Recycle & Retrofit
  • Recycle & Retrofit
Recycle & Retrofit
Blog Retrofited Alarm Clock with New Brains and stuff
Join Recycle & Retrofit to participate - click to join for free!
  • Author Author: hugohu
  • Date Created: 8 Dec 2020 1:41 PM Date Created
  • Views 3299 views
  • Comments 12 comments
  • recycleretrofitch
hugohu
hugohu
8 Dec 2020
Recycle & Retrofit
Project14 Home
Monthly Themes
Monthly Theme Poll
I have this old Sony alarm clock. Took it apart a few months ago, powered solely by ICs.
It's not too powerful.
I'm adding a Pi 4 to it- to run the Google Assistant SDK, so it could be a google assistant enabled alarm clock.
Well, what's my progress?
Welp. I've been procrastinating a bit since I thought the due date was 1/14.
Turns out it was 12/14
Ouch.
Anyway. I have a first-gen AIY kit I got from microcenter for 3 dollars. I plopped it onto the Pi 4 4GB Tariq sent me(thank you!)
I set up the SDK, API, and stuff like that yesterday.
https://aiyprojects.withgoogle.com/voice-v1/
I can't find the microphone! I'll find the speaker I took from this alarm clock, reinstall it, and connect.
When done, I'll install it into the chassis.
For the screen- I'll have to reverse engineer the LCD module.... ouch....
Multimeter should come in handy.
Yay. I opened up the chassis. Looks like I'll need significantly more effort to modify the case than i expected.
Ouch.
Ouch.
Ouch...
Yipee. The API didn't work. I have to redo it. WHIPEE.
Hey, I did finid that mic.
12/9/2020
Ralph, you were right! Just finished the major portion for this.
3A+(sorry Tariq but space was limited)
This also has one of those AIY hats.
The AIY hat is basically just an audio amp, mic breakout, and servo drivers.
Suits me.
The original speaker's wires are too old and I decided to swap them for new ones. Hi-quality 22AWG, here we come!
Soldered on some new wire, and it's as good as new.
The sound quality isn't the best, but it IS over a decade old.
Trust me- it really is the original speaker.
Look how much it fits to the original chassis. Had to tape it on since I couldn't find my glue gun.
And lastly a poorly shot image
That plastic, is to prevent the terminal block leads from touching the HDMI port which causes a short circuit which isn't fatal but make a buzzing noise.
That's it.
(Or is it)
I have to add a video for proof!
Here's a short video, showing myself asking the current time and temperature.
Time to figure out the timing part. Ouch....
Now that hurts. Time to dig up some dev modules.
12/11
I did make the clock!
With an arduino Uno, but I realized it wouldn't fit. In my attempt to use a digispark I managed to kill the digispark and also the screen and RTC.
*Trying but failing not to cry*
*sniffs*
Sacrficed, I suppose.
Time to find something else.
A bit of "how to"
First, you have to follow the instructions in the link I posted above. However, don't connect the speaker nor put it in a case.
Then, see how to fit this into your case. I had to snap some plastic support structures to do so.
Then, I had to figure out the power issue. I basically took the power cable and then fit it through the hole that the power cable used to be.
Since I already enclosed the board, I use SSH to connect to it, and run the scripts.
I have no idea if I can add a screen- I fried the smallest dev board I had, the small ones that I have now are incompatible with libraries.
I still have a cool SHARP monochrome 2.7" screen, but that requires a large memory size and I don't have small boards with more powerful chips that support libraries.
Installed a LCD, 12/17
thanks for the extension!
  • hugohu
    hugohu over 5 years ago in reply to ralphjy +3
    Ha. Tariq sent me this pi for this project14 and i don't want to be a traitor and not submit anything. Hehe. Short deadlines? You bet. I'm also.. *considering* builidng onto this for the making time one…
  • mp2100
    mp2100 over 5 years ago +3
    Huh, I bought one of those google AIY kits at microcenter too. It was cheap because is was a few generations old. For the G company, anything from 2019 is ancient history, no support, libraries not available…
  • ralphjy
    ralphjy over 5 years ago +2
    The Making Time Competition ends 1/14. You could switch to that and give yourself more time for the project. Or maybe short deadlines help cure your procrastination .
  • ralphjy
    The Making Time Competition ends 1/14.  You could switch to that and give yourself more time for the project.  Or maybe short deadlines help cure your procrastination image.
  • hugohu
    Hehe.
    I'm also.. *considering* builidng onto this for the making time one.
    And also something else.
    And then, also something else...
  • hugohu
    Hehe.
  • navadeepganeshu
    navadeepganeshu over 5 years ago in reply to hugohu
    Nice Project!
    Hugo,
    Did you receive this Pi kit as for Vintage upcycling idea winner and to execute at Project14?
    I did see a comment regarding this but, didn't get any update on providing Pi/Arduino.
  • hugohu
    hugohu over 5 years ago in reply to navadeepganeshu
    Oh, there were 10 people who got one, and 5 "supporters" that would get the book after release?
    So I asked Tariq for a Pi since I wanted to make a pi radio(which I scrapped), and he sent me a Pi 4, 4GB(which I didn't expect).
    Few days later, no reply, and got an intracompany purchase in the mail.
    A shiny new pi!
    It wasn't quite a kit, only the pi was provided, I had this kit from before after buying it at micro center for 2.99, so...
    hehe.
  • cbohra00627
    cbohra00627 over 5 years ago in reply to navadeepganeshu
    Same here!
    I also didn't receive them. Actually, I had forgotten about thisimage.
    Thanks for remindingimage.
  • hugohu
    hugohu over 5 years ago in reply to cbohra00627
    Ouchhhhhhhhh
