Music Time
  • Music Time
Music Time
P14 Music Time Blog 215 Instrument MIDI Synthesizer
Join Music Time to participate - click to join for free!
  • Author Author: dougw
  • Date Created: 13 Feb 2023 6:49 AM Date Created
  • Views 11895 views
  • Likes 19 likes
  • Comments 17 comments
  • musictimech
  • anthems
  • VS1053
  • MIDI synthesizer
dougw
dougw
13 Feb 2023
Intro
In my ongoing quest for a cheap MIDI synthesizer, I came across the VS1053 chip which is a pretty spectacular audio chip. It has many features like encoding and decoding many audio standards and implementing several different interface standards. The datasheet is linked below for those interested, however I was specifically interested in its ability to play any note from 215 different synthesized instruments. In fact it can play up to 16 notes or instruments at the same time.
I also found that there are many suppliers who have used this chip in low cost audio modules, unfortunately none of them really cater to its MIDI capabilities. Almost none of them even make the MIDI selection pin available to be jumpered, and of course none of them have a MIDI connector. They all seem to implement the chip as an MP3 player, which is fine, but why ignore the synthesizer capabilities?
So naturally I had to design my own synthesizer around this chip. All the "music" in this blog is produced by this synthesizer, except the percussion intro. I played that on a PC to contrast it with this synthesizer. The percussion sequences may only loosely be called music, because I made them all up and I am not a musician. Fortunately a program called Hydrogen makes fooling around with percussion sequences a lot of fun. I am not playing popular music in this blog since we have to wait until the musicians involved have been dead for a century or two to play that music. Of course that music may no longer be popular then, but hopefully some of the music capabilities of this chip will come through just playing some old classical music. This synthesizer can play just about any real music and it all sounds great, although I have to say it sounds better playing modern music. About the audio setup, my microphone system is adding plenty of noise because my audio lab is not set up yet and also these speakers are not hi-fi. I don't quite get how some web sites will play just about any music ever written down, but every expert on the subject indicates that it is illegal to do so.
Anyway, if you have some unencumbered MIDI music and want to hear what this device sounds like playing it, enclose it below, and I will post it.
The Circuit Card
Design Features
This system is based on the VS1053 audio processor. The custom PCB for this chip is designed to provide a full breakout of every pin on the chip to 0.1" pitch connector pads that will insert directly into a standard breadboard. In fact it can be used as a breakout card for any 48 pin QFN footprint chip of the same physical size. The PCB does not stop there, however, it also breaks out a full microcontroller interface to allow it to have a display and SD card to store music or audio. It also has an auxiliary audio input connector, a stereo power amplifier and an optically isolated MIDI connector. There is a USB connector to supply power to the circuit and regulators to step down to 3.3V and 1.8V as required by the chip.
Description and Demo Video
The first video plays a percussion sequence I made using Hydrogen, first with a PC then using this synthesizer. Then the device is opened up to explore what is inside, followed by an explanation of the 3D printed case.
Anthems
Here are excerpts from a selection of anthems just to show that the synthesizer can play a bunch of instruments. How many anthems do you recognize? I have a tenuous connection to most of these countries but on a good day I would not recognize more than 4 of these. If your anthem is not included, indicate in the comments which one is missing and I will add more to the blog.
Classical Music
In case you didn't recognize any of the anthems, here are a few excerpts from some classical pieces everyone is familiar with:
MIDI Tools & Synthesizer Connections
This video shows how the synthesizer connects to MIDI sources:
Schematic
Here is the schematic
In case it isn't clear what relationship this project has with clocks, everything about music has to do with clocks, especially digital music. Every note is made up of frequencies which in a synthesizer are generated by clocks. The timing between notes is controlled by clocks and even the software that is running is all based on clocks. This circuit includes a 12.288 MHz crystal clock that is used in the synthesis of instrument sounds and notes. The note timing is coming from the MIDI source, which is also a clock driven computer.
