Making Time
  • Making Time
Making Time
Blog Big Real Time Clock Using Arduino
Join Making Time to participate - click to join for free!
  • Author Author: rahulkhanna
  • Date Created: 5 Dec 2020 12:37 PM Date Created
  • Views 7522 views
  • Likes 10 likes
  • dmd
  • makingtimech
  • rtc
  • ds3231
  • p10 display
rahulkhanna
rahulkhanna
5 Dec 2020
Making Time
Project14 Home
Monthly Themes
Monthly Theme Poll
Real-time clock using DS3231 and p10 Display Matrix
This project demonstrates the use of electronics and embedded systems with Clock. Dot-matrix Display or more commonly referred to as Free Running Text is often found in shops as a means of advertising their products, it is practical and flexible in its use that encourages business actors to use it as advertising advice. Now the use of Dot-matrix Display has spread, not just as advertiser media only, as well as prayer schedules, warning boards, queuing machines, etc. Here, we will give a post about how I made a clock using p10 Matrix Display and DS3231 RTC using Arduino.
Step 1: Step 1: Hardware and Software Requirements
HARDWARE:
  • Arduino Uno x 1
  • Push-button (Keypad) x 4
  • RTC Module (DS3231)
  • P10 Dot-matrix Display
SOFTWARE:
  • Arduino IDE
  • DMD 2 Library / DMD Library
Before that, you need a supporting library that must be installed on Arduino IDE. To download the DMD2 library mentioned above
Step 2: Connections
*Arduino -> RTC MODULE*
  • A4-> SDA
  • A5-> SCL
  • VCC -> 5V
  • GND -> GND
*Arduino -> P10 DMD*
  • D8-> SCK
  • D6-> A
  • D7-> B
  • D11 -> R
  • D13-> CLK
  • D9-> OE
Step 3: The Code
You can find the code in the Git Repository.
https://github.com/Rahul24-06/Big-Real-Time-Clock-Using-Arduino
Step 4: Features
DMD
  • 32 x 16 high brightness Red LEDs (512 LEDs total) with 10mm pitch
  • Supports 5V operation
  • Viewable over 12 meters away
  • Tough plastic frame
  • Onboard Controller IC
  • Arduino compatible library, graphics functions
RTC
  • counts seconds, minutes, hours, and year
  • Accuracy: +2ppm to -2ppm for 0ºC to +40ºC, +3.5ppm to -3.5ppm for -40ºC to +85ºC
  • Digital temperature sensor with a ±3ºC accuracy
  • Two Time-of-day alarms
  • Programmable square-wave output
  • Register for Aging trim400Khz I2C interface
  • Low power consumption
  • Automatic power failure battery switch circuitry
  • CR2032 battery backup with two to three-year life
Working of This Project: Simple Clock
Working of This Project: Clock With Settings
Step 7: Conclusion
Give a thumbs up if it really helped you and do follow my channel for interesting projects image
Share this video if you like. Happy to have you subscribed: https://www.youtube.com/channel/UCks-9JSnVb22dlqtMgPjrlg/videos
Thanks for reading!
    dubbie over 5 years ago +1
    Looks a nic complete clock. How much power does it take? Dubbie
  • Fred27
    Fred27 over 5 years ago +1
    I see quite a lot of this in your code: switch(minute) { case 0: dmd.drawString( 12,0, "00", 2, GRAPHICS_NORMAL ); break; case 1: dmd.drawString( 12,0, "01", 2, GRAPHICS_NORMAL ); break; case 2…
    Dubbie
    Dubbie
  • rahulkhanna
    rahulkhanna over 5 years ago in reply to dubbie
    Hi,
    The entire setup consumes 20W-22W.
  • shanchya
    shanchya over 5 years ago in reply to rahulkhanna
    Nice project, but could you please gives us a diagram where to put the Push-button (Keypad) x 4 ?
