arduino IoT Cloud offering which is Powered by Amazon Web Services (AWS).  Although the IoT Cloud is still in Beta, it does offer some very cool features that take advantage of the MKR devices as well as other connected Arduino devices and Linux based systems such as Raspberry Pi, BeagleBone, and the latest Intel UP boards.
Hardware
In this project, a Robot Arm controlled by a MKR1000 and a MKR1010 powered conveyor belt will be used to test the Arduino IoT Cloud features and how it can be used to control these devices in a simulated Manufacturing environment. Also, a MKR Relay Proto Shield, MKR MEM Shield and a MKR2UNO Adapter board along with a Make Wicked Devices Motor Controller board will be used. A Robot ARM make of foam board with 5 servos connected to the Make Motor controller and MKR1000 will be used to simulate a Robot Arm in a manufacturing environment. A conveyor belt will be created to connect to a MKR1010 and MKR Relay Proto Board will be used to move widgets for the Robot Arm.
MKR WiFi 1010 - https://www.newark.com/arduino/abx00023/development-board-arm-cortex-m0/dp/71AC0169
MKR1000          - https://www.newark.com/arduino/abx00004/dev-board-32bit-arm-cortex-m0/dp/47AC4164?st=mkr1000
MKR Relay Proto Shield - https://www.newark.com/arduino/tsx00003/relay-proto-shield-mkr-board/dp/47AC6341?st=MKR%20Relay%20Proto%20Shield
MKR2UNO Adapter Board - https://www.newark.com/arduino/tsx00005/eval-expansion-board-uno-shield/dp/47AC6343
MKR MEM Shield - https://www.newark.com/arduino/asx00008/mkr-mem-shield-mkr-development/dp/71AC0214
Make Motor and RC Shield for Arduino v1.1
American Robotic Supply MG-90M Micro Servos
Tower Pro SG92R Micro Servos
Parallax 2-Axis  Joysticks
Software
Arduino IoT Cloud - https://www.arduino.cc/en/IoT/HomePage
Arduino Create - https://www.arduino.cc/en/Main/Create
Eclipse MQTT - https://mqtt.org/tag/eclipse
Related Posts
Arduino IoT Cloud controlled MKR Robot ARM: We have Movement
Robot ARM
Robot Arm based on the FoamArmDS design at EasyDS
https://mauriciodgsantos.wixsite.com/easyds/copia-easyfinderds
MKR1000, MKR2UNO and Make Motor Controller stack and Joystick control
MKR1000 Firmware Update
There could be issues seen connecting the MKR1000 to a WiFi router and thus the IoT Cloud, so before connecting a MKR1000 to the Arduino IoT Cloud, it is best to check the firmware version installed on the board and update it as necessary.
For MKR WiFi 1010 Firmware Update, see the following post
MKR WiFi 1010 - Enable BLE Support
The instructions for the MKR1000 are from the following:
https://www.arduino.cc/en/Tutorial/FirmwareUpdater
    1. Downloaded the latest version of the WiFi101 Libraries from:
           https://github.com/arduino-libraries/WiFi101
   2. Add the zip file via Add .Zip File... under Sketch -> Include Library
        NOTE: This updates the Wifi101 to 0.15.3
       https://create.arduino.cc/projecthub/nazarenko_a_v/mkr1000-connecting-to-the-wifi-3-steps-d02fed?f=1
    3. Under Examples->WiFi101, select, build and load the CheckWiFi101FirmwareVersion Sketch.
        If the result of the Firmware check is NOT PASSED, then proceed with updating the firmware:
       Ex.
WiFi101 firmware check.
WiFi101 shield: DETECTED
Firmware version installed: 19.4.4
Latest firmware version available : 19.5.4
Check result: NOT PASSED
 - The firmware version on the shield do not match the
  version required by the library, you may experience
  issues or failures.
    4. Under Examples->WiFi101, select, build and install the FirmwareUpdater sketch
    5. From the Arduino IDE Menu, under Tools, select Wifi1010 / WifiNINA Firmware Updater.
    6. Select the MKR1000 serial port connection and then Update Firmware version.
       Version 19.5.4 was selected to match the version shown in the FirmwareChecker but there was a newer version 19.6.1 shown.
    7. Click the Update Firmware button to update the firmware.
        When complete and successful, a pop up windows should appear indicating the firmware update completion.
   8. If successful, go back to the Firmware Checker (Step 3) and see if the firmware was updated.
       The result should now show PASSED
Firmware version installed: 19.5.4
Check result: PASSED
    9. From the  Arduino Create IoT Cloud IDE, the device should indicated connection if working properly.
    Monitor output with debug set to 2
[ 10081 ] Connecting to Arduino IoT Cloud...
Compile time: 1553040000
[ 12186 ] Connected to Arduino IoT Cloud
If no device has been added to the Device Manager, click on Add New Board to add one.
Or go to the Getting Started Page:
After adding a device it will appear in Device Manager
NOTE: The device will appear if it is connected or not.
Click on the Checker board Icon in the upper left corner to navigate to get to Arduino IoT Cloud or other options.
Click on Arduino IoT Cloud to add Things.
Here a MKRLED Thing was created which is use to turn on and off the LED_BUILTIN
NOTE: Currently only a single Thing can be created, I guess since I get the following when trying to add a new Thing
  "No more Things left on your current plan, please remove your existing Thing before creating a new one. Arduino Plans coming soon!"
Clicking on the defined Thing displays a window showing the Thing's Properties as well as options to add code and edit the thing. A Thing can have multiple Properties.
Selecting Edit Code will bring up the Arduino Create Editor
Here, a onLEDVAL_Change method was created when the MKRLED Thing was created.  The method is declared in thingProperties.h.
Click on "GO TO IOT CLOUD" to go back to the Thing.  Clicking on the eyeball Tab of the Thing brings up window to interact with the think.
A Switch that can be turned on and off is used to toggle the MKR1000 LED (6).
MKRLED Off
MKR1000 LED_BUILTIN Off
MKRLED On
MKR1000 LED_BUILTIN On
Video showing the the MKR1000 LED control from Arduino IoT Cloud
  • jomoenginer
    jomoenginer over 7 years ago in reply to balearicdynamics +3
    My view with the Arduino boards are that they are nice Maker boards or Prototype boards at best. With the partnership between Arduino and ARM and now the extended line of ARM based Arduino boards, they…
    shabaz over 7 years ago +2
    Hi Jon, Very nice walk-through of the Arduino IoT platform.. I'd not seen this before. I think it will be very popular, if the MKR boards come out-of-the-box ready to use with it. Even if cloud is not…
  • jomoenginer
    jomoenginer over 7 years ago in reply to shabaz +2
    I appreciate the comment. The MKR line of Arduino boards are nice and the foot print allows them to be used in smaller projects similar to the Adafruit Feather or smaller Arduino Tiny boards. I believe…
    dubbie over 7 years ago
    Jon,
    Very comprehensive. One day, when I find some time, I too hope to get to grips with this IoT thing and hopefully understand it, regretfully today is not that dy.
    Dubbie
    Jon,
    Dubbie
