Simple Electronic Repairs
  • Simple Electronic Repairs
Blog Repair of a CNG boiler control board
Join Simple Electronic Repairs to participate - click to join for free!
  • Author Author: koudelad
  • Date Created: 5 Jan 2018 8:01 PM Date Created
  • Views 3125 views
  • Likes 10 likes
  • Comments 8 comments
  • boiler_control
  • boiler
  • simpleelectronicch
  • boiler repair
koudelad
koudelad
5 Jan 2018
Hello,
(Note: I know I am posting this a month after a deadline, but I thought it is worth mentioning as I am very happy about it.)
Previous month's theme was Simple Electronic Repairs Project14 | Earn a $100 Shopping Cart for Your Simple Electronic Repairs! . I didn't have anything to repair that time, but a coworker approached me one week before Christmas, because he noticed I was talking about electronics to another colleague. He has got an almost 16-year old Vaillant CNG boiler for a heating of his entire house (including a water tank). The trouble was that a control board couldn't switch the burner properly. He did a good job examining the control board and finding out, that after knocking on one of the two relays present on the control board, the relay switches the contacts and the heater is turned on. This was his daily job for a few weeks, in fact, turning on the electronics every day after coming from work, knocking on the relay, heating the house and water (thermostat was bypassed for obvious reasons, max. output was delivered to the heating system) and switching everything off in the evening.
The servicing company said that another board (probably used) would cost ca. € 400.
I requested a photo of the board and especially the relay and their surrounding:
The relay is identified as EE Electronic E3206S (for switching 250 V, 10 A), working with 24 V DC and resistance of the coil 1100 Ohms. I haven't found a way to buy a new one from common distributors, but I found a seller on eBay that had two unused relays (probably in the past). It took about 2 weeks during the Christmas time to get it from Australia to Czech Republic.
Yesterday I visited my colleague with a soldering iron and a simple manually operated "pen style" pump and replaced both relays. I am glad the board was originally soldered using a lead solder, so I could do the work easily. I have no I idea whether I would be successful if the lead-free solder was used (need to do more research on that, I only have one bad personal experience).
After replacing the relays and plugging everything back again, a magical moment came. The boiler started as before the breakdown.
We are both happy that we gave a meaningful life to the board again, for about € 10, saving € 390 + price of the work.
This was not the end of this evening image I also repaired a toaster (burned temperature fuse soldered inside) for about €1 (new could cost ca. € 30 - 50) and rewired his house lights in one room (after a not very successful change of a power switch), so it could be switched on and off from two places.
I don't have a video, because there wouldn't be much to see, as the device is well covered and the flame is not visible.
David
  • tariq.ahmad
    tariq.ahmad over 8 years ago +3
    Thanks for sharing koudelad ! It's never too late to post projects especially now. We will be giving out shopping carts to give as part of the The Holiday Special . Any project submitted while this event…
    jw0752 over 8 years ago +3
    Good job, I always wonder how many good boards and equipment end up in the landfill just because no one had the inspiration to attempt a fix. Good job and congratulations. John
  • koudelad
    koudelad over 8 years ago in reply to jw0752 +3
    Thank you. I feel exactly the same. I am now in a process or ordering new electrolytic capacitors for an old ADSL modem. Yes, a new one costs ca. € 40, but a few capacitors for € 8 will fix it. (Especially…
    shabaz over 8 years ago
    Hi David,
    Awesome job(s)! This series on repairs is really great. And good seeing the massive savings by not throwing out hardware. Spare parts for boilers are really expensive, and of course schematics are not always available, so the system is often against those who wish to self-repair : (
    Hi David,