PCB Layout
Here is the PCB layout
BoM
Here is the parts list:
Part Value Package Description MFR FARNELL NEWARK #
C1, C6, C14, C15 4.7nf C0805 CAPACITOR
C2-C4,C9,C12,C13,C16,C20 1uf C0805 CAPACITOR
C5,C8,C22-C30 .1uf C0603K CAPACITOR
C18 .1uf C0805 CAPACITOR
C7, C19, C21 10uf C0805 CAPACITOR
C10, C11 18pf C0805 CAPACITOR
C17 .01uf C0805 CAPACITOR
D1 4148 SOD123 DIODE
J1, J2 RCA1 RCA1 RCA Connector
J4 MTA10-100 10-100 AMP MTA connector AMP
J5 PG203J PG203J MIC/HEADPHONE JACK
J6 MAB5SH MAB5SH Female CONNECTOR 809883
J7 USB-MB-H USB Connectors
LED LED5MM LED
LED1 LED5MM LED
M2 PAM8403V PAM8403V PAM8403 Stereo Amplifier
Q1 12.288MHz HC49/S CRYSTAL 1667008 75Y2298
R1,R2,R4,R9,R10,R13,R14,R15 1K M0805 RESISTOR
R3, R8 100K M0805 RESISTOR
R5 220 M0805 RESISTOR
R6 4.7K M0805 RESISTOR
R7 270 M0805 RESISTOR
R11 1M M0805 RESISTOR
R12, R16 10K M0805 RESISTOR
U1 VS1053 LQFP48 VS1053 synthesizer VLSI
U2 3.3V SOT223 LDO regulator
U3 1.8V SOT223 LDO regulator
U4 6N138 DIL08 Optocoupler ONSemi 93R4620
F1-F4 DTRPOF-40059 Push on rubber feet Duratool 43Y4284
Enclosure
The 3D print files used to make the case are enclosed:
Discussion
This project ended up to be a very neat, very useable, and very low cost MIDI synthesizer capable of playing any MIDI music. The PCB has lots of flexibility to be used in different applications, but this application is focused on its MIDI capabilities.
I am extremely happy with the way it turned out. It works and sounds better than expected, and the 3D printed box ties it all up into a fully deployable device. Now I need to get busy learning how to compose real music and perhaps building a MIDI controller. Hopefully members will contribute some MIDI files they want this device to play.
Enclosure STL Files
MIDIsynthSTLfiles.zip
Links
/challenges-projects/project14/musictime?ICID=P14main-feature-widget
/challenges-projects/project14/musictime/b/blog/posts/project14-music-time-build-projects-involving-clocks-and-musical-instruments?ICID=musictime-p14-3step
http://hydrogen-music.org/downloads/
http://www.midieditor.org/
https://www.vlsi.fi/fileadmin/datasheets/vs1053.pdf
    dougw over 3 years ago in reply to robogary +1
    I use Autodesk 123D Design for 3D design. (because it is free and simple to use) I use Hydrogen to create music which is saved as a MIDI file. I use MIDI Editor on a PC (I will put a link in the blog…
    beacon_dave over 3 years ago in reply to dougw
    Electric shock feedback usually makes you try that little bit harder... Slight smile
    Failing everything else, then perhaps dynamic drumsticks that flex to automatically adjust for the timing error such that the tips always strike the drum at the right time. You might feel like you are drumming with a pair of bananas to start out with, but hopefully over time they will straighten out...
    dougw over 3 years ago in reply to beacon_dave
    Cool haptics.
    What I need is a system that can encourage (force?) my hands to do the right thing...Relaxed
    Looking and sounding great.
    You perhaps now need to build yourself a haptic drum kit MIDI controller to go with it  Slight smile
    https://www.youtube.com/watch?v=9ioWDrrJWS4
    https://www.youtube.com/watch?v=NcoNgCHZyTE
    dougw over 3 years ago in reply to javagoza
    MIDI protocol has a lot more complexity than that, Relaxed but the original baud rate is a simple 31.25 KHz.
    USB MIDI is much faster - I haven't looked into how timing is maintained.
    It sounds like your project is an awesome project. I hope to see some blogs about it. Relaxed
    genebren over 3 years ago
    Well done Maestro!  This turned out very nicely.  The wide range of voices is a really nice touch for this chip.
