Photonics
  • Photonics
Photonics
Blog Easily LED
Join Photonics to participate - click to join for free!
  • Author Author: paj
  • Date Created: 14 Apr 2020 7:07 PM Date Created
  • Views 4564 views
  • Likes 10 likes
  • Comments 25 comments
  • photonicsch
Easily LED
paj
paj
14 Apr 2020
  • Introduction
  • Experimenting
  • Research
  • More Experimenting
  • Finally a project
When the photonics competition was announced I had no idea what I could do as an entry. Reading through the brief the only parts I have that I could usefully use in a project are LEDs. To date I have only used LEDs as indicators to signal that something is working so in a nutshell I know very little about them. To prove this I have jotted down what I know.
Even the things I know are a bit vague so I thought I would do some research and experimentation.
Experimenting
First thing I did was to put an led in a breadboard and take a photo.
Then I powered the LED with 1v and nothing happened.
I increased voltage to 2v and the LED lit up.
Next  I increased the voltage and the LED failed in what looked like a small explosion. Video shows LED lit  normally then I turn off the power, increase the voltage and turn the power back on.
So what is actually happening here?
Research
I started by Googling ‘Why does an LED explode?’ More than a few people seemed to take exception to this terminology but to be honest they didn’t clarify why they thought this was wrong. The posts were quite old so there is little point in trying to follow this line of thought. The best answer I could find was that the current caused the semiconductor material in the LED to overheat and eventually burn.
This makes some sense. Reading a bit more I found out that the LED is made up of a semiconductor. Semiconducting material has a forward voltage which is the point below which it will not allow the current to flow. This is why my LED did not light at 1V.  When you pass enough current through the semiconductor it allows the current to flow hence it lit at 2V. This happens by virtue of the electrons in the semiconductor becoming excited. In an ordinary diode this allows the current to flow in the LED it also creates photons and consequently light.  The non-conducting material in a semiconductor is doped with an another compound. Doping is a process of adding a minute quantity of another substance to the silicon base and it is this trace compound that creates the ability for the electrons to flow.  Different compounds create the different colours.
These are some of the different compounds used.
  • Indium gallium nitride (InGaN): blue, green and ultraviolet high-brightness LEDs,
  • Aluminum gallium indium phosphide (AlGaInP): yellow, orange and red high-brightness LEDs,
  • Aluminum gallium arsenide (AlGaAs): red and infrared LEDs,
  • Gallium phosphide (GaP): yellow and green LEDs.
I think what I have written, whilst brief, is correct (please point me in the right direction if I have missed the point somewhere). Anyway the physics beyond this point is getting more complicated than I want to get into (this branch of physics is on the rather large list of things that I don’t understand).
I noticed on the data sheet, that I looked at, there was a reverse voltage i.e. the voltage at which the diode will allow current to flow back. The data suggests that when this point is reached it is usually also the point at which the LED will fail.
More Experimenting
So back to experimenting and I put an LED in the bread board and reversed the voltage.
I started my camera recording and watched what happened as I cranked up the volts.
Nothing.  I started at 5V and reached 31V (the limit of my bench power supply) and what I expected, which was some sort of catastrophic failure, didn’t happen. I tested the LED and it still worked. So I connected another LED the right way around into the circuit to see if at any point the current flowed. Still nothing.
So from that I can conclude , for my LEDs at least, that they would act as a diode for quite a high current, certainly more than I ever play around with. I guess other LEDs will have different characteristics.
LED as a light sensor.
During my earlier research I read that an LED can be used for a light sensor because it creates a very small current in the presence of light. So I tested one with my multimeter.
In my little room, which is quite dark, my yellow LED registered 5.6mV. I tried a green LED and this registered 7.9mV. A red LED registered 6.9mV.  I tested another similar yellow LED and got 6.9mV , Another green 9.6mV another red 3.9mV. It was bright sunshine outside so the light levels weren’t fluctuating. So the results weren’t consistent. I have some super bright clear LEDs so I put one in 19.5mV. I tried another 18.7mV, another 21.9mV then another 21.2mV and back to the first 19.1mV. I then measured the values whilst  I held a 6V LED bulb above the LED.
Colour
First test mV Second test mV Third test mV Result of holding light above LED
Red 6.9 3.9 6.3 230mV
Yellow 5.6 6.9 7.1 140mv
Green 7.9 9.6 9.9 121mV
Clear (super bright) 19.5 18.7 21.9 33mV
The super bright LEDs are better quality so maybe that explains the more consistent voltage readings. Looking at my little table I think the voltage is differing according to the different colours. Also it is evident that each LED is responding to the light being shon eon it.
