Merry Boxes & LEDs
  • Merry Boxes & LEDs
Merry Boxes & LEDs
Blog Empty RGB XMAS Tree
Join Merry Boxes & LEDs to participate - click to join for free!
  • Author Author: designer2k2
  • Date Created: 12 Dec 2018 6:29 PM Date Created
  • Views 3401 views
  • Comments 13 comments
  • 3d xmas tree
  • merryboxesledsch
  • github
  • diy
  • holidayspecial19ch
  • xmas
  • ws2812
  • attiny85
  • digispark
  • xmas_tree
Empty RGB XMAS Tree
designer2k2
designer2k2
12 Dec 2018
Merry Boxes & LEDs
Enter Your Project for a chance to win a Maker Tool Kit, an Oscilloscope Grand Prize for the project that brings the Most Joy to the Heart, and Gift to Gives!
Project14 Home
Monthly Themes
Monthly Theme Poll
Hallo,
ein leerer Weihnachtsbaum gebaut aus WS2812 RGB LED Ringen, gesteuert durch einen Attiny Digispark:
Die LED Ringe werden durch die Kupferleitungen die sie verbinden gehalten, er ist Innenseitig leer!
Durch die WS2812 RGB LED können nahezu unendlich viele Farben und Muster erstellt werden image
Den Code und eine kleine Anleitung findet man auf Github: https://github.com/designer2k2/xmas-tree
    dubbie over 7 years ago in reply to dubbie +3
    Stephen, I did like your Christmas tree so much that I did go and purchase a set of these LED rings. All I have to do now is make them work! I've never used this type of programmable LED before. Maybe…
    dubbie over 7 years ago +2
    A really good project. I must get some of these LEDs and try them out myself. Dubbie
    dubbie over 7 years ago in reply to designer2k2 +2
    Stephen, I looked this up. Seems very reasonable. I might have a go at getting one to try out. Dubbie
    Dubbie
  • designer2k2
    designer2k2 over 7 years ago in reply to dubbie
    thanks!   for about 10$ you can get the led rings: https://www.dx.com/p/61-bit-ws2812-5050-rgb-led-full-color-drive-round-development-board-2061268
    The Digispark i had at home (i think most of us have some of them lying around image)
    Take your time with bending the wire, but it still will be done quickly image
    Stephen,
    I don't have a digispark. Should this have come with the LEDs? Can I programme these LED rings with an Arduino Nano? Do the LEDs stay programmed or does the microcontroller always have to be present at power-on?
    And here was me thinking it would be simple!
    Dubbie
    dubbie over 7 years ago in reply to 14rhb
    I will have to look up this Neopixel library and see what can be done.
    Dubbie
  • designer2k2
    Yes you can use the Arduino Nano, actually, you can use just about every system to let them shine image
    But it has to be present at all times, the WS2812 has no memory in it.
    I have choosen the Digispark as it is one of the smallest Arduino´s out there, and its cheap...
  • 14rhb
    14rhb over 7 years ago in reply to designer2k2
    Hi Stephan,
    I didn't know what the Digispark was until you posted that comment and I looked it up - wow what a great little board, thanks for bringing to my attention.
    Rod
    Stephen,
    I'll have to give it a go with a Nano then. As for the Digispark, cheap is always good.
    Dubbie
    Stephen,
    Dubbie
