Robots with Wheels
  • Robots with Wheels
Robots with Wheels
Blog The Making of R2D2 - The Force on Wheels
Join Robots with Wheels to participate - click to join for free!
  • Author Author: Sean_Miller
  • Date Created: 13 Apr 2018 12:22 AM Date Created
  • Views 5749 views
  • Likes 20 likes
  • Comments 19 comments
  • morobotsch
  • robotwheelsch
Sean_Miller
Sean_Miller
13 Apr 2018
Although as a kid, for some reason, I thought R2D2 hovered like a land speeder.  He actually had wheels which can be seen in a lot of shots in the movies - even the prequels and sequels.
For the Project 14 Robots on Wheels project, I'll take a trip down memory lane at the making of our R2D2 - a screen ready, semi-autonomous version of what we call - The Happy Machine.  We call him this, because he can roll into any environment and you will see nothing but smiles on the faces in the room.
The Inspiration
When my son was around six, I told him that when I was his age, I always wanted to build an R2D2.  I would look at tree stumps and imagine how I could cut it up into his shape.  So, he and I did a Google search to see if anyone else ever had that crazy idea.
To my surprise, I found a forum on Yahoo Groups just for building R2.  A guy in Australia was leading the charge since 1999.  He had grown a community of 5000 around the world by 2010.  From there, we stumbled upon this video:
https://www.youtube.com/watch?v=azE7bifgzUg
This video showed me how he was a Happy Machine.  It sealed the deal - we were going to build him.  The Yahoo Group led me to a relatively new extension to the club: astromech.net which now is the primary hub for the group.  I met some really smart people who were so very helpful - similar to element14.
The Learning Curve
As I researched, I immediately became attracted to the coding of the mechelectronics of the build.  It was also the period I found the Ben Heck Show.  I had programmed for leisure since I was 10, so now applying programming to control hardware was super fun.  For over a year, I did nothing but learn about the Arduino, Netduino, proximity switches, servos, and motor controllers.  Autodesk Fusion didn't exist, but I found Blender.  It was, and still is, the hardest software I ever learned - but it is an amazingly powerful, free tool to substitute for 3D CAD once you learn it.  I'm glad I did as it led to good visualizations of projects at work and dabbling in game development.
The Grunt Work
I'd talk to folks at work about the project and they would say, "I'd like to see it."  I realized that after a year all I had to show were wires and microcontrollers.  So, I forced myself to get to the grunt work - physically making the droid.  This required woodworking skills, resin casting, metal work, and model building.
I was able to get ahold of drawings that gave a template to make his body frame out of wood.  So, I broke out my table saw and router and got to cutting:
After I had a sturdy frame, I learned about the material High Impact Polystyrene.  It is a sheet plastic material used by prop designers and model builders.  You can obtain it in various thicknesses.  Using solvents, it can be chemically welded instantly to allow you to make parts.  I used this sheet material to shape all non structure parts such as his foot shells.  I also used it to laminate over all wooden parts to give it the illusion of him being built from metal once painted.
For the small parts, I learned how to make molded resin parts from Smooth-On.  I would use clay to make one part, then resin cast it to duplicate it as with R2's coin slots:
3D printers weren't yet affordable.  So, this old school approach served me well.
It took about 3 years to find the time to research, 2D print & puzzle templates together, cut out the plastic, cast the resin, route wood, and assemble and paint.
The whole family was involved on applying the two layer of body skins:
The legs were a big challenged in that part of the journey.  I had to keep in mind I had to get electricity to the feet when designing my approach without the wires showing.  So, I routed a hidden channel in the legs and ran the wires before gluing and screwing it all together.  Here is a video showing the extensive process:
They turned out pretty good:
The Wheels
A popular builder on astromech.net had posted his personal design for the foot drives.  I liked everything about it, but decided to upgrade his sleeve bearings with roller blade bearings.  I worked in a fab shop for automated sowing machines when I was 18 and my sole job was to cut lengths of metal.  The experience finally paid off.  With a reciprocating saw and a metal cutting blade, I carved out the frame.  Since then, I have acquired a "portaband" which would have made it much, much easier.  You can see my first test drive of the assembled 4 wheel drive in this video:
The mechanical parts (chain, sprockets, shafts) came from SurplusCenter.com.  They are a great source for mechanical supplies.
The Controls
After 3 years, I had a great movie prop.  Not every body detail was finished, but we had enough to apply my programming and microcontroller skills I learned at year one.  Ben Heck taught me how to make my own PCB.  So, using Eagle, we designed the PCB shields to control R2's motor drivers using XBee radios.  This allowed for his control to fit in my pocket.  This makes him truly magical because people don't know how he is moving around.  When asked, I just say "The Force!"  It makes most men mad, though.  They just want to know how, but a good magician never tells his secrets.