The other thing I read was that LEDs are colour sensitive so I did some experimenting with different colour LEDs and an RGB LED to provide the coloured light. I placed the coloured LEDs next to the RGB and then powered each leg on the RGB to get red green and blue light. Here are the results:
LED colour Room light mV Red light mV
Green light mV
Blue light mV
Red 1.2 5.1 1.2 1.2
Green 17.5 17.5 52.3 41.7
Yellow 8.3 8.1 33.9 10
Clear 39.4 40.3 40.1 41.4
From this I would say the red LED is definitely more sensitive to red light just as the green LED is more sensitive to the green light, but also quite sensitive to blue. I didn’t bother to try to power the RGB to make yellow but it responds quite strongly to the green light. The clear LED didn’t seem to respond.
Finally a project
Whilst I was experimenting I started thinking about what I could do as a project with LEDs and came up with the idea of a sun tracker. My plan was to embed 5 LEDs in tubes to form the shape of a plus sign. My idea being that as the light shone down the tube, in which the LED was embedded, the more directly the tube faced the sun the greater the voltage generated by the LED would be. I would use an analogue input pin on an Arduino UNO to measure the current generated by the LED. The plus sign of LEDs would be mounted on a pan and tilt assembly.
So I had already 3d printed a pan and tilt assembly some months ago (courtesy of Thingiverse)  that utilised a couple of cheap servos. So I got that out and wrote a script to make the pan and tilt scan through the various angles at which the sun could be situated.
Next I generated a small script to capture values from the LED. The LED cathode is simply connected to the earth and the anode into the A0 socket. This seemed to work nicely, the values went up when the light was turned on and back down when the light was turned off.
So now I needed to combine the two scripts but I knew both were too simplistic for a working sun tracker.
So I thought to get things started I would attach just one LED to the pan and tilt mechanism. I had a couple of male female jumper leads and I connected these to the LED and plugged them into the UNO. It was then I realised that it wasn’t going to work. The longer leads made the analogue pin sensitive to nearly anything and the values were leaping around by themselves. Sometimes dropping to 0 then rising and falling again. I think what is happening is that the A0 pin is responding to various sources of emf.
So at this point I decided to call it a day and I didn’t actually intend to finish this blog. But then today I thought I would because it might interest someone and also someone might tell me something that I can do to fix this.
So any comments about anything that I might have gotten wrong (please be kind) or any ideas to solve this would be very welcome.
As I finally put this to bed I wonder if a capacitor would help?
  • jc2048
    jc2048 over 6 years ago in reply to paj +4
    Here's the circuit and a couple of pictures of it I didn't bother with a board, just floated it in mid-air above the UNO. This is the UNO code. It's extremely simple, just takes the pin high for 60us every…
  • paj
    paj over 6 years ago in reply to dubbie +3
    Hi Dubbie, can”t take the credit for the pan and tilt it was just something I found on thingiverse. My CAD skills aren’t quite up to that though I am getting there. I will take on board your thoughts oh…
  • jc2048
    jc2048 over 6 years ago +3
    I was curious about your reverse measurements. It's not something that you normally ever look at if you design with LEDs, you just go by what the datasheet tells you (which is usually 5V). I've tried it…
  • jc2048
    I've tried it with a few LEDs, but unfortunately I don't know what they are as they are from old bags that have been lying around for years (once upon a time, LEDs were part of my day job and these are some from spares that were kept on a storeroom shelf and never used). This is with a test current of about 20mA, but it's all a bit approximate. This isn't a piece of professional test equipment; it's just a lash-up with an Arduino, so take the results with a little skepticism.
    Here's a red, clear, high brighness, narrow viewing angle
    Here's a green, fairly high brightness
    Finally here's one I do know the part number of, it's a Kingbright L-7104ID red LED (GaAsP/GaP), which is impressive.
    That last one is getting very 'iffy'. This is my test circuit without an LED
    so it only reaches -180V anyway and at -170V it's running out of 'steam' [current really] and it's probably just increased leakage that's folding it over and not an actual, sustained avalache.
    All the above were happy to repetitively avalanch twice a second, but I also tried an old Nichia high-brightness true-blue and that failed almost immediately after showing a breakdown at about -70V. When they first came out they had to be treated carefully as static-prone components, so I'm not surprised it died quickly.
    The low datasheet figure might be down to what can be tolerated before it starts to compromise other things like the lifetime, rather than anything to do with where it breaks down and what damage might then ensue.
    As Fred27 points out, there's a relationship between the forward current and the forward voltage that you need to understand. If your power supply works constant-current to a reasonable accuracy, you could try increasing the current from about 1mA in small steps and seeing what the forward voltage is for each step. If you plot it on a graph, current against voltage, you'll soon see why applying 5V directly across the diode is problematic.
  • jc2048
    jc2048 over 6 years ago in reply to jc2048
    Here's another one.
    That's a 1W warm white on a 'star' board. It seems to have a very low reverse breakdown voltage (the reading at the 'b'
    cursor point of -6.68V), compared to the ones above, but that's because we're most likely not looking at the breakdown of
    the LED itself. Instead it probably shows the voltage at which an internal anti-static diode is clamping.
