Photography
  • Photography
Photography
Blog Lightning strike photos
Join Photography to participate - click to join for free!
  • Author Author: helium5793
  • Date Created: 17 Jul 2021 12:35 PM Date Created
  • Views 1947 views
  • Comments 8 comments
  • photographych
  • canon camera
  • lightning
helium5793
helium5793
17 Jul 2021
My intention is to make a circuit that can see the increase in brightness of a lightning strike and trigger a canon camera to photograph it before it fades.  I have partially succeeded in this several years ago, but need to look up my current circuit, describe it and see about improving it.
A list of needs:
appropriate sensor
arduino to control it
camera interface
protection from bad weather.
Portable power.
john
    DAB over 5 years ago +5
    Having done lightning photography, I have won awards with some of my shots, here are some things to consider. Most lightning lasts about one second and generates repeated strikes at about 38 HZ, which…
    beacon_dave over 5 years ago in reply to DAB +3
    Even more fun if you have a high speed camera lying around Lightning Strike at 103,000 FPS - YouTube ( Just need to setup on the correct side of the hotel ! )
    dougw over 5 years ago +2
    https://www.electroschematics.com/lightning-detector/
  • robogary
    robogary over 5 years ago
    I wonder if OpenCV could scan fast enough video frames quick enough, learn what a lightning strike is, save those photos, discard others.
    DAB over 5 years ago in reply to robogary
    Depends upon your computer and resolution.
    You can get OpenCV to run at 60 Hz, but by the time you process the frame and send a trigger pulse, you will probably miss it.
    I would just set up a good HD video camera and then use OpenCV to sort those frames that do not have a flash in them.
    I recall someone taking a similar approach a few years back. I think it was this project:
    https://lukse.lt/uzrasai/2015-05-lightning-strikes-and-python/
    Not likely to win any competitions but it may be of interest to see what can be achieved using a GoPro 3 action camera.
    According to the write-up it takes about 8mins for a 'quick and dirty' Python OpenCV motion detection script to process 15min of 1080p @60 video on an i7 CPU.
    DAB over 5 years ago in reply to beacon_dave
    Nice sequence.
    Yes there are a lot of ways to go about solving the problems.
    As long as you live somewhere where you get lots of lightning, like Florida, you can have a lot of fun projects playing around with cameras, software and different triggering methods.
    Yes, if you have access to a high frame rate cameras, you can see all sorts of things.