The dome lights are controlled by an Arduino Mini.  You can see it in this video where we troubleshot his lights:
My first true circuit was in 2013 when I made a voltage regulator circuit.  Looking back, its fun to remember how rookie I was.
We first got the microcontroller to work with an RC controller:
We quickly evolved, though, and we soon had an OshPark.com PCB.  My son learned along side of me:
I used the Netduino for the foot control microcontroller, which has an Arduino form factor, but out of the box could be programmed with C#.  I love the language due to its ability to have Threads.
Joystick Design:
Receiver Design:
With C#, I had threads reading a proximity switch, reading the thumbstick from the Xbee, and randomly driving the dome.  I could click the thumbstick and he'd go into an autonomous mode where he would use a front proximity sensor to move around without hitting things:
I would never turn my head from this mode since he only had one proximity sensor to prevent collision.  However, he also could do "idle animations".  This further allowed the illusion of full autonomy in that I could have both my hands in full view of the crowd while he moved safely on his own.  His proximity sensor served as an interlock to prevent running over someone.
The Finishing Touches
Now that he is fully Movie Ready, fully controllable, and has been a big hit at school functions, work functions, and Halloween, the hobby continues.  Every few months, I'll add a new servo to open another panel.  With each one, he comes more and more to life.
Closing Thoughts to this Robot on Wheels
Building R2 was a journey that took my son from 6 to 10.  He and I both learned so much.  Although I am an engineer, the journey taught me more than my college degree did.
If anything, we both learned - if you can dream it, you can build it.  It just takes commitment.  That level of commitment translates to something amazingly impactful.  When people see him, they don't imagine him being made, but rather, that they are in the presence of the real R2 - the Happy Machine.
I do thank the Ben Heck show for inspiration along the way.  I wish I had joined this community sooner.  However, the guys and girls at astromech.net were absolutely fantastic, too.  Just like here, it is so great to be among a community without trolls - a group that is eager to help one another.
I hope this serves as inspiration for future builders as well.  As my boy says - Let's get to it!
    jw0752 over 8 years ago +5
    Hi Sean, What a wonderful adventure you and your son have been on. This is the type of education that can not be purchased. Thank you for sharing the build and the inspiration with the rest of us. Joh…
  • Sean_Miller
    Sean_Miller over 8 years ago in reply to tariq.ahmad +4
    Did you flip your loose tooth out like that, too, in every single picture taken?
  • Sean_Miller
    Sean_Miller over 8 years ago in reply to mcb1 +4
    I believe he weighs in around 110lbs (50kg). This makes it where you don't ever want to take your eye off of him when he's moving - particularly with little ones around. I took him outside early in the…
  • Sean_Miller
    If I were to do it again, I could probably make him in 4 weeks working straight 8 hour days.  If I had a laser cutter and 3D printer, you could take a week off of that.
    Doing it from scratch without a 3D printer or laser cutter, however, was a different story.  At the time, my electronics skills were only enough for me to wire power sources such as installing a car stereo or messing with home residential wiring.  PCBs were a bunch of blips and bloops to me.
    So, I had a lot of research, a lot of design files to find or make, a lot of software to learn (Eagle, Blender, C#), and a lot of trips back to the drawing board.  I also never used a wood router before, which is the most dangerous tool I've used even compared to my welder.
    So, I'd say I had more like 1500 or more hours over 4 years with everything required to get my brain to make my hands move in the right direction.
    We're definitely grander for it, though.  By the end of the journey, we got a 3D printer, learned PCB fabrication, and learned Autodesk Fusion.  We can whip up a project pretty quickly.
    A young mechanical engineer at work told me that one of our builds on our YouTube channel was like the senior year engineering projects he saw in school.  I drew it up after work for fun and we banged it out on the weekend.
    I didn't think about the importance of being self-taught as a kid and young man.  For the boy, that is the #1 principle I am bestowing to him; regardless, of what he wants to do in life.
    See ya',
    Sean
    genebren over 8 years ago in reply to Sean_Miller
    Hi Sean,
         "I also never used a wood router before, which is the most dangerous tool I've used even compared to my welder."
    There is good reason to be cautious about any tool. Routers are indeed dangerous as are the whole gamut of spinning cutting tools.  As a person who can longer rely on their fingers for the simple task of counting to ten, my best advice for anyone using power tools is keep you full attention on what you are doing right now, not what you will be doing next.  Respect for the danger is paramount.
    That being said, never let the danger of tools prevent you from using them, for learning through doing is one of the most important lessons in life.  What you have done is absolutely amazing, and taking your son along on this journey of doing and learning is an great gift.
    Gene
    Hi Sean,
    Gene