    If you want to try this for yourself with some of your own LEDs (you'd need an oscilloscope, an Arduino UNO, and three
    simple components), say and I'll explain how I'm doing it and show you a picture.
  • paj
    paj over 6 years ago in reply to jc2048
    Hi Jon, yes please show me how you are doing this I would like to learn more. Thank you.
    Jan Cumps over 6 years ago in reply to neuromodulator
    neuromodulator  wrote:
    Jan Cumps  did it work the first time that you checked my post?
    No. The images didn't show. At the time I thought it was an issue with my tablet.
    I logged a support request: https://www.element14.com/community/message/291092/l/pictures-do-not-show#291092
  • jc2048
    jc2048 over 6 years ago in reply to jw0752
    I can see my pictures above.
    Pictures do seem to be missing in other places, though. John's reply to Karen on her 555 bistable blog doesn't appear, to me, to have any visible pictures. Some of my old blogs have pictures missing, too.
  • jc2048
    Here's the circuit
    This is the UNO code. It's extremely simple, just takes the pin high for 60us every half a second.
    /* pulse output
    Turns UNO pin 12 output on for 60us every half second
    This is specific to UNO [but should work on NANO as well].
    void setup() {
      DDRB = DDRB | 0x10;
    void loop() {
      while(1) {
        noInterrupts();
        PORTB |= 0x10;
        delayMicroseconds(60);
        PORTB &= ~0x10;
        interrupts();
        delay(500);
    That 60us isn't very critical. Looking at that last trace of the warm white, it might do with lengthening a bit, maybe 80us
    or something like that.
    One note of caution. I assume that the power to the UNO is floating relative to mains earth [I ran the board from a bench
    supply]. That enables me to clip the 'scope probe earth to the +5V and treat that as being 'ground'. That would probably
    also be the case powered by USB from a laptop, but might not apply with a traditional desktop machine.
    Note also that the Vdsmax of this particular MOSFET is 400V. If it were too low, we'd be testing the MOSFET rather than the
    LED.
    Operation is quite simple. When the output goes high, the MOSFET turns on. Current flows intially through the LED and it
    momentarily lights up. The voltage across the LED will be the forward voltage at the current defined by the resistor.
    That's at cursor 'a' on the warm white the waveform above. Because I've got the trace inverted, that comes out as a
    positive voltage on the trace, even though it's negative wrt to the +5V. The initial forward voltage appears across the
    coil and the current in the coil will start to ramp up. It will then start to steal current from the LED, the voltage
    across the LED will go down, and the light from the LED will diminish. That continues until it limits at the current given
    by the resistor plus the coil resistance across the +5V [about 22mA]. At that point the voltage across the coil is fairly
    low. After 60us is up I turn off the MOSFET. The coil now has the problem of keeping that current running because there's
    no path through the MOSFET anymore. To do that it generates a voltage and it will keep raising that voltage until the
    current flows. That voltage is going above the +5V rail, but because of the trace invert it looks like it's negative. When
    the LED reverse breakdown voltage is reached, the LED conducts and clamps the voltage at that point. It's not particularly
    good for the very high voltages because the fairly high capacitance at the MOSFET drain has to be charged to get there and
    it runs out of energy before it arrives [I could have chosen the MOSFET much better but was limited by the ones I had
    available]. When the reverse breakdown of the LED finishes, any remaining energy will surge back and forward between the
    coil and the capacitance of the MOSFET drain [it forms a resonant circuit] whilst it gets steadily dissipated in the
    resistor.
    Obviously, be a little bit careful with it if you do decide to try it. It is high voltage. Having said that, the current is
    only a maximum of 22mA and the anti-static protection diodes on the processor should be able to cope with that at a half
    second repetition rate if they were inadvertantly touched.
  • jc2048
    Here's the circuit
    /* pulse output
    void setup() {
      DDRB = DDRB | 0x10;
    void loop() {
      while(1) {
        noInterrupts();
        PORTB |= 0x10;
        PORTB &= ~0x10;
        interrupts();
        delay(500);
    LED.
    resistor.
  • cstanton
    cstanton over 6 years ago in reply to jc2048
    Sorry jc2048 , you might have to re-attach/upload/embed those images because of the site problem(s) we've been having.
  • jc2048
    jc2048 over 6 years ago in reply to cstanton
    cstanton I've replaced the pictures. Can you see them now?
  • paj
    Hi colin yes I can see them
  • cstanton
    Yes, thank you.
  • paj
    Hi Jon, I have looked at my parts and I don’t have a mosfet that big in fact the only one I have is 70v. Also I don”t have a coil. So I’ll have to add them to my shopping lis and come back to this later. Thanks for your time and effort it’s much appreciated.
