Music Time
  • Music Time
Music Time
P14 Music Time Blog Project14 | Music Time: Build Projects Involving Clocks and Musical Instruments!
Join Music Time to participate - click to join for free!
  • Date Created: 26 Jan 2023 7:49 PM Date Created
  • Views 10642 views
  • Likes 17 likes
  • Comments 6 comments
  • musictimech
tariq.ahmad
tariq.ahmad
26 Jan 2023
In the Comments Below:   Let Us Know Your Ideas for Projects that Involve Music and Clocks!
Contest Details:
The theme this month is Music Time.   You can build any projects involving clocks and musical instruments.   The theme combines two things dear to the heart, music and timepieces.   Your projects can involve building your own musical instruments such as theremins, guitar synths, e-bows, musical motion clocks,  music themed clocks, musical instruments based on clocks, flute playing instruments and clocks, and more.
Submit Your Projects Here:
Submit an Entry
The relationship of music and clocks can be traced to automatic musical instruments that had musical instruments built into the clocks.   Initially,  these consisted of chimes or psaltery-harp clocks that could only play simple melodies due to their limited range of sound.     In the 18th century serinettes, or bird organs, became popular.   A serinette is a type of mechanical musical instrument that consists of a small barrel organ. Its name was derived from the French serin, meaning “canary and they were used to teach canaries how to sing.  They come equipped with everything that makes up an automatic musical instrument: a drive (hand crank), a sound carrier (pinned barrel), and sound cources (pipes). The hand crank drives both the barrel and the pump. The pinned barrel is sensed by small levers which are attached to valves. If a lever is raised by a pin, the valve opens and compressed air streams into the corresponding pipe.
This would eventually lead to the development of flute-playing clocks driven by weights and a clockwork with additional flute pipes.  Reproduction of melodies became more and more precise with improved pin barrels and sensing mechanisms.  Famous composers such as Mozart, Handel, Haydn, and Beethoven wrote music especially for flute playing clocks.  Among the enthusiastic collectors of flute playing clocks were the likes of Frederick the Great and Napoleon.
The thereamin is basically a clock circuit controlled by a large capacitor.   Its made with vacuum tubes and everything. The large capacitors capacitance is changed by moving ones hand closer or further away from the plate. This changes the frequency of the clock circuit and is outputted as noise. The theremin is distinguished among musical instruments in that it is played without physical contact. The thereminist stands in front of the instrument and moves their hands in the proximity of two metal antennas. The distance from one antenna determines frequency (pitch), and the distance from the other controls amplitude (volume). Higher notes are played by moving the hand closer to the pitch antenna. Louder notes are played by moving the hand away from the volume antenna.
Musical clocks are clocks that mark the hours of the day with a musical tune. They can be considered elaborate versions of striking or chiming clocks. Elaborate large-scale musical clocks with automatons are often installed in public places and are widespread in Japan. Unlike conventional electronic musical clocks, these clocks plays pre-recorded music samples, instead of using programmed sound synthesis.
Here are some projects to inspire you:
Old fashioned Japanese Music Box by Workshopshed
A Simple Arduino Music Box by jc2048
Vintage Toy Synthesiser by liamtmlacey
The IOT Wind Chimes by fmilburn
Dum-De-Dum, the Cardboard Drum! by balearicdynamics
Your Chance to Win
Be Original
Stick to the Theme
  • You could come up with a clever name that make's your project memorable!
    • This project is your baby! Part of the fun of bringing something new into the world is coming up with a name.
  • Your project could introduce something new or that is not commercially available or affordable!
  • If you have an idea for a project that doesn't fit the current theme then submit your idea in the comments section of the monthly poll.
List the Steps
Submit Video Proof
  • Provide the steps you took to complete your project (text, video, or images).
    • This could be a step by step how-to-guide, vlog, schematics, coding, napkin drawings, voice narration, or whatever you think will be useful!
  • If it doesn't work that's fine, this is more about the journey than the end product.
  • A short video is all that is required but you can shoot as much video as you like.
  • You are encouraged to be creative and have as much fun as possible!
Your Prizes
One Grand Prize Winner Wins a $200 Shopping Bundle Three First Place Winners Win  a $100 Shopping Cart
  • One Grand Prize Winner Wins a $200 Shopping Cart!
  • 3 First Place Winners a Win $100 Shopping Cart!
image image
Some Terms & Conditions Apply:  Music Time Terms & Conditions
Your Project, Your Ideas!
About Project14
Directions
Every month you'll have a new poll where you'll get to decide an upcoming project competition, based on your interests, that will take place a couple of months in advance. Themes are broad in scope so that everyone can participate regardless of skill set.
What are Monthly Themes?
  • Every month (around the 14th of each month) a new theme will be posted on Project14.
  • Submit your ideas (proposals) for your projects to get feedback from the rest of the community.
  • Submit a project entry in the Theme space once you start working on it.
What are Monthly Theme Polls?
  • Every month (around the 14th of each month) there is a project theme poll.
  • Vote on which project competition you want to see for the following upcoming theme.
    • The themes voted on during the previous poll decided the upcoming theme.
    • If you submit an idea for a theme that is not used then it can still be used in a future poll.
  • Themes comments and ideas from the comments section of the project theme poll.
Step 3: Submit a blog post of your progress on your project by December 19th.  You are free to submit as many blog entries as you like until the beginning of the next theme.
Visit:  Music Time  or tag your project blog musictimech
You have until April 14th End of Day to submit your completed project!
A jury consisting of your peers will judge project submissions!
  • robogary
    robogary over 3 years ago +1
    Have an idea for something completely different. ......Kinda. .....See if the project can play the Monty Python theme, Liberty Bell, and without a huge smelly foot squashing me at the end.
    dubbie over 3 years ago +1
    I think I might see if I can give this a go. Something along the lines of a quarter chiming time piece, possibly with robots - or possibly not. Who knows as currently I'm building a shed/greenhouse and…
  • Sudeep AJ
    Sudeep AJ over 3 years ago
    I have been working on TinyML projects recently. How about making a real-time voice-activated time keeper using RPi Pico!!
    beacon_dave over 3 years ago in reply to ljmora.13
    Derek talks you through designing a guitar distortion pedal over at 'DC to Daylight', which may be of interest:
    /challenges-projects/element14-presents/dc-to-daylight/w/documents/27759/dc-to-daylight-16-how-to-use-a-jfet-as-a-buffer-in-a-guitar-distortion-pedal
  • ljmora.13
    ljmora.13 over 3 years ago
    Always i've wondered how effect pedals work and how can i make to make one by myself (being a bass/guitar player). This could be a nice little project to make my first handmade pedal Metal tone3Guitar
  • aaryan2134
    aaryan2134 over 3 years ago
    Exciting! Could be fun to work on this
    I think I might see if I can give this a go. Something along the lines of a quarter chiming time piece, possibly with robots - or possibly not. Who knows as currently I'm building a shed/greenhouse and I purchased my seed potatoes yesterday (Pentland Javlins) so I'll have to complete this project before the warm weather arrives - when I will be going outside and then  I might be sometime.
