Vision Thing
  • Vision Thing
Vision Thing
Forum Possible help for BB-AI heat problem
Join Vision Thing to participate - click to join for free!
  • Replies 7 replies
  • Subscribers 11 subscribers
  • Views 1858 views
  • bb-ai
  • overheating_problem
clem57
clem57 over 7 years ago
I did some investigation and found the BB-AI uses a governor of policy0 which is a custom setting. So I am testing setting the normal conservative to reduce the heat.
Here are the two commands:
  • sudo cpufreq-set -c 0 -g conservative
  • sudo cpufreq-set -c 1 -g conservative
I will monitor these overtime and report results...
Clem
  • clem57
    clem57 over 7 years ago +2
    After 30 minutes of usage and 1 hour of sitting idle (Chrome and terminal window open, with no typing),I do feel the heat sink is less hot to the touch. I am using the 1 Mississippi, 2 Mississippi... I…
  • cstanton
    cstanton over 7 years ago in reply to clem57 +1
    Have you tried monitoring the temperature either via a console command or external temperature sensor?
  • clem57
    clem57 over 7 years ago in reply to cstanton +1
    Yes, after discovering the correct place to find the temps for the CPU.
  • clem57
    After 30 minutes of usage and 1 hour of sitting idle (Chrome and terminal window open, with no typing),I do feel the heat sink is less hot to the touch. I am using the 1 Mississippi, 2 Mississippi... I can get through that much before removing my finger.
  • cstanton
  • clem57
  • gdstew
    gdstew over 7 years ago in reply to clem57
    I posted where to find these in a discussion a couple of days ago (Reading BeagleBone AI Temperatures) and added a bash script to display one or all of the temperature zones
    to that discussion after I wrote and tested it. From what  was seeing it looks like zone 2 is the one for the dual core Cortex-A15.
  • phoenixcomm
    phoenixcomm over 7 years ago
    does anybody know the screw threads to mount the fan on the heatsink ?????
    shabaz over 7 years ago in reply to phoenixcomm
    Hi Cris,
    They are metric, M3 threads. I created a basic dimensioning drawing here :
    BeagleBone AI BB-AI Photos for Documentation Purposes
    (not a draughtsman-level drawing, just some practical dimensions marked for making a case or heatsink).
  • phoenixcomm
    phoenixcomm over 7 years ago in reply to shabaz
    shabaz Thanks they looked like maybe 4-40 but I haven't unpacked my hardware. All of the hardware will stay in the garage.
