Proving Science
  • Proving Science
Proving Science
Blog Laser Microscope Experiment
Join Proving Science to participate - click to join for free!
  • Author Author: vishwasn
  • Date Created: 14 Sep 2020 7:49 AM Date Created
  • Views 4102 views
  • Comments 6 comments
  • provingsciencech
vishwasn
vishwasn
14 Sep 2020
Proving Science
Project14 Home
Monthly Themes
Monthly Theme Poll
LASER stands for Light Amplification by Stimulated Emission of Radiation. As the name itself says it's a powerful beam of light which is coherent and monochromatic. Let's see how we can make a microscope with this key-chain LASER.
PLEASE DON'T FORGET TO VOTE ME IN CONTESTS. THANKS FOR YOUR PRECIOUS TIME.
Step 1: Parts Required
Parts Required
1. Key-chain LASER (You can use any LASER source such as laser diode .etc)
2. Injection Syringe(Be careful with the needle).
3.Cellophane Tape
4.Thin Copper Wire(Extracted from old electronic clock)
5.Stands for holding the things
6.White Chart paper for Screen
7.Clip for holding the button of key-chain laser
Step 2: 1. Laser Microscope
1. Laser Microscope
1. Laser Microscope
1. Laser Microscope
Take the syringe and fill it with pond water (To see aquatic creatures in micro-level) then place it on a stand or on top of a box.
Wrap the chart paper around a cardboard to make a screen.
Place the screen about 1 meter from the syringe arrangement.
With the help of clip hold the button of key-chain laser in ON position.
Secure the laser setup with the help of a stand or a box.
Place this setup 2 feet away from the syringe arrangement.
Step 3: Setting Up...!
Setting Up...!
Now we have arranged everything let's put the things into action.
Gently press the syringe piston such a way that water droplet should come at the end of the needle. This is the main part of our microscope i.e Convex lens. Yes, water droplet acts as a convex lens.
Focus the laser beam such that it should point the water droplet. Due to refraction from the water lens, it projects the laser light directly on the screen. This will form a red patch on the screen.
Step 4: The Final Show: Microbes.
Turn off the light and see the nice view of the microbes. You can use this experimental setup to check the purity of drinking water, boiled water etc.
Now you can observe microbes, bacteria etc. roaming around the tiny droplet of water.
You need the patience to watch this, of course in order to see wonders of science you need patience. image
    balearicdynamics over 6 years ago +2
    Maybe a video may help. Anyway, the proof of concept is interesting, but I think it is more probable you see the diffraction of the microbes instead of the cells themselves. The reason that probably you…
    dubbie over 6 years ago +2
    Looks a fun experiment. I might have to try this out. Dubbie
    jw0752 over 6 years ago +1
    Fascinating simple experiment. I've got to try this. Even if the images aren't perfect it will be neat just to confirm the presence of the little beaties in the water. John
  • vishwasn
    vishwasn over 6 years ago in reply to jw0752
    Thanks. I have added the video please checkout.
    Regards,
    Vishwas Navada B,
    VU3TEY,
    https://vishwasnavada.github.io
